American Classic Hubs - Bearing Replacement ?
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
I bought a used set of American Classic CR-420 wheels and the 15mm rear hub bearings seem pretty rough to me. There's the friction from the seals, but I can also feel roughness when I turn them, similar to the feeling of loose ball hubs that are too tight. The front hub seems ok.
I started to take them apart, but it doesn't look like there's any adjustment to be made ... am I wrong ?
I'm used to loose bearing hubs and being able to adjust them perfectly, but am at a loss for what to do here .... Any ideas about replacing the bearings ? Cost, availability, specifc tool needed ?
I've emailed American Classic, but no reply yet.
Riding to fill the void
Bikes: 1998 Kona Caldera
The American Classic hubs use cartridge bearings. There are four in the rear hub; replacement requires a full hub overhaul. It's a good job for your favorite pro wrench to take care of. Bearings can be a bit pricey, I get mine direct from Boca Bearings (bocabearings.com) and got a good sale price on ceramic balls in steel races...
Super Moderator
Liked 927 Times
I'm looking at Boca Bearings. How did you figure out which bearings are the correct ones ?
I do all my own work, so I don't mind trying something new. Just not sure if I need special tools for this ?
Super Moderator
Liked 927 Times
Maybe these are the right ones:
#BRK-014C-YS (2nd item on this page)
https://www.bocabearings.com/main1.as...earchkit&cat=9
P.S. Thanks, you guys have been more help than American Classic support...
A little North of Hell
Quoted: 71 Post(s)
boca
non-ceramic hybrid green seal bearings are little less expensive.
https://www.bocabearings.com/main1.as...&id=*BRK-014GS
https://www.bocabearings.com/main1.as...d=*BRK-014C-YS
