Totally Tubular
#376
My bikes became Vintage
#377
Quoted: 1854 Post(s)
Liked 661 Times
The tin contains at least 10 times what one tube contains. I know because I have them both on my shelf.
You can't compare 25 g of something with 0.25 liters of something to see which is bigger, unless you also talk about the density (mass per unit of volume) of that something, in this case, glue.
Oldyellr, I wish what you said was true, I wouldn't have needed to go to school.
#378
Forum Moderator
Quoted: 3085 Post(s)
Liked 6,566 Times
Thanks guys. I think I'm going to order 3 of the tubes.
In the metric system everything is very logical and orderly. (Doesn't the freezing point of water at 0° make more sense than 32° and the boiling point at 100° make more sense than 212°?) I spent my youth learning there are 12 inches in a foot, 3 feet in a yard, 220 yards in a furlong and 8 furlongs in a mile. In the metric system all you need to know is the meaning of prefixes like micro, milli, kilo, etc. Of course, I often have to convert those back to English to quantify them.
Of course, you might also say, "A pint's a pound the world around".
Actually, we who work with bikes have been exposed to the metric system longer than the average joe on the street.
#380
Liked 661 Times
Last time I bought a pint in London, UK it was about two pounds!
#381
Liked 661 Times
Don't take my number of 10 to the bank! I'm sitting at work knowing my tin and tubes are on my basement shelf in the Bike Junk Room. I found the price per tire install to be much lower for the tin of Vittoria, even at LBS prices. I just don't remember all the details.
I'm the kind of engineer who remembers how everything works, but doesn't memorize the details, at least not after I need them. I also think the Vittoria tin had a mass printed on teh label as well. If not, use Oldyellr's number of 0.7 g/milliliter (the 0.25 liter tin holds 175 grams, which is 7 tubes at 25 grams per tube). So I'm even wrong about the 10.
#382
Forum Moderator
Liked 6,566 Times
I did my first tire with a little more than a 1/2 tube, and it squeezed out all over the place and made a giant mess. That's why I cut back.
#384
Old fart
Quoted: 3582 Post(s)
Liked 3,395 Times
#385
Liked 661 Times
I can end one argument, at least. I just looked at my tin of Vittoria and a tube of Conti. The tube is marked 25 grams, and the can of Vittoria is marked 250 grams. No volume conversions are required.
#387
Liked 661 Times
10 to 1.
#389
Liked 661 Times
It flew under my radar, sorry!
#390
Bikes: 2000 Litespeed Classic, 1984 Schwinn LeTour, 1998 Gary Fisher Marlin, 1969 Hercules, 1977 Sekai 5000 Superlite, 1993 Koga-Myata TerraLiner, 2013 Trek Farley.
Hi – I know there is another tubulars thread running currently, but I’m posting here to avoid further hijacking that thread.
A friend was kind enough to give me some NOS tubulars he has no use for – some Vittoria Swallow Montello and a Vittoria Competition Formula Uno.
I have not found much of anything about them in a quick BF and web search (other than one BF member who had a bad experience with a Formula Uno tire).
Can anyone comment on these tires, from personal experience? Which are better tires, the Swallow Montello or the Competition Formula Uno? Any sense of where they fit in a Vittoria hierarchy?
Please, I’m looking for feedback only on these particular tires, since I have some in hand. Thanks!
#391
Liked 661 Times
#392
Good thought.
Vittoria Competition Formula Uno: made in Thailand.
Vittoria Swallow Montello: no markings found except "HS 021" and "8605."
Only a guess, but my hunch is they are low-end to mid-range tires for my commuter. They have the classic gum walls and black herringbone treads. My impression is, higher-end tires often have smooth/slick treads, sometimes in colors.
#393
Bikes: '86 AMBROSI / C RECORD. PINARELLO MONTELLO / FRAME, FORK.
"Doesn't the freezing point of water at 0° make more sense than 32° and the boiling point at 100° make more sense than 212°?" QUOTE.
Not really! ....... (LOL)
Regards,
J T
Regards,
J T
#394
Quoted: 101 Post(s)
Liked 49 Times
But "0" being way cold and "100" being too danged hot does make perfect sense.
Still stupid and seriously neglected..
#395
Waiting for Summer !
Bikes: E.Merckx Corsa extra PK Banken,E.Merckx Corsa extra TT,E.Merckx Strada,De Visini,Olmo Gentleman,Peugeot PA-10,E.Merckx Corsa extra Team Issue,Nishiki Olympic Royale,Nishiki Olympic
#396
Correction - the Swallow Montello tires are not Vittoria, just plain Swallow Montello.
#397
^^ Interesting tidbit of web research: Swallow was a brand name of a Korean bicycle tire manufacturer that became a supplier to a German bicycle tire exporter in 1973 ...
... and the origin of the Schwalbe brand name.
They must have kept the Swallow name in use for US distribution, because these tires are too new-looking to date from the early 70s. Unless the rubber and glue can stay supple for that long.
#398
Have any of you guys ever tried using the 32mm, gray, diamond tread, cyclocross Vittorias on the street? I am wondering how they'd stick and if the compound would last.
I am fascinated by the higher volume tubulars but would like to avoid spending $150(!). I figure I'd run them at 75 psi or so.
#399
Liked 661 Times
#400
Quoted: 830 Post(s)
Liked 2,110 Times
As for removing glue from rims, etc., I find Brasso (household metal polish available in many drugstores) works exceptionally well. Just apply to a rag and rub the glue off. Wipe away residue with a clean rag.
