Cannondale 2.8 Shifter Boss Removal?
Old 09-15-19, 06:17 AM
Hudson308
Mr. Anachronism
Hudson308's Avatar
Quoted: 526 Post(s)
Liked 256 Times in 165 Posts
Does anyone know if the shifter bosses are removable on this '93 Cannondale R900? The paint is beyond touchup, and I'd like to have it powdercoated. The bosses appear to be made of cast potmetal or plastic.
Hudson308 is offline
Old 09-15-19, 06:22 AM
Pompiere
Pompiere's Avatar
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 523 Post(s)
Liked 968 Times in 507 Posts
Someone who knows more will surely have details, but I think those have a threaded shaft that goes through the down tube, connecting the left and right sides.
Pompiere is offline
Likes For Pompiere:
Old 09-15-19, 07:05 AM
Bianchigirll
Bianchi Goddess
Bianchigirll's Avatar
Quoted: 2924 Post(s)
Liked 2,916 Times in 1,488 Posts
Yes there a threaded rod/shaft that is fixed to and extends from the right shifter to the left shifter.
OP do you have the black plastic piece that came off the left boss?
You should be able to unscrew the brass portion, of the left boss, with an...an... 8mm IIRC but BECAREFUL. I'd dose it with a little penetration oil first. These things are prone to breaking especially the fixed right side snapping off.
Sugar "Kane" Kowalczyk
Bianchigirll is offline
Old 09-15-19, 07:22 AM
Depaso
Quoted: 14 Post(s)
Liked 4 Times in 3 Posts
Depaso is offline
Old 09-15-19, 07:53 AM
cudak888
www.theheadbadge.com
cudak888's Avatar
Quoted: 2412 Post(s)
Liked 4,374 Times in 2,086 Posts
From the looks of it, the left side has already been unscrewed a bit. The flats are not parallel with the downtube.
The black squared off washer is missing as well.
-Kurt
cudak888 is offline
Old 09-15-19, 07:27 PM
Hudson308
Mr. Anachronism
Hudson308's Avatar
Quoted: 526 Post(s)
Originally Posted by Depaso
Perfect... thanks so much! Yes, I do have the the black plastic washer. The bike came with Tri-color brifters, so there were cable stops bolted to the bosses.
I'll see if I can coax these off without damage.
Old 06-09-22, 01:05 PM
Sonofamechanic
Go Ride!
Bikes: Klein Quantum Pro, Klein Attitude, Azuki SS, Merckx AXM, Klein Quantum Race, Klein Quantum
Quoted: 109 Post(s)
Liked 154 Times in 87 Posts
removal of down tube shifter boss — aluminum frame
(…this is an older thread but thought it better to add details to this one rather than start a new one):
Had to remove down tube shifter bosses off of an aluminum frame (Klein Quantum) and similar to above they screwed out fairly easily—in this case both sides were threaded but I started on the drive side of the bike based on Cannondales I’d seen before. Once loose I could easily pop loose the base plates.
Klein Quantum shifter boss removal
Sonofamechanic is offline
Likes For Sonofamechanic:
sjpitts
Classic & Vintage
16
12-13-20 11:14 PM
jodphoto
Bicycle Mechanics
11
06-23-19 11:12 AM
mkeller234
Classic & Vintage
53
03-27-19 07:17 PM
Cache
Classic & Vintage
5
07-25-12 08:23 PM
