Niagara Cycle apparently bankrupt
They also might have seen this coming: Trek: proposed tariffs would cost us $30 million a year
https://www.bicycleretailer.com/indu...0-million-year
Full list: https://www.regulations.gov/document...2018-0026-0001
I would not have thought so.
Stevoo
Thanks for sharing the info on Niagra.
That explains my recent Amazon purchase from them that was never filled.
I too bought from them over the years as they had good prices. Never any issues.
Sad to hear they are out of biz.
Quoted: 11 Post(s)
I do not think they even had them. But as the link to what is being included shows, it is far more than just E-bikes.
This may be worthy of its own thread.
- Casing for bicycle derailleur cable; and casing for cable or inner wire for caliper and cantilever bake, whether or not cut length; of plastic.
- New pneumatic tires, of rubber, of a kind used on motorcycles.
- New pneumatic tires, of rubber, of a kind used on bicycles.
- Bicycle rim strips of natural rubber.
- Bicycle rim strips of rubber other than of natural rubber.
- Interchangeable tire treads and tire flaps, of rubber other than natural rubber, except bicycle rim strips, nesoi.
- Inner tubes of rubber, of a kind used on bicycles.
- Electrical lighting equipment of a kind used on bicycles.
- Electrical visual signaling equipment of a kind used on bicycles.
- Parts of electrical lighting equipment of a kind used on bicycles.
- Bicycles, not motorized, w/both wheels not over 63.5 cm in diameter.
- Bicycles, not motorized, w/both wheels o/63.5 cm [25''] in diam., weighing under 16.3 kg & not design. for tires w/x-sect. diam. o/4.13 cm.
- Bicycles, not motorized, w/both wheels o/63.5 cm in diam., weighing 16.3 kg or more, and/or for use w/tires w/x-sect. diam. o/4.13 cm.
- Bicycles, n/motor., w/front wheel diam. o/55 cm but n/o 63.5 cm & rear wheel diam. o/63.5 cm in diam., & wt <16.3 kg w/o acces., value $200+.
- Bicycles, n/motor., w/front wheel w/diameter different than rear wheel diam., nesoi.
- Cycles (o/than bicycles) (including delivery tricycles), not motorized.
- Pts. & access. for bicycles & o/cycles, frames, valued over $600 each.
- Pts. & access. for bicycles & o/cycles, frames, valued at $600 or less each.
- Pts. & access. for bicycles, sets of steel tubing cut to exact length for the assembly (w/other pts) into the frame & fork of one bicycle.
- Pts. & access. for bicycles & o/cycles, forks, nesoi and pts of frames, nesoi and pts. of forks.
- Pts. & access. for bicycles & o/cycles, wheel rims.
- Pts. & access. for bicycles & o/cycles, wheel spokes.
- Pts. & access. for bicycles & o/cycles, aluminum alloy hubs, w/hollow axle and lever-operated quick release mechanism.
- Pts. & access. for bicycles & o/cycles, 3-speed hubs nesoi.
- Pts. & access. for bicycles & o/cycles, 2-speed hubs, w/internal gear changing mechanisms, nesoi.
- Pts. & access. for bicycles & o/cycles, variable speed hubs, w/internal gear changing mechanisms, nesoi.
- Pts. & access. for bicycles & o/cycles, non-variable speed hubs, nesoi.
- Pts. & access. for bicycles & o/cycles, free-wheel sprocket-wheels.
- Pts. & access. for bicycles & o/cycles, brakes (o/than hub brakes) and parts thereof.
- Pts. & access. for bicycles & o/cycles, brakes and parts thereof, nesoi.
- Pts. & access. for bicycles & o/cycles, saddles.
- Pts. & access. for bicycles & o/cycles, pedals and parts thereof.
- Pts. & access. for bicycles & o/cycles, cotterless-type crank sets and parts thereof.
- Pts. & access. for bicycles & o/cycles, crank-gear nesoi and parts thereof.
- Bicycle speedometers.
- Parts and accessories of bicycle speedometers.
I do not think they even had them. But as the link to what is being included shows, it is far more than just E-bikes.https://www.regulations.gov/document...2018-0026-0001
E-Bikes it is really the electronics/battery that definitely come from China, and probably the rest of bike to... since most E-bikes I have seen would be $500 bikes without the electronics on it.
Quoted: 11 Post(s)
But this is for parts made in China, which with bicycles it is still possible to avoid parts made in China if you are not buying the lowest tier of cycling.
Which, besides the relatively low income (versus 3rd world) is partly die to approximately 93 percent of complete bicycles, and at least 40 percent of imported bicycle components being sourced from China.
If the next round of tariffs go thru, the repair business may see more of an increase vs. new bike sales.
Quoted: 18373 Post(s)
Liked 4,508 Times
Niagara sold a lot of stuff on Amazon. I wouldn't think Amazon would have killed them off, unless it was through added fees.
I wonder if there is slowly increasing competition of internet retailers.
This may be the new world... of not internet resellers vs LBS, but rather a cuthroat internet reseller vs internet reseller.
I see some of the Wheelmaster hubs that I had previously been interested in from Niagra are now available from a place called BikeSomewhere.com down in Florida.
I am buying the lowest tier of cycling, like 0.10, 50mm patches, $.5.00 pedals, $8.00, 20'' tires (if they have the money for that) + free labor buy the grace of God.
Because I did not even know they sold super cheap parts like that, I thought they were a higher end seller. Granted, I had not bought anything from them since I replaced my Campy chainrings a couple of years ago and they had the best price.
Hard to make a living on such low margin stuff, as they have shown.
Nashbar maybe?
Nashbar maybe?
Nashbar maybe?
WGB
Bikes: Panasonic PT-4500
Quoted: 1800 Post(s)
Liked 2,334 Times
Peacebyjesus - I had used Niagara Cycle a lot because it was free local pick up, When I saw your post I checked google street view for the Lewiston address for Niagara Cycle and it's the UPS store in Lewiston.
Quoted: 11 Post(s)
Nashbar maybe?
Nashbar maybe?
They are likely the same on Amazon.
I'll have to check but I'd swear I bought my frame from them 13 years ago. It was a Kuota Kredo. They had a shop in NY State and one in Ontario across the border/river/falls, and to save on taxes they shipped from Ontario since I live in NY and would otherwise have had to pay 8.5% The frame was gently used and I still ride it as my main road bike.
Registered User
Quoted: 16 Post(s)
www.lightinthebox.com
www.dhgate.com
www.made-in-china.com
I know some other shopping platforms, but I don't know if they provide the inexpensive parts you need.
Hope to help you.
www.dhgate.com
Hope to help you.
Quoted: 11 Post(s)
www.dhgate.com
Hope to help you.
www.dhgate.com
Hope to help you.
The second site,www.dhgate.com, based on my very limited searches, is more expensive than Ebay. 0.92 - 1.04 / Piece for the same covers and requiring a Min. Order: of 100 Pieces. Two of the standard brake pads were $1.83.
The last site is more like alibaba amd lacks a "lowest price first" seartch option, and was more expensive than Ebay on the brake pads at 3.58-4 / Piece Min. Order: 300 Pieces. I did not find comparable seat pads. However, i did find Lock on type handle grips (which last year were 0.99 each on Ebay, but but now 3.19 for a pair ) apparently much cheaper for eve one, but it requires contacting a supplier to find out the actual lowest price.
All the same, thanks for trying.
Commuting Fool
Bikes: 1988 Miele Azsora, 2022 State All-Road 4130, 2003 Jamis Coda Comp, 1983 Specialized Expedition, 1994 Norco Monterey
Quoted: 104 Post(s)
Liked 72 Times
I hate to be the one to revel in others misery, but this feels oh so good. Worst bike shop ever! I live about 15 miles from it and the dude that owns it was a giant pile of hot garbage. This is a very happy day indeed.
Quoted: 1163 Post(s)
Liked 442 Times
since you are in the Niagara Falls area, do you happen to know whatever happened to ital-tecno? They used to advertise in Velo News (before the Internet-hah) and had great selection and pricing on Italian imported parts, particularly Cinelli. About 10 years ago they were liquidating their inventory apparently (on eBay). I picked up a Grammo titanium stem cheap. I just wish I knew what happened to them.
I live in Western New York and largely used Niagara because I could pick up at the store and avoid shipping charges. In addition to the very good prices that they had. They were a local shop first (having purchased an older nearby shop) and then went into the e-business. Husband and wife team at first. Very interesting and nice folks. They still did repairs and sold items in their shop. I chatted with them once, surprised at the fact that their online presence made one think of a huge company. They had an interesting business model. They had no warehouse, rather their website was directly connected to all the various suppliers. I believe the owners investigated and learned alot about how to connect the databases. When you placed an order the parts were sent to Niagara from all the suppliers, and the availability was directly reflected in their website. They probably had large orders from the various suppliers all the time. They then re-packaged it to send out or set it aside in a box in the case of local pickup like me. There were a bunch of people re-packing and shipping.
Registered User
Well, that's what soured me on them. When you say an item is "in stock" it really should be in stock. When they didn't take down an Amazon item after they cancelled my order, I was disappointed.
Quoted: 111 Post(s)
Liked 5 Times
When sitting on a pile of unsold inventory, it is easier to lose money than sell inventory. The goal of the most savvy online retailers today is to never have anything "in stock".
Liked 4,508 Times
Just in time would imply stocking just slightly more than one would expect to sell in a given time frame.
Just about in time means you're constantly needing to restock or manufacture to fulfill orders.
I have the tendency to like to buy a couple of things at a time. Likely what those stocking both love, and dread, as my impact on inventory can be unpredictable.
But, if I need qty 5, and a store stocks qty 1 or qty 2, then I'm ether looking elsewhere, or heading home with a half an order, and looking elsewhere.
On occasion I'll pass up E-Bay vendors because I can't buy 5 of one thing, and 1 of another.
Drop shipping has fallen out of favor also due to inventory and other issues.
Niagara must have had a dang good wholesaler, but never quite had the stock to do their own fulfillment for most things, especially if an order went slightly out of the ordinary.
In general, if they could do one day for product acquisition, and one day for shipping, they could do OK. Unless something hit differently. Perhaps they would hit a holiday, so a Thursday shipment becomes a Wednesday of next week shipment.
Randomhead
Liked 3,696 Times
They had stuff that was apparently surplus or overstocks for good prices. But the great majority of their items were from QBP and sold at the same retail price that my LBS offers. But since my LBS gives me a good discount and doesn't charge me shipping on QBP items, I was far better off going there.
I stopped buying from them after I found out they saved a cookie containing my credit card number in plain text on my computer.
WGB
Liked 2,334 Times
I drove by to see if there was any movement there. No cars and no one inside. I left a note asking how they were selling off their inventory.
The online motorcycle store I worked for only stocked high volume items. Certain batteries, manuals, fenders, etc. The rest of the stuff ordered was drop shipped direct from the supplier or received from the supplier overnight and reshipped to the customer. It was a serious nightmare to run, but turned a lot of money, albeit very low profit margin.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
The retail store is no longer open and the website is "Down for maintenance". Thanks for the images.
