anyone ever add POI's to a Garmin Edge?
Old 02-21-19, 10:38 AM
unterhausen
Randomhead
Liked 3,684 Times in 2,508 Posts
As part of my PBP bakery project, I want to see them on the map.
unterhausen is offline
Old 02-22-19, 02:06 PM
njkayaker
Quoted: 4242 Post(s)
Liked 1,342 Times in 931 Posts
I've added locations (that's fairly easy to do).
I created the list of locations (POIs) as waypoints in Garmin BaseCamp and exported the list as a GPX file. Copy that to the \Garmin\NewFiles.
You might want to verify that the symbols you want to use work on the device.
njkayaker is offline
Old 02-22-19, 02:27 PM
unterhausen
Randomhead
Thanks, does that effectively add them to the route? I have found a number of bakeries just off route and I don't really want to go there if I don't reach that point when they are likely to be open. I figure the ones off-route are less likely to be stripped bare. They close when that happens anyway.
Old 02-22-19, 04:42 PM
njkayaker
Locations are separate from the route. They show up on the map and you can use a location as a navigation target (select it to have the Garmin compute a route to it).
johngwheeler
Road Cycling
0
09-19-17 10:20 PM
iab
Road Cycling
42
02-24-15 09:27 PM
kenmcchord
4
06-21-12 01:14 PM
JustinNY
Road Cycling
34
06-14-12 01:09 PM
notwist
3
12-08-11 07:12 AM
