Racer Tech Thread
#3301
Bikes: 1979 Raleigh Team 753
Quoted: 3375 Post(s)
Liked 371 Times
There is no rule that I am aware of, only that your bar end must be plugged. However as I have explained in the past, if a referee feels that it gives the rider an unfair advantage or is a safety issue, they can ask that it be removed.
I have a similar mirror on both of my bikes now, an Italian one that has a glass lens. It goes under the bar tape though so it's not removable. It's been a game changer for me with my vision issues. It makes road riding, especially in a pace line, much safer.
Off topic rules, touchy feeling stuff:
I think but the "unfair advantage" is one that I have never seen enforced properly in cycling (or soccer). There may be an advantage, but it is not unfair if others have the same opportunity to legally use it. If they didn't know about it, or chose not to use it, or couldn't afford it, it does not become unfair, from a cycling rules perspective. I see affordability as an issue, just not for referees to deal with.
This is a @20 mirror.
#3303
Liked 371 Times
It does contribute to crunch.
#3304
As a long-time Specialized fan, I must say I'm pretty impressed with Trek. I did the "project 1" program where you can customize the bike. With the paint I picked (matte white, minimal logos), it only cost me $100 more than a standard "non-custom" frame. It took me less than 3 weeks to take delivery. You also have the opportunity to pick from different seatpost setback and handlebar width and reach (since there is no separate stem). I'm not sure whether that's part of buying a standard frame or not, but it's something you certainly want to get right. If your reach is off, you are looking at $600 to buy a new "stem" (ie complete handlebar). The bike is extremely well thought out and assembly was surprisingly easy with all the integrated stuff and internal cabling.
#3305
Liked 371 Times
Physics / Math experiance guessing required. Junior is doing this course: Stage 3 - Redlands Bicycle Classic - Redlands, CA
We are not tied to any brand. I'm not 100% UCI bike dimensions apply, but I think they do.
My thinking is focus on uphill as that is where most time will be spent. Downhill, much will be coasting as his junior gears can't pedal well 45mph +.
Bike is Shiv, 11spd.
Wheels...these are ready to ride weights, tires cassettes. I am avoiding brand name for current and ex sponsors although on our own here.
Rear:
Road wheel - 50mm profile, 25mm wide, 25mm silks 24h, super coaster ceramic bearings - 1020g
Vintage XWind tri-spoke 22 wide - 1270g
Modern disc flat - Ceramic bearing - 1350g
Modern disc not flat - 1660g
Front
Road wheel match to Rear - 20h - 800g
Modern Trispoke - 1140g
Vintage trispoke - 970g
I'm thinking double vintage tri-spoke or road wheels. Leaning double tri.
Thoughts?
Rear:
Front
Thoughts?
#3306
Rear:
Front
Thoughts?
Rear:
Front
Thoughts?
If not windy I'd go Rear : Modern disc flat Front : Vintage Trispoke
#3307
Liked 371 Times
Think I agree. Except that Vintage (Nibble Crosswind) handles wind very well. I just learned the road is bad, so wondering about wider profile tires.
Why have TTs on bad roads?
#3308
Quoted: 14 Post(s)
I normally don't worry much about crunching a frame, but I gave this one some thought before taking it out to the Driveway just 6 days after building it up. There were 2 wrecks in the first 5 minutes of the 3/4 race and I kept thinking "just get through week one and Murphy will go away after that". It was fine and I'm just not going to stress about it. I can't see having a bike like this and not racing it.
#3311
Bikes: Trek Madone, Blue Triad SL, Dixie Flyer BTB
Quoted: 160 Post(s)
Ouch, @grwoolf, that's a bummer. Hope you heal up soon and it's nothing too serious. You get checked for a concussion?
#3313
#3314
commu*ist spy
did it happen around the last incline right before you get into the turns? I heard something happened over there. I got taken down there once when some guy tried to bomb the corner through the track kerb, lost his wheel, and took 4 of us down with him.
depending on circumstances, I might be there next week.
#3315
I ended up in the Emergency room until 3am after my headache was getting more intense/dizzy and I was bleeding in my sinus cavity (sign of possible brain bleeding). After CT scan, etc., the dr. said it was just concussion/hematomas and some damage in the sinus cavity from the impact. I wasted a night and unknown $'s at the ER, but I figured the head stuff isn't something you want to mess with.
Funniest part was when I walked into the ER at midnight (holding my helmet), the guys asks "are you another one from the bike race"? I was their 3rd for the night.
#3316
commu*ist spy
Yep, that was the spot. I heard there were multiple wrecks at that same spot last night.
#3317
jeezus.... sorry to hear that... was this the 3/4? have to make note to be careful around that spot next time, because from what I remember, it's that incline right before the turns where people make attacks and try to pull away from the group, because it's pretty much all single file after that.
That is absolutely the place you need to have position, but our race was already getting strung out at that point and there was a lot of room for not many people. I don't think it was people fighting for position or getting squeezed, I assume it was a clipped wheel the way it happened.
#3318
#3319
commu*ist spy
No, 4/5, but I heard there was a wreck in the 3/4 there as well.
#3320
Liked 371 Times
I cropped a Strava segment and even though I move the start to the right, it still has the segment starting at 0 mph. The map shows correctly, but does not line up with the speed, HR.
So I just deleted it off Strava and Garmin.
Is there any simple cropping tool besides Strava?
#3321
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2636 Post(s)
Liked 3,150 Times
I'm glad that you're ok @grwoolf
"Your beauty is an aeroplane;
#3322
Liked 371 Times
This is the crop situation that is off.
First and Second have the same timeline, no matter where I start this thing.
And after the start crop the speed is the same.
#3323
Bikes: nagasawa, fuji track pro
Quoted: 26 Post(s)
W**** B*
Bikes: Several
Quoted: 103 Post(s)
My LBS has the eTap upgrade kit on 'pre-book' for me via QBP, but has no ETA.
Anyone know how that works? Are they guaranteed to get it? Is there a priority system or something? (This is a very very small shop)
SideNote: Anyone know how often SRAM is replenishing stock?
#3325
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
The last time I looked, QBP had an ETA of April 30 for eTap. My guess is that orders will be filled in the order they were received. I don't know of a "priority" system (which doesn't mean it doesn't exist). Another guess is that they won't have enough stock to fill all outstanding orders, but I'd like to be pleasantly surprised.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
