prototype/custom garmin 500 mount
Bikes: 2009 Specialized Tarmac Sl2
Man, where do I get one of these?! I've been looking for a forward stem mount.
Found here:
https://www.cyclingnews.com/features/...ditalia/120054
Steve
Found here:
Steve
Carpe Diem
Bikes: 2007 CAAD9; 2014 CAADX; PedalForce CG1
does the 500 use a different mounting interface than the other Garmin Edge computers?
"When you are chewing the bars at the business end of a 90 mile road race you really dont care what gear you have hanging from your bike so long as it works."
ΛΧΑ ΔΞ179 - 15% off your first Hammer Nutrition order!
pan y agua
Quoted: 1447 Post(s)
Liked 728 Times
To the OP, looks like just something fabricated by Garmin team mechanics. Kinda doubt it will see production. For one it's not going to work with the vast majority of stems.
You could get lost and die.
You could hit a tree and die.
pan y agua
Liked 728 Times
And this would accomplish the same result , albeit not as elegantly.
Bikes: Baum Romano, Brompton S2, Homemade Bamboo!
Quoted: 474 Post(s)
Liked 204 Times
Send me the specs of your stem and I'll get the lads at work to make you one (as a prototype for my own )...
pan y agua
Liked 728 Times
If you had a stem like that it wouldn't take much to fabricate one. Buy a sheet of carbon fiber (or aluminum if your cheap. Cut to size. Glue the 500 mount on, and you've got it.
Heck if you're really cheap. Cut and fold a beer can.
I've found this one before. I just wish it wasn't so huge.
https://cgi.ebay.com/25g-Carbon-Bike-...ht_4428wt_1139
Bikes: Time RXRS, Specialized Stumpjumper FSR
Found here:
Steve
Found here:
Steve
- Find a thin aluminum, plastic, or carbon plate. The plate would have to be L-shaped for a regular stem.
- Drill a couple of holes for the stem bolts and one for the Edge mount.
- Use a regular Edge 500 mount, clip the four elastic band prongs so it's a bit flatter and drill a hole in the center. You could keep the elastic band prongs intact if you want the mount to keep its original form.
- Use a flat bolt and washer to attach the mount to the plate.
Bikes: 2010 Trek 2.1
Looks like the FSA, there's a bunch on ebay and some copycats that seem interesting:
https://cgi.ebay.com/FSA-Control-Cent...#ht_1958wt_907
https://shop.ebay.com/?_from=R40&_trk...All-Categories
Easy to make. You can buy cf plate at your a hobby shop for $20. If it's thin enough you can cut it with an exacto knife, if it's thicker use a dremel. Looks like they just countersunk a screw through the garmin mount into the cf.
