Another Falcon This Time San Remo Equipe (Late 60s).
Another project nearly complete, a late 60's Falcon San Remo Equipe. The fame is Reynolds 531 butted tubing and forks, chrome headlugs, all chrome forks with Cinelli like sloping crown (I think it is a Davis crown), full Campagnolo Nuovo Record equipment with Cinelli bars and stem (1A nutted), Brooks Professional saddle, yellow label Fiamme rims laced to Campagnolo Record low flange hubs, Regina chain and freewheel, campy pump umbrella, Silca Impero pump, Christophe toe clips with blue Lapize leather straps. Just need to do a little touch up and the bike is finished.
Quoted: 3803 Post(s)
Liked 3,324 Times
WOW!
What a beauty.
At first glance it looks just like the Professional.
Can you explain the difference between this and the Professional?
Are brakes "no name?"
What a beauty.
Bikes: 1970 Holdsworth Mistral, Vitus 979, Colnago Primavera, Corratec Hydracarbon, Massi MegaTeam, 1935 Claud Butler Super Velo, Carrera Virtuoso, Viner, 1953 Claud Butler Silver Jubilee, 1954 Holdsworth Typhoon, 1966 Claud Butler Olympic Road, 1982 Claud
Quoted: 10 Post(s)
Liked 11 Times
Your bike is Gorgeous!
Thanks. The San Remo Equipe was the top of the Falcon line (the bike does have Campagnolo Nuovo Record brake levers and calipers), however there were other San Remo models which had less Campy equipment. I think you are referring to the Raleigh professional? Yes the Raleigh Pro and Carlton Pro do look similar with the chromed sloping fork crown.
Liked 3,324 Times
Hi Juvela,
Not confusing bicycle with anything else.
Have seen this model referred to by others as the Professional model. Perhaps they were mistaken or perhaps both names were used depending on year. Am not a Falcon expert so either way is just fine.
The term "no-name" when used in conjunction with Campagnolo Record brakes refers to the first year, ~1969, when the caliper arms were smooth and unmarked with the Campagnolo name.
Thanks very much Sante.
Are those newer decals? The downtube one looks right, but the chrome-look seat tube decal looks like late 70's-80's.
Love the robin-egg blue paint. If I ever repaint mine, I'm going for that color.
I am not sure if the bike has been re-finished or not. The paint certainly looks original but one might get that impression if it is an older refinish. If it is refinished that might explain the seat tube decal however I would still like to check some older frames as so many of these Falcon San Remo bikes had little detail differences. Mine for instance has unusual top eye treatment and unusual serial number (maybe built for the Falcon Team? :-). The San Remo was built is a separate section of the Falcon factory by their best frame builders with each frame taking around 3 1/2 hours to build which does not sound like a long time but it actually is when you consider that Falcon was a large producer of frames - churning them out. Forgot to say that the pale blue was the team color. Another interesting thing is that by the late 60s the team bikes were still using the Weinmann brakes which might explain why I have the Campagnolo branded later calipers - maybe they were changed out by an owner somewhere along the way?
Liked 3,324 Times
Yes, certainly. If one looks at the position of the brake pads in the adjustment slot they are right at/near their lower limit which is 56mm. If the frame had been constructed for Campagnolo Record brakes it would have been built with 52mm brake centers front and rear. The Weinmann 610 caliper has a center of slot dimension of 56mm. This is about where the pads appear to be positioned. 56mm is the lower limit of the standard reach Record caliper.
I had a Falcon from 1971 or 72 with the chrome seat tube decal and the same chrome fork with Cinelli crown.
I was looking at a 60's ('67 or '68) bike that belongs to a collector (Velo Classics blog) and his has the same seat tube decal as mine so I am assuming mine is correct.
Quoted: 1372 Post(s)
Liked 1,748 Times
Perhaps one of my favorite English bicycles and my size also. Great job!
I guess they changed the decals in the 70's to the white panel design.... mine is c. 72-74:
Quoted: 1854 Post(s)
Liked 661 Times
Liked 661 Times
Liked 3,324 Times
Liked 661 Times
Ok. I have both sizes, but the short ones were circa 1984.
Liked 3,324 Times
Liked 3,324 Times
Very nice photography.
Very shiny bicycle!
Very shiny bicycle!
southpawboston
Classic & Vintage
53
02-02-12 12:19 PM
septacycles
5
08-23-10 10:56 PM
