Wet, stink clothes from riding to work the rain
Bikes: Specialized Allez Sport
Quoted: 12 Post(s)
So it'd been rain and more rain here on the East Coast. I don't mind wet clothes but having them wet and smelly all day around the office or even in the locker is starting to get to me. Any else has this issue and how do you deal with it?
My bike doubles as a clothes and towels drying rack during the day. It's locked outside, but under a roof, so on high humidity or rainy days things may not completely dry out. Usually everything is completely dry, though. It's better than drying stuff at my desk. Never had anyone mess with it, but if that was an issue, I'd have to come up with another solution. Shoes stay inside with me regardless, as they are a bit more expensive.
Bikes: Trek FX 7.3
Do you have a shower at your destination? If so, you can do what I do and wash the clothes in the shower. I forgot an extra pair of socks for my ride home and just used the soap in the shower, scrubbed and rinse. I dried them out on my fan underneath my desk during the day. This could solve the smelly problem, and just hang dry the other clothes.
ouate de phoque
Bikes: Bianchi, Nakamura,Opus
I hang everything to dry in the break room. no one ever complained.
Quoted: 2604 Post(s)
Liked 1,928 Times
Shoes are the worst, they go next to the computer to dry out.
I usually decorate my cube wall with bike jersey on a hanger, and bibs draped over the jersey. They'll usually dry out during the work day, and since they started the day clean, they don't stink too bad when dry.
Bikes: 3 good used ones
Quoted: 83 Post(s)
You need different clothes. My cycling clothes dry within an hour, no smell. Ultra-lightweight T-shirt made of water absorbent material, cycling shorts and water-wicking socks made of multiple materials. All are designed to pass water not retain it.
Quoted: 12 Post(s)
My clothes have all of those properties but you are kidding yourself that you think they don't smell.
I have one of those valet stand thingies to use everyday, and then on heavy rain days when everything is soaked thorugh and dripping I resort to a combination of the boot and glove dryer for some pieces and a regular mini-space heater under my desk for other pieces (draping a jersey, for example, over an empty 3 ring binder to allow the warm air to flow under and through it until dry). Doesn't eliminate oder while drying but does speed up the process from an all day thing with damp clothes to put back on to an hour or so and dry clothes for the return commute.
Longbikes Slipstream
Thunder Whisperer
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times
Wool doesn't retain odor...
Community guidelines
Center of the Universe
Bikes: Bianchi San Remo, Norvara Intrepid MTB , Softride Solo 700
Let me check in from rain central. He is right use light weight breathable clothing and you won't stink. Been doing it for 20 years now. The other thing is get a good set of rain gear, that way your clothes are dry when you get to work. All you have to do is dry your outer wear.
Matthew 6
Matthew 6
Bikes: Merlin Ti Frame, Marin Point Reyes
have gotten rained on for all but two days out of the last 14.
wicking sleeveless shirt, 4way stretch golf shorts over lightly padded tri shorts. i have a coat rack in my office and those items usually dry by the end of an eight hour day. and, if still damp, i know i'm probably just going to get wet again, so.....
feet were a problem until i bought a pair of waterproof mtb boots (Sidi Diablo. used, could never pay that much for new). thin Smartwool socks with them and only the tops of the socks get wet (and also dry out by the end of the day).
i tried rain gear, but preferred being soaked to sweating.
Quoted: 12 Post(s)
Bikes: cyclotank
Greetings from Central Florida. Rain or shine, one still arrives to the destination soaking wet - with sweat. Tight weave of technical fabrics retains stink. Wash riding clothes after each use with regular undies and periodically with either oxy-clean or Borax. These two disinfect the fabric and your clothes will be fresh for another 5-6 uses. Since these two chemicals have rather high pH, make sure you rinse your laundry very well. Line dry.
I have three changes of summer jerseys and shorts and three changes of winter tights and long sleeve base layers. Do not worry about ruining your technical clothes in the washer, if they can not stand to regular cycle, they do not belong on your back.
Ride safe
Ride safe
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
My clothes are pretty smelly normally, actually less so when it rains, I guess the sweat gets partially washed out during the ride. I would like to find some nice wool jerseys but they're too darned expensive.
Work: the 8 hours that separates bike rides.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
I do have that issue and they don't dry out in the locker. I won't bring wet riding clothes up to the office though just in case they do start to stink. Normally they don't, not if you start with clean riding clothes every morning.
Yesterday I was so reluctant to put on a wet jersey - even though I knew I was going right back out into the rain - that I took a hair dryer to it.
Rain cape, splats, gators, rain suit, jacket, fenders. "An ounce of prevention..."
Señior Member
Quoted: 446 Post(s)
Liked 8 Times
For me that about quadruples the stink. The rain washes out the sweat. If I wear rain gear when it's warm, I get twice the sweat. Though people who have seen me after a normal ride would probably say that it's not possible to sweat twice as much as I do.
Dirty Schwinn-Lover
Bikes: '11 & '13 Schwinn Racers, Takara (Kent) Kabuto, '11 Gary Fisher (Trek) Marlin SS 29er, Schwinn Sanctuary Cruiser, '11 Schwinn Sid, Firmstrong Chief 3-spd, '10 Schwinn Corvette
@hyhuu, I'm not sure what your office situation is, but I'm lucky to have a "workshop" (or as I call it, the PC Graveyard) behind my office where I park my bike. On [Summer] days when I arrive smelling of sweat, I use a wire hanger and improvise a sturdy spot to hang up my jersey while I fan it out with this little puppy. If you're crammed into cubicles with lots of other folks close by, this obviously might not work for you. I also second alan s's suggestion about using your bike as a drying rack, depending on where it's stored.
Perhaps you can elaborate a little more on your logistical situation at work?
◘ Where do you park your bike?
◘ How close to others do you work/is your bike parked/clothing stored?
◘ Does your place of business allow you to keep a fan close by?
◘ Are there showers where you work?
Liked 1,928 Times
Señior Member
Quoted: 446 Post(s)
Liked 8 Times
I stink even when I'm riding with a pair of baggy shorts and a poly alert shirt. I guess I just have sweat that microbes really dig.
