Are Walmart bikes really dead end bikes?
I was talking to someone in a bike store (a competitor of Walmart, I guess) and was told that Walmart bikes are "dead end bikes", they are built in a way that if a Huffy's part XYZ (I forgot which) breaks from heavy daily use on our hilly trails, it costs more to replace than the value of the whole bike.
As opposed to, say the Cannondale or Specialist bikes which their shop sells which are much less prone to break, are repairable even after a bunch of years of use, etc. So for frequent hillside use without bike breakdowns, I'd need at least a $450 bike, not from Walmart or Target, but them.
The bike store gentleman sounded quite convincing, and his claim above might be totally true. As a novice I have a difficult time telling. So it hit me, perhaps I should confirm on a forum of experienced cyclists, are Walmart mountain bikes (like the Genesis GS29) indeed as bad as stated above? Dead end, breaking down 3x as often as, say, a 3x pricier Cannondale?
Thank you for all the insight
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
As they say, the devil is in the details. The cheap bike with standard parts can be repaired very cheaply. Those with sub-standard parts will break down more quickly.
You can replace the whole rear wheel for example, for less than your bike store will charge to replace the freewheel.
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,833 Times
here we go again.
search is your friend. if it's working
try - WalMart, Magna, dept store bike, etc
Edit: Welcome to Bike Forums. Good question. Very recently discussed topic. Look at thread titles only a few pages back for similar topics. Inexpensive vs High-end, Who Really Needs a $1,000 Bike?, My Huffy is better than your Italian!
You'll get the drift.
Bench vise user
Bikes: 2004 Orbea Marmaloda, 1982 S12-S LTD, 1956? Maino, 1985 Sagres
Quoted: 79 Post(s)
If you want to get a Walmart bike, the Schwinn Varsity is actually halfway decent if you are mechanically inclined and can fix assembly errors. It has pretty good components.
Lucille
I got my Schwinn Meridian from Walmart a year ago, and along with it an inexpensive extended warranty. I ride it all the time and it is fun to ride, and have two other bikes I ride also.
Recently some spokes broke on the right rear wheel of the Meridian which is the drive wheel. Because it was right before (days before) an actual year, Schwinn honored their warranty and sent me a new wheel, and the extended warranty sent me a courtesy check for $15 just in case Schwinn wanted me to return the old wheel which they didn't. So I actually made $15 off that repair.
Bikes: 2012 Salsa Casseroll, 2009 Kona Blast
Quoted: 1031 Post(s)
Liked 208 Times
By contrast department store bikes are pretty bad, and not much fun to ride. They are built to be disposable. Real world example. I was at my local bike shop a few months ago when a guy comes in with a Wal Mart bike. Front wheel is badly wobbling, really barely rideable as it looks like it is on the verge or completely failing. The problem was the cheap hub and bearings. Completely shot. The bike needs a new wheel. The bike shop basically told them a new wheel from them would cost around $45. The guy said he only paid $50 for the bike. And that is just one part. Even if he replaced the wheel, what does he do when the back wheel fails? Or some other part? If you start replacing the parts on a Wal Mart bike one component at a time, by the time you are done, you just spent what it would cost you to get something decent to begin with.
If you are on a tight budget and can't afford the $400 to $500 retail for a new entry level bike from a bike shop, you could look for a sale (in Northern climates, you can find good deals on floor models in the winter, maybe), or buy a lightly used bike for maybe half the cost of a new one. Or even go with something much older for a lot less, maybe $100 to $150 that is maybe 10 to 15 years old with the idea of replacing wear items like chain, cassette, chain and brake pads.
Bikes: 2015 Giant Escape 2,
Quoted: 52 Post(s)
I recommend that you look at the Giant escape series. 4 model that run between $400- about $650. A lot of bike for the money
Bikes: Enough plus 1
Quoted: 364 Post(s)
Many products are cheaper to repurchase and replace than to repair. One reason so many products say "warranty" on the packaging - of course the consumer pays shipping and handling each way to get a repair or replacement on their $15 LED lightbulb or whatever - so it never actually happens.
Would I have my S-Works Roubaix repaired - absolutely. My $200 WM bike - I would be willing to spend $50/$60 tops on some part I could replace - otherwise adios.
IMHO - anyone who needs a reliable starter bike should stay away from mass merchandisers, go with a good brand bike from a real bike shop.
If you want to buy a cheap bike for amusement - the fun of seeing what you can get out of it for your minimal investment - go for it.
Bikes: Nashbar Road
Liked 341 Times
Liked 208 Times
In that many shops don't want to service those bikes, it's a good example. Possibly a cone wrench and a couple of minutes would have taken care of the guy, and failing that $25-$30 on Amazon would get him a new wheel. I think a person needs to be somewhat mechanically inclined to make these bikes work long-term.
Bikes: Nashbar Road
Liked 341 Times
I don't think so. According to the bike shop mechanic, the bearings were really bad, and the wheel needed to be replaced. The bike shop would have sold the guy a wheel if he really wanted one. Yes, you could buy a wheel for $30 on Amazon, and mount the tires yourself. To be honest, I think the guy was worried about getting home on the bike and was hoping the shop could service the hub on the spot, which is why he was coming to a bike shop. Maybe amazon was the guy's next stop.
Those cheap wheels can last for years, thousands and thousands of miles, with even minimal maintenance. The real issue here is that customers with Walmart bikes do tend to balk on repair prices, and many bike stores understandably don't appreciate it. There are some which will outright refuse to look at one, or exaggerate the issues. My take on that is that a person needs to be more self-reliant if he wants to ride the cheapest bikes he can get.
Liked 208 Times
Hopefully he'll add a buck or two more for bearings in his Amazon order, which might have taken bike shop guy another 10 minutes to replace. The only likely way the wheel was useless is if he'd worn ruts in the races, and even then tighten it up with new balls and ride home. Sorry but I am highly skeptical of the mechanic in this story.
Just one more data point, again relating to my old Bianchi. A few years ago, I loaned it out to my cousin, who isn't a regular rider but sometimes rides with his wife in and around Chicago on his department store bike. When we get back from our ride he tells me how much more enjoyable it was riding when he wasn't constantly fighting the bike.
Quoted: 111 Post(s)
Liked 5 Times
If a wal-mart bike costs $200 and the cheapest bike-store bike costs $400, you would have to spend at least $100 to fix the common problems with the cheap bike, plus it's gonna take at least a few hours of your time, which is worth something as well. If you want something reliable, you're much better off buying the low-end bike at a bike store than you are buying anything at wal-mart.
Also note: at Wal-Mart, the brand name has no bearing on the quality of expensive items, at all.
Wal-mart arranges with companies to product extra-cheap versions of their name-brand products, just to sell at Wal-Mart.
Once upon a time (back in 2006) the CEO of Snapper turned down Wal-Mart's offer to sell cheap mowers branded with the Snapper name:
https://www.lawnsite.com/threads/the-...l-mart.243720/
...But it looks like that decision got reversed at some point, because now there's consumer complaints about Snapper mowers and other lawn equipment that people bought at Wal-Mart:
https://www.consumeraffairs.com/homeowners/snapper.html
The article notes that at the time (2006) the cheapest Snapper push mower cost $519... A couple years back I was told that the cheapest Snapper push mower (at the dealers) costs around $800.
And Wal-mart is not the only company that does this. Most of the other big chain US stores do it as well.
I know for a fact that regarding bicycles: a number of bicycle manufacturers that sell bikes at private dealers and department stores have agreements with their private dealers that the highest quality level of bikes that the department-stores get to sell is still a lower-quality than the lowest quality level of bikes that the bike stores get.
To add more detail to the original post, the purpose of the mountain bike I am looking to get is to be shared between a whole group of novices like me. Between all of us, it might get potentially 30 miles of use a day. Hence my concerns with the maintenance and reliability aspect.
Its all about the cruise
Hears a simple answer..If you need to do this...
Or this
Then go to the LBS.
Complete lie....the expensive lbs bikes break as well. These elite riders put bikes thru harder usage than say the avg individual....And when they break you will pay money to have it repaired...
Now if your an avg human being who enjoys a nice bike ride......
Then I wouldnt waste good money at a LBS.....A poster above is right. If you read down the forum list of threads you will see many topics on the same thing with the same results..If your a hardcore you love the lbs....Normal human being your walmart bike will be just fine....Again, they both break down..
If it warrants, pay your 100 bucks, enjoy it, take care of it, it will last long enough. Im on 3 years 400 miles no serious breakdowns.......Other than weather lol
If your an extreme hardcore I hope you have 10k lol
Or this
Then go to the LBS.
Bikes: Nashbar Road
Liked 341 Times
Thank you for the advice, I'll heed it. Does any of the brand name $450 bike handle gravel hill roads better than the rest? For non-acrobatic riding.
Liked 208 Times
So, a group of people are going in together on the purchase of the bike, or are you buying it and planning on lending it out to a bunch of people?
Quoted: 523 Post(s)
Liked 229 Times
If they are still having garage sales in your area, go out looking to see what is available. Normally I wouldn't choose anything from WalMart but keep an eye out for used bikes that are within the limited price range for some friends who can't afford a bike store bike. I picked up a used Mongoose bike recently for $50. It had already survived 13 years and was still in excellent condition. The new owner put a pair of city tires on it and was ready to ride. It was probably not a bike shop bike new.
If you want the Genesis 29, you can read reviews here from people who ride bikes like it and like them: www.bigboxbikes.com ? View topic - Genesis GS29 and this pulled from a review on Amazon.
As stated above it was not put together professionally so you MUST go over every bolt and screw before you ride to ensure your bike doesn't fall apart when you ride. There aren't many bolts and screws so it takes less than 5 min to go over the entire bike with normal tools that I'm sure you already have in your tool box. Brakes are very "soft" and the lever practically goes all the way to the grip (again this is part of the tuning process since it was not from a pro shop). Gears aren't aligned so when gears are shifted it doesn't shift clean. Seat is considered soft but not soft enough for my taste plus it is narrower than what I like (this is purely a rider's preference). These "con's" should be expected from any bike purchased at ANY big box retail store so they aren't really "cons".
That person's experience is similar to what I saw with a kid whose father insisted on a WalMart bike in spite of his being able to buy an entry level bike at a store. The pedals fell off within a couple of miles on the first ride and stripped the cranks in the process. It took three tries to get one that had been assembled correctly so if you don't know bike mechanics add in the cost of having a legitimate bike shop at least check it over.
Bikes: Nashbar Road
Liked 341 Times
Your specific use case of a whole group sharing it, it's hard enough to recommend a bike for just one person so I'm not going to touch it.
