Is this tire ruined from my trainer?
Quoted: 94 Post(s)
Not sure why my trainer did this to my tire today. Tire was pretty new and haven't used trainer in 6 months. Tire pressure was 95
The bike was properly mounted and the rear wheel was set with the proper 2 clicks.
Do I have to replace this tire or is it safe to ride on the street?
Quoted: 1975 Post(s)
Liked 232 Times
When did you notice this? Possibly the roller overheated and melted the tire when you stopped on 1 spot. Not uncommon with trainers with small mass rollers that dissipate heat poorly. Tire is probably okay to ride on the real although you might have a lump when rolling.
Quoted: 20810 Post(s)
Liked 9,456 Times
That's weird, but I wouldn't necessarily say that it's ruined; if you look at the wear indicator dot towards the lower right corner, that patch doesn't look any deeper. I would probably take it out for a ride and see if the patch is noticeable/bothersome.
Quoted: 2952 Post(s)
Liked 3,106 Times
Likes For caloso:
Should Be More Popular
Quoted: 22597 Post(s)
Liked 8,925 Times
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I wouldn't ride a tire with that kind of damage.
Likes For TimothyH:
I don't mess with things that could cause horrible injury. I'd buy a new tire immediately.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4389 Post(s)
Liked 3,016 Times
I wouldn't generally use a tire on a trainer and then ride it on the road. Apart from he seeming damage to your tire, with time, the trainer wears a severe flattening into most tires. Some people buy trainer-specific tires. I just use old tires that are no longer road-worthy.
To make it easier to swap back and forth between the trainer and outdoors, I use an old rear wheel for the trainer, so all I have to do is swap wheels. The only real expense was buying an extra cassette for that wheel.
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
I have lost count of the number of GP4000's I have seen have heat issues on the trainers here in the training center. It's a really crappy trainer tire.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Quoted: 18883 Post(s)
Liked 10,646 Times
I wouldn't either. It'll probably roll lumpy, and it's probably safe but might not be. And for context, I'm lucky to have my job, and the $ for one tire is worth the ride quality and peace of mind to me. I can understand how other people can weigh things differently though.
I eat carbide.
Liked 1,306 Times
i understand everyone's situation is different but for me life is too short to ride on crappy tires.
Quoted: 4717 Post(s)
Liked 1,882 Times
That tire costs about $40. If it causes a crash, how much time away from work might that be?
Likes For noodle soup:
Quoted: 4560 Post(s)
Liked 2,802 Times
I use Conti Ultra Sport II on my road bikes, including on the Cycleops trainer. No problems, even with intervals and sprints that cause a little dragging on the rollers if I don't build up speed gradually enough. Good, tough, grippy enough for my purposes, reasonably low rolling resistance and cheap. Different rubber compound than the GP4ks tho', so maybe that's a factor.
Its not the rubber holding the tire together, its the casing. - > Imo, the tire is fine unless the "injury" is all the way through the rubber thread. It may be a bit bumpy tho. Im betting it happened because you used the brake.
- Soli Deo Gloria -
Liked 736 Times
How are these things made?
I think it was @Doge who said to never use a tire with glued tread on a trainer and used Corsa as an example.
Are the treads glued to the casing on higher end tires?
-Tim-
-Tim-
Quoted: 1186 Post(s)
Liked 289 Times
Bikes: 1979 Raleigh Team 753
Quoted: 3375 Post(s)
Liked 371 Times
-Tim-
-Tim-
Trainer have rollers that cause the tire to deform quite a bit more than normal flat road riding. If riding on rollers the deformation is part of the resistance. Anyway keep bending a glued on case back and forth and the tread will be more prone to come off. A GP4000 - eh, don't know. That is a great clincher, and as a pure trainer tire, I wouldn't use it, but for warming up and periodic use seems fine. My wife used a GP4000 on her rear solely for about 2-3 hours/week on a 2.5" roller. The tire came apart about a decade after first use. That is not so bad.
Quoted: 94 Post(s)
I'm curious what type of trainer you are using and the diameter of the roller contacting the tire. I've always used GP4000s on a KK trainer and have never observed any tire damage. The reports of tire-eating trainers I've seen usually indicate a small diameter tire roller.
i haven't used my trainer in 6 months so I'm not sure what went wrong. I don't remember using the brakes but i don't see what else could have caused this.
Quoted: 1814 Post(s)
Liked 923 Times
It looks like a skid patch to me.
Maybe it was there & the trainer buffed it up to be more noticeable.
Man, chicken little is alive and well around here!
