Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Knee pain from switching bikes
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 11-17-19, 10:55 PM
OldCruiser
Bikes: Most of my bikes are Single Speed Conversions
Quoted: 267 Post(s)
Liked 3,067 Times in 1,015 Posts
Can going from a Standard framed bike to a crank forward bike cause knee pain ?
OldCruiser is offline
Old 11-24-19, 10:48 PM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 3889 Post(s)
Liked 1,938 Times in 1,383 Posts
Most any change can cause pain. I don't think a simple thing like that should be a big issue - look at recumbent riders for example. More likely it's either poor fit or poor technique.
Results matter
Carbonfiberboy is online now
Old 11-25-19, 10:13 PM
OldCruiser
Quoted: 267 Post(s)
Thanks for the reply .
After researching , I was so worried after about having my saddles too low , I think I’ve got them too high . Especially on the crank forward bikes . I should be able to put both feet down when I stop , I can’t where I have them right now . I’ve bought some quick release seat clamps that will allow me to adjust while out riding .
I’ll be lowering them and give it a try .
Old 11-26-19, 09:46 AM
Carbonfiberboy
I haven't ridden a crank forward bike, but I suspect that the heel-on-pedal method should work for setting saddle height. With your butt planted on the saddle where it normally is, put one heel on a pedal so that your lower leg bones point right at the pedal axle. With that knee totally locked out, your heel should just barely touch the pedal when it's furthest away from you. You can check this out on the road, pedaling normally, then putting one heel on a pedal and continuing to pedal. If you lose contact with the pedal, saddle is too high. If there's pressure on the pedal there, it's too low. One has to be sort of coasting and soft-pedaling to do this, as it's a bit weird to completely lock the knee at the bottom of the stroke.
Results matter
Old 11-26-19, 11:56 AM
OldCruiser
Quoted: 267 Post(s)
Installed my new seat clamps on three of my bikes this morning and lowered my saddles a little . On my Rockhopper I had to cut the seatpost about 3/4” to get it lowered , it was already bottomed out in the seat tube .
Then I took each one out for a spin .
After seven miles between them , which is my average ride distance , my knees feel better than they did two days ago when I rode my Roll 6.5 miles . Hopefully I’ve solved my issue and once the knees get better I can get back to increasing my distance.
