I deflate my bike tires when trying to add air.. Why does this happen?
Bikes: purchasing;
Its been 30+ years since I owned a bike, Don't recall filling tires ever was a problem.
But when I now try to fill the tires of my new Specialized bike with a Joe Blow manual pump, I find that air deflates from the tire and it takes me several attempts until I am successful.
I actually ruined one tire when trying to fill it.I broke off the fragile seeming mobile end of the tire valve (the needle-like extension which is inserted in the pump "spigot")
Getting ready to ride is anxiety provoking.
I am afraid to attach the pump to the tire lest I again break something. A mechanic at my local bike shop told me pump spigot may be overly tight and that will ease as I use the pump.
Is that true? Is that the problem?
Thunder Whisperer
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times
Which valve stems do you have- Presta or Schrader (like the ones found on cars)?
Community guidelines
Bikes: '17 Access Old Turnpike Gravel bike, '14 Trek 1.1, '13 Cannondale CAAD 10, '98 CAD 2, R300
Quoted: 1571 Post(s)
Liked 12 Times
Place the stem at the six O'clock position when filling the tire with air. Maybe do a practice run or two... sit right down on the floor where you can actually see what your doing. Get a good idea of how much stem needs to go into the "spigot" part. Familiarity will end the anxiety..... once you get it figured out... you'll have it forever.
Quoted: 1572 Post(s)
Liked 644 Times
One other trick - "burp" your inner tube before inflating.
It sounds counter productive to let out a little air before reinflating your tire but it unsticks the presta valve and makes it much easier to pump up.
Life is good
Bikes: 2018 Lynskey Helix Pro
Quoted: 522 Post(s)
Liked 10 Times
+1 on the "burping". Always works for me.
When I first moved over here I didn't have a clue how the Presta valves worked. I let all the air out the tire and had to walk the bike to the bike shop.
YouTube has helped me many times to learn how to accomplish something. I always carry an valve adapter with me (even when I'm not biking).
Bikes: purchasing;
Thank you- don't have the broken tube stem.But do have veg oil.
Appreciate the tip on 6:00 PM position.
After reading posts on Bike Forum, I googled, found some YouTube videos and I learned (Duh!) that I have Presta valves on my tires - I had no idea there were two types of valves.AND I learned that I am supposed to screw shut the mobile tip at the end of the Presta Valve. One reason I may have ruined my one tube is that I never knew to shut it and so it is no wonder i broke it off.
Gee-I paid what for me is a small fortune for the bike and not one bit of information about maintenance.
Thank you.This BikeForum is helpful Gad I found it
Bikes: purchasing;
Thanks to posts here i learned there are two kinds of valves related to the type of tire and tire rim. I have the fussier Presta Valve. I now know I need to screw shut the little mobile end piece when done filling the air.
I was clueless.
I recalled going to Gas Stations (I guess they call them service stations these days), pulling up to the air pump, attaching to my tires, hearing a BLAAST noise and the tire was filled.
Question: Since Presta valves do not allow me to use the air hoses most bike shops leave out side their doors in biking season , should I purchase Schrader adapters? I read these are available reasonably priced and would allow me to fill at a bike shop if need be?
I was clueless.
Bikes: purchasing;
Valve adapter? to make the Presta valves look and act like Schrader valves?
I am so new I not know what to carry with me ( I ride in the city, in our parks on special bike paths)or am now beginning to commute using my bike. I look for streets that have the special narrow bike lanes painted on the roadway.
Quoted: 5234 Post(s)
Liked 3,609 Times
if you get totally frustrated after more attempts you can always drill them out and replace the tubes with long stemmed shrader tubes. it's a one time hassle for easier inflating for the lifetime of the bike. lots of folks have no issue with the prestas so I'm not suggesting you give up on them yet
<guess> (not understanding your applied terminology , eg spigots =faucets for water to me , etc)
The removable core presta and those with extensions for the very tall rims that are stylish now, unscrew at the wrong spot.
ask your Bike shop for tubes without removable cores if they do unscrew and let the air out.
or get that schrader valve rim drilling done .
Quoted: 1514 Post(s)
Liked 735 Times
If you get a presta-to-schrader adapter, bear in mind that not all service station compressors will inflate to 100+ psi. Sometimes they'll leave you with less air than you started. It's best to get a floor pump for home use. A good pump these days will come with a dual head and will work with both presta and schrader.
As an in-between solution, I have a roadside pump that plugs into the car's aux output (aka cigarette lighter socket.) It'll do 200+ psi, but it pumps slow enough that I don't have to worry about exploding my tire by mistake. It has a schrader head, so an adapter is required.
Liked 6 Times
OP, I don't think I have had a wheel with Schrader tube in over twenty five/thirty years, but I still carry a little Presta to Schrader adapter in my saddle bag for unforeseen emergencies. You never know when you just might need a gas station air pump.
Bikes: purchasing;
My JoeBlow pump, a floor pump, also has the dual heads. It works very well; my tires recommend 110psi and the JoeBlow does it ,
The fragility of the Presta Valve has been concerning but I will try all the tips given here (6:00 position,veg oil or gasoline greasing the pump clamp opening,I understand now that the air release prior to filling is not an error.
When I go to inflate my tire (with a Presta valve), I simply rotate the stem, the top part of the valve, counterclockwise until air is released when I press that valve in. At that point I mount an adapter over that stem that allows me to use a general purpose bike pump.
The adapter has a lip that the pump grabs from above. It's probably easier to see than describe.
Now that I know how this valve works, it's not an issue ... as long as I have an adapter with me.
Bikes: '09 Trek 2.1 * '75 Sekine * 2010 Raleigh Talus 8.0 * '90 Giant Mtb * Raleigh M20 * Fuji Nevada mtb
FB4K - Every October we wrench on donated bikes. Every December, a few thousand kids get bikes for Christmas. For many, it is their first bike, ever. Every bike, new and used, was donated, built, cleaned and repaired. Check us out on FaceBook: FB4K.
Disclaimer: 99% of what I know about cycling I learned on BF. That would make, ummm, 1% experience. And a lot of posts.
Quoted: 1366 Post(s)
Liked 1,689 Times
My road bike has presta valves and I keep a shrader adapter on the rear and got in the habit of using that to inflate the tires. I like how the presta valves screw shut and have a threaded ring to tighten against the rim.
Liked 735 Times
Presta valves aren't quite as fragile as they look. I've never broken one. One thing I do, though, is to make sure I'm pulling the chuck straight off it rather than just yanking at an angle. It's easier on the pump head that way, too.
Statistically .. Saying most is a personal guess unless you actually do a survey of several thousand people in all parts of the world.
you can really only assert you do , and thats fine ..
Cathedral City, CA
Bikes: 2016 RITCHEY BreakAway (full Chorus 11), 2005 Ritchey BreakAway (full Chorus 11, STOLEN), 2001 Gary Fisher Tassajara mountain bike (sold), 2004 Giant TRC 2 road bike (sold)
Quoted: 8 Post(s)
There are books on the market. One that I remember is by Leonard Zinn, who has a bike building business and writes tech articles for Velo magazine.
Quoted: 75 Post(s)
I have Zinn and the Big Blue Book and both are good. The websites for both of these also have good information. Sheldon Brown is still my go-to.
Quoted: 3352 Post(s)
Liked 1,056 Times
This is why I favor presta valves. When the chuck is removed, a presta valve immediately blows shut without much air being lost. A schrader stem OTOH has the valve held open for a certain amount of time by the pump chuck as the chuck is removed, and causes more loss of air.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,203 Times
What he's saying is as people gain experience, they learn the nut doesn't do anything useful and can actually cause harm.
You are speaking just for your self,, I have not had that issue .. the royal We is assuming too much
