how to measure inseam for cycling
Quoted: 426 Post(s)
Liked 274 Times
A lot of bike brands as for height and inseam when sizing a bike.
Some sites say from from crotch to floor. While others say to your ankle. That's going to give two very different answers.
Sunshine
Quoted: 11031 Post(s)
Liked 7,576 Times
I have never heard the ankle one.
Odd.
Odd.
Quoted: 7666 Post(s)
Liked 3,532 Times
Likes For Maelochs:
Advocatus Diaboli
Quoted: 4759 Post(s)
Liked 1,539 Times
Am I alone? My jeans are typically always 1" longer nominally than my actual
Liked 3,532 Times
Of course, nowadays some guys wear their pants below their buttocks. I have no idea how to measure "clothing" inseam in those cases. Happily, I only need my actual inseam to ride a bike.
Likes For Maelochs:
Liked 3,532 Times
Yeah ... . try as I might I cannot get an accurate measurement of my bike's inseam.
Likes For Maelochs:
Over the hill
Quoted: 1003 Post(s)
Liked 1,222 Times
Inseam alone is not a very good way to size a bike. The fit calculator Maelochs linked to is a much better way.
It's like riding a bicycle
Quoted: 3980 Post(s)
Liked 7,430 Times
Quoted: 511 Post(s)
Liked 646 Times
Please provide a link to the site that says to measure from your ankle. Nobody does this and in over 50 years in this racket, I've never heard of it. So a link to that reference would be interesting so we can figure out what kind of nonsense they are spouting.
Quoted: 426 Post(s)
Liked 274 Times
google "how to measur inseam"
most results come back with ankle or where your pant ends.
I always thought it was crotch to floor.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,571 Times
google "how to measure inseam"
Likes For ThermionicScott:
Klaatu..Verata..Necktie?
Quoted: 10493 Post(s)
Liked 12,021 Times
Ummmm .... well. "Actual" inseam is from crotch to floor. "Clothing" inseam is usually shorter as pants are supposed to "break" on the top of the foot and come down to about an inch above the floor in the back, so as not to drag on the ground. if your jeans are an inch longer than your actual inseam you are rolling your cuffs or walking on them.
Likes For genejockey:
Over the hill
Liked 1,222 Times
Likes For urbanknight:
Over the hill
Liked 1,222 Times
But if you have always measured it from the floor, what made you suddenly google it recently?
Quoted: 426 Post(s)
Liked 274 Times
I injured both of knees in motorcycle accident in 2016. 2017 had surgery on both knees. I can hike ok, I still can't run. If I putz around on bike at 100 watts on flat ground I can ride all day. Of course bike rides are not putzing around in zone 1 all day. I have been reading & watching lot of stuff on knee pain while biking. Some stuff comes back as q-factor but I can't find anything on how to measure what yours should be. I see lot of stuff on bike fit, what size bike you should ride and shorter cranks.
https://www.applemanbicycles.com/res...-crank-length/
If I was to believe this ^^^^^ I should be riding on 155mm cranksets. I have been thinking of getting a bike fit, and shorter cranks to see if that helps.
Over the hill
Liked 1,222 Times
Advocatus Diaboli
Liked 1,539 Times
[Oh, wait...sounds like you're trying to size your frame, my bad...]
Liked 3,532 Times
As I understand it, with shorter cranks the rider spins faster against marginally less leverage and with marginally less force (since the force is spread over more repetitions) so hsorter cranks are good for people who have tender knees.
"Q" factor is .... well, if you are running a triple crank or something, or riding a fat bike, it might be an issue. Basically you don't want the pedals to be wider than your hips? Most bikes are pretty similar .... two chain rings or even three, most are not that wide. Unless you have some specialty bike, I wouldn't even worry about it.
The most important consideration, IMO, is bike fit---and this means fitting the bike's contact points, which determine your riding position, to your body and riding style.
Obviously there can only be rules of thumb, because each of us has a specific body. if I had bad knees I would probably be most interested in not hyper-extending---which is also my main consideration with my not too bad knees. Hyperextension Hurts and causes lasting damage. But you also have to look at where your feet hit the pedals (most people suggest the ball of the foot or a little back, I think) and how far your feet are ahead of seat ....
if your legs don't extend enough, it pus more strain on your knees .... or more accurately (and in terms of physics or physiognomy, none of this is really accurate anyway) you won't be using your legs as efficiently if you don't extend them the proper amount ... More power than the motion can transmit, which means more strain on the knees. But, given that you might be riding with less than maximum power to spare your knees, a little shorter might be better. You can and will almost certainly have to adjust your position many, many times to dial it in.
Also ... putzing around in Zone 1 Is cycling. Maybe not what you want, but if you enjoy it, you do.
It is a ballpark measure to get you within a couple of sizes for a start. Ultimately it depends on how you feel on the bike in a normal riding position and posture. It is also going to be different for a mountain bike as compared to a road bike or a touring bicycle. Most bikes now come in half as many sizes than was the case with centimeter frame sizing in the past. It has become a XS, S, M, L, or XL size frame.
For men it is more important to be able to stand over the top tube with feet on the ground to protect vulnerable parts of the body. There is a tendency for men to get the smallest frame that will "fit" as a result, even if that requires very long seat tubes and stems.
Liked 7,430 Times
