Chain chatter at cassette on three largest rings: SRAM X5
Old 08-27-12, 08:53 AM
Noize4
Noize4's Avatar
Bikes: ‘16 Domane 4.6 Disc, ‘17 Bianchi Impulso S-Sport, ‘12 Giant Escape 0
Hey everyone,
I'm fairly mechanically inclined, but am new to bike mechanics.
I have a month old hybrid, X5 RD, and recently swapped tires on the rims. Wheels were re-installed properly as far as I can see (pulled and did a second time), but I now have a chain chattering noise at the rear cassette (9 speed) on the three largest rings. Particularly third gear. The chatter occurs on those gears no matter what ring I'm on with the FD, so I assume it's some adjustment I need to do to the RD.
I flip the bike and go through the gears, and it changes throughout the cassette without issue. It just now chatters on the three tallest rings, particularly third, which is the worst.
Any idea what I should adjust to try to quiet this chattering sound?
Thanks in advance!
Noize4 is offline
Old 08-27-12, 02:03 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,271 Times in 877 Posts
Front = rings
Rear = cogs.
There is no front cassette, so rear cassette is redundant.
Anyway-
Is the noise loudest on the largest RING, which means you are cross chaining?
You might try turning the barrel adjuster on the RDER 1/4 turn at a time and see if that helps/hurts.
Keep track of where you started in case that isn't the problem.
Another possibility is that your cable needs to be cleaned/lubed.
As you go to the larger cogs, you typically use more cable pull/tension. (some RDER's are opposite)
IF the cable is "sticky", you may have the tension too loose which tends to quiet the smaller cogs.
Bill Kapaun is offline
Old 08-27-12, 02:17 PM
wphamilton
wphamilton's Avatar
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times in 228 Posts
Chain too short can cause chatter on the largest cassette cogs. How I know ... was replacing my chain, noticed I could feasibly take two links out, and impulsively did so thinking it might make it hold better on the chain ring when in the smallest cog ... the chatter was the first thing I noticed.
wphamilton is offline
Old 08-27-12, 02:45 PM
Noize4
Noize4's Avatar
Originally Posted by Bill Kapaun
Front = rings
Rear = cogs.
Anyway-
Thanks for the explanation and helping me understand the terms better, it helps make learning easier.
I'm at work and uncertain which ring it's loudest on. I'll check it out when I get home and report back.
Don't think it's this. Stock chain on pretty new bike. It just started after swapping a tire.
Noize4 is offline
vintagerando
Bicycle Mechanics
18
03-20-19 08:02 PM
Myosmith
Bicycle Mechanics
5
07-17-17 12:52 PM
jezmellors
Bicycle Mechanics
16
08-20-11 04:20 PM
Davidlean
Bicycle Mechanics
1
08-28-10 07:54 PM
