Travel cover
Bikes: FX 3 Disc
Quoted: 9 Post(s)
Travel cover
I bought a hitch mounted platform rack for my SUV and I plan on bringing my new bicycle to various places to ride. I would like to get a cover for the bicycle so that it does get dirty and damaged while mounted to the back of my SUV.
What is the best cover to get?
Is there anything that I should be careful to avoid?
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,437 Times
There are elastic type covers that can protect the bike but I am not sure how much coverage they would provide
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
If you mean dirt on the bike from having it on the car, there is almost none. The car blocks the wind and dirt mostly. If you're afraid of scratching your bike with another bike on the rack with it, get some foam pipe insulation to put on the frame or any contact points. I use Velcro to keep the foam in place sometimes. On the car trips to another place to ride I also have a couple of beater (old, cheap) bikes use and to keep the expensive bikes home.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I have never used a cover. Sometimes the bikes get a little dirty. No big deal. It happens when you ride them, too.
Sounds like you need to partially disassemble the bike and put it in the trunk.
Bikes: 2 many
Liked 323 Times
Good point. With quick release wheels in a few seconds you can take off both wheels. Put the frame in the vehicle use a blanket for padding and put the wheels next to or on top of the frame.
Let's Ride!
Quoted: 327 Post(s)
Liked 37 Times
Quoted: 18415 Post(s)
Liked 15,546 Times
Blue tarp add more grommets
(to actually stay clean , tow a cargo trailer with your stuff locked inside it , It will have its own lights , and licence plate)
Advanced Slacker
Liked 2,537 Times
A very small number of unusually neurotic people do.
Just keep your chain lubed and it will be fine. I have driven tens of thousands of miles with uncovered bikes on the back of my car and the only time I had issues with anything being adversely affected by dirt, water, or even salt was when I did not have my chain lubed.
I do thoroughly wash off the bike as soon as possible if I drive through salt... but that is very rare.
Bikes: 2 many
Liked 323 Times
Put your bike on the rack and walk away from the car, crouch down to where your eyes would be abut the same height as a driver, and look to see if a cover would block the taillights or the license plate. If it would, there's no reason to think about a cover.
Quoted: 643 Post(s)
Liked 1,526 Times
A loose fitting cover will do more damage than no cover at all as the wind whips it against the paint finish continuously for however long your driving. There is a company called Geza Gear that makes stretch covers for motorcycles being hauled and those work great. If you're really hot on a cover, you may be able to get them to make something for a bike but you'd need to make sure the cover didn't block your taillights as mentioned earlier.
Personally don't think there is much risk having it uncovered. Maybe it gets a little dirty but so does riding it.
Liked 15,546 Times
Yeah. The risk management side of me can envision a lawsuit stemming from a crash caused when an improperly secured cover blows off and blinds a trailing motorist. "You should have warned people not to use covers."
Bikes: 2 many
Liked 323 Times
Maybe the bike covers don't block the lights or the plate If you use a coupe of bags and cover maybe just the drive train and the seat?
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
If you are worried about dirt or damage then don't keep the bike outside.
Return the rack. Put the bike inside the SUV. That's all.
-Tim-
-Tim-
Let's Ride!
Quoted: 327 Post(s)
Liked 37 Times
sorry i did not finish my thought. It rained the whole way back. I did not cover it at all. It rained so hard that the tires had water in them! I dryed the bike when i got home and lubed the chain all is good.
