Does it make sense? Bar end to STI Shifters? Gevenalle GX Shifter
Quoted: 9 Post(s)
I have a Diamondback Haanjo EXP Carbon Bike, so does my friend and he hates the bar-end shifters.
Doing a bit of research I saw a few people changing their bar end shifters to these (Gevenalle GX Shifter).
I find that bar end shifters for me are something to either get used to and do better or just don't struggle and change. Where I ride, there are up and down minor elevations and having ability to easily change gears is priceless. So,
1. Does it make sens to change bar end shifters to Gevenalle GX Shifter?
2. Other than the cost of shifters, how expensive/troublesome is it to make that change?
Thank you.
Thank you.
Thank you.
Thank you.
Also, if you are going to change your brake levers to brake/shifter levers you could also get STI/brifters.
If you are reasonably mechanically inclined and have some bike tools you should be able to handle this yourself. Youtube and the Park Tools website are loaded with how-to videos.
You bar-end cable housing and cables may be long enough that you can modify the lengths to fit the new shifters without having to buy new cable and housing. You will need to unwrap and re-wrap the bar tape in order to change the levers. If you are careful you may be able to re-use the tape - but good tape is pretty cheap - and while you are re-doing it you can put some gel pads under the tape for extra padding. I've used the Planet Bike gel pads and like them.
Once you get the cables re-installed you will need to adjust the shifting front and rear.
Sounds like a good rainy day project. Good Luck.
IIRC, you don't need Gevenalle solutions unless you have a 10sp or higher mtb rear. Your bike is 3x9, correct? I think Shimano 3x9 brifters will work.
Gevenalle works fine (I've had/used them before). The installation is not difficult, but you will have to unwrap and rewrap your bar tape--that's because of the bar end shifters. But the product is a little overpriced for what it is (rebadged Microshift products).
Bikes: Novarra Randonee 2016, Trek Verve 2 2015
Quoted: 97 Post(s)
I have Microshift barcons on my Randonee and I don't like them much either.
The main problem is that, when you are on the hoods, you have to take your hands off the hoods, every time you want to shift gears. That's unsafe at high speeds.
When on the drops, in my setup, you can't reach the shifters and still be in touch with the brake levers, which I consider unsafe, as well.
If you use the Gevenalle shifters, you solve the problem of shifting with your hands on the hoods. However, when you are on the drops, you have to let go of the drops to shift. Just as unsafe, although likely it would occur less often.
Brifters is the right answer. As mentioned correctly above, if you have a 3X9 setup, you will have the correct pull ratios (my Microshift shifters are m10 to make the pull ratios possible) for an easier swap. Another issue you may encounter is whether your new brake levers will have the same pull ratio like your old brake levers. Also, the front derailleur may present you with problems too, requiring an adapter.
I opened a thread about migrating from Microshift barcons to brifters and a lot of knowledgeable people offered assistance. Should you decide to go the brifter way, it might help:
https://www.bikeforums.net/bicycle-m...-randonee.html
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
I love my Gevenalle shifters. I do wish they used a more ergo lever like the SRAM S500s or something similar to the feel of a newer Shimano STI lever but aside from that I love the actuation of the shifting and the brakes work just great. The problem with most STI levers (minus Di2) is the brake lever is also a shifter so it moves and I just like a brake lever to be just that, a brake lever. DoubleTap solves that problem but I just didn't like the shifter actuation but with Gevenalle I get the ability to sweep a cassette or fine tune a front derailleur all while having a brake lever that is just a brake lever.
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
Thank you.
Thank you.
I have a couple bikes with bar ends. In fact, other than my flat bar bikes, I am in the process of changing everything to bar ends, I simply like them better. I'd argue they are nicer for shifting going up and down hills, I can dump them three, four, five steps in a quick go. I'm not saying this to try and encourage you towards one or another, but you do need to get on your bike and make your own decision, independent of your friend.
All that said, a relative has those on his fat bike, they are nice shifters.
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
Gevenalle are great. I have 11sp on my gravel bike- its easy to use, quick, etc.
not the prettiest of setups, but oh well.
expensive to just try out- $150-200 on a maybe solution isnt appealing to many, but have at it if ypu like!
Downtube shifters must an existential crisis by comparison.
Gevenalle has a origin in Cyclocross racing in bike rich Portland Oregon...
relocating a down tube or bar end lever to the front of the bars,front of the brake lever hoods.
and work in muddy races, and be less costly to replace, during the week between races..
Crash replacements if your 105 + Brifter is damaged is a lot more expensive..
Bikes: I have a few
Quoted: 340 Post(s)
Liked 210 Times
And some of us still use them.
I do have a sudo-CX bike that came with bar-end shifters which I switched to STI because it scared the crap out of me doing 20 MPH off road and trying to get a gear for a climb. On a road only bike I don't think it makes a difference unless you are in a pack racing and bumping.
If you like them get them but IMO they are ugly as hell.
