Non-pannier use of a rear rack
Old 10-28-12, 01:16 PM
FatBottomedGirl
FatBottomedGirl's Avatar
Hey guys!
I have an EX2 Blackburn rear rack and been very happy with it as far as hanging a pannier (or two) to it.
I was just wondering: what kind of items can I put *on* the rack and how liable and safe is it?
Can I, for instance, put a backpack with my rainclothes on it?
Of course I would secure it with an elastic strap or a cargo net but it is tough to imagine what could fit there? it feels so narrow!
Thanks!
FatBottomedGirl is offline
Old 10-28-12, 02:08 PM
no1mad
Thunder Whisperer
no1mad's Avatar
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times in 2 Posts
That rack doesn't have a 'fender top' or solid platform. I'd be wary of strapping anything to the top of that rack that wasn't designed to do so- like a trunk bag or a basket. You could strap your backpack to the rack, but you'd have to take great care that the pack straps don't dangle through the rack and secure it so the load doesn't shift resulting in the bag making contact with the rear wheel.
no1mad is offline
Old 10-28-12, 02:49 PM
David Bierbaum
David Bierbaum's Avatar
Bikes: 1992 Specialized Crossroads (red)
Quoted: 26 Post(s)
Liked 35 Times in 19 Posts
As long as you use something that won't fall through the gaps on the top of the rack (or use a stiff piece of cardboard/plastic under your item for said purpose), and you mummify the item in so many bungee cords that it can't move, I think you can carry just about anything that doesn't exceed the weight limit of the rack.
David Bierbaum is offline
Old 10-28-12, 03:06 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Secure a piece of Plywood to the rack, and then it will be wider,
and, also, have some wheel-spray protection.
BALTIC birch plywood is light and strong, paint or clear lacquer to keep it nicer looking..
add some corner holes to hook the stretch net into..
fietsbob is offline
Old 10-28-12, 05:14 PM
MichaelW
Quoted: 19 Post(s)
Liked 7 Times in 7 Posts
I have toured with a 25l backpack bungied to the rack-top. You need about 3 bungie chords, at least one going under the rack and over the bag.
Don't let anything drag into the spokes or wear against the tyre.
make sure your rear lamp is not blocked.
I sometimes use a rack extender for carrying big items such as bags of plaster, cement or horse manure!
I have a 1/4" plywood length with 4 pairs of small holes, threaded with a length of wire so i can fix it in place and remove it easily. If you want a more permanent fixture, corrugated plastic fixed with zip-ties should be strong enough.
MichaelW is offline
Old 10-28-12, 07:09 PM
no1mad
Thunder Whisperer
no1mad's Avatar
Quoted: 275 Post(s)
If you opt for this route, take note of where on the rack you place your panniers and then cut into the new deck plate at that location or you won't be able to use your panniers in the future.
no1mad is offline
Old 10-29-12, 12:59 PM
steve-in-kville
Warehouse Monkey
steve-in-kville's Avatar
Quoted: 305 Post(s)
Liked 7 Times in 2 Posts
I've attached milk crates... high profile but work really well. I once used a sturdy cardboard box. Cut a piece of plywood to fit the inside bottom and used 1/4" carriage bolts to secure it to the rack. Added some reflective tape to the back. Worked reall well for an entire summer. Then I spent some bucks and bought my panniers, but you can't beat a simple box sometimes!!
'10 Specialized Hardrock
steve-in-kville is offline
Old 10-29-12, 01:06 PM
cale
cale's Avatar
Bikes: Kuota Ksano. Litespeed T5 gravel - brilliant!
Liked 4 Times in 4 Posts
The issue you'll most likely encounter when strapping stuff to the top of your rack is bike instability. The higher you mount a load the more it contributes to instability. Now a bag with rain clothes in it doesn't sound very heavy so it's hard to imagine you'd have any problem with that. But if you were to mount your child to the back, you'd find the bike less stable. YMMV.
cale is offline
Old 10-29-12, 01:16 PM
FatBottomedGirl
Thanks guys! this was mostly out of curiosity! I always have a rear pannier on my bike and I see no case where I would absolutely need to use the top... I was just curious.
(as it turns out, just today I used it to put some bread and a couple of cucumbers... )
Old 10-29-12, 01:59 PM
noglider
noglider's Avatar
Quoted: 7336 Post(s)
Liked 2,435 Times in 1,422 Posts
I've used racks like that for 35 years. I use bungie cords to attach all kinds of things. Tying things up can be slower than with other methods, but it works. Be patient and thorough. Make sure the bungies are tight and have no risk of dangling or getting caught in the wheels or anything. When I tie up clothing or a backpack, I take care to tuck in any dangling straps, sleeves, etc.
You could use rope if you prefer. Or you could use those nifty ratcheting straps that have become popular. Be sure you're good at any of these skills before you take off. Bounce and wiggle the bike to be sure.
noglider is online now
Old 10-29-12, 02:30 PM
cale
cale's Avatar
Okay.... but take it easy!
cale is offline
Old 10-29-12, 02:50 PM
steve-in-kville
Warehouse Monkey
Quoted: 305 Post(s)
Now that's quite the pickle!!
Old 10-29-12, 10:32 PM
Bike Gremlin
Mostly harmless ™
Bike Gremlin's Avatar
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times in 130 Posts
This is my small, urban summer version. I've carried 3 times larger backpack - no problems. Just put a good bungee cord. Stability is not a problem if you tie it down right - doesn't moove. It is also very practical. You stop and you've got a regular backpack to carry. Unless aggressively riding OFF road, it will be no problem.
File Type: jpg
File Type: jpg
Bike Gremlin is offline
Old 10-30-12, 06:34 AM
MichaelW
Quoted: 19 Post(s)
If the racktop load is very heavy or big I always use a rope; lightweight rope is fine, as are nylon webbing straps. You dont want a heavy bag of plaster or concrete held in place by a bit of elastic.
MichaelW is offline
silvermace
Bicycle Mechanics
13
06-23-15 07:27 AM
Monster Pete
Utility Cycling
5
01-24-12 03:56 PM
chico1st
Commuting
20
10-15-11 07:39 AM
CornyBum
Commuting
28
12-19-09 07:55 AM
