Need Advice on Refinishing a Frame
Old 07-04-18, 01:44 PM
byscott
byscott's Avatar
Quoted: 8 Post(s)
Liked 17 Times in 11 Posts
I’ve had a frame hanging on my garage wall for years. It’s a Falcon San Remo that I bought when I was in college in the mid 70’s. I rode a lot of miles on it through the early 80’s; I was pretty strong back then, so the 531 straight gauge suited me. I retired the bike in favor of an aluminum Cannondale, but never parted with it.
Lately I’ve been thinking about rebuilding it with some of the stuff I have lying around. The first step would be to restore some semblance of the original Falcon colors, which were primarily powder blue with (I think) contrasting paint on the head and bottom-bracket lugs.
Here’s my question ... what’s the current state of the art in repainting a frame? I had figured I’d have to hand strip it, hit it with a couple coats of self-etching primer, then go from there. Is that the best way to go? Are chemical strippers or sandblasting an option? I’d appreciate any advice ... TIA.
byscott is offline
Old 07-04-18, 02:07 PM
satbuilder
Bikes: A few
Quoted: 289 Post(s)
Liked 198 Times in 103 Posts
How bad is the current paint job?
satbuilder is offline
Old 07-04-18, 02:37 PM
byscott
byscott's Avatar
Quoted: 8 Post(s)
Meh. Rattle can gloss black, little or no surface rust. The frame is pretty good, just ugly.
byscott is offline
Old 07-04-18, 02:45 PM
Hoopdriver
On Holiday
Hoopdriver's Avatar
Bikes: A bunch of old steel bikes
Quoted: 394 Post(s)
Liked 14 Times in 12 Posts
I generally shave as much paint off with a single edge razor blade as I can, the wire brush. I have a sandblaster but no booth and it's way to messy for me. I will use chemical strippers on those hard to reach places like the seat lug and bottom bracket, but that's it - again too messy. Following that, I just repair any dings, add braze-ons maybe, and then file ugly parts (all frames seem to have blobs of brazing filler left during manufacturing), finally a good sanding. Painting is something that needs a different thread.
Hoopdriver is offline
Old 07-04-18, 02:55 PM
gugie
Bike Butcher of Portland
gugie's Avatar
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times in 2,286 Posts
All depends on how much you want to spend. Media blasting should only be done by someone who paints/powder coats bike frames. I've got a guy who will do it for $40 who does powder coating of bikes.
@Hoopdriver's method sounds as good as you need. Dings can be filled with JB weld, let it set overnight, then carefully file/sand it round.
gugie is offline
Old 07-04-18, 03:43 PM
John HP
Bikes: 1998 Marinoni Leggero, 1988 Tommasini Super Prestige, 2018 Holdsworth Competition, 1996-ish Redline Cross Bike
Quoted: 26 Post(s)
Liked 9 Times in 7 Posts
How difficult is it to media blast a frame but not touch the chrome on seat/chainstays? Just mask it off maybe?
John HP is offline
Old 07-04-18, 05:40 PM
SquidPuppet
Calamari Marionette Ph.D
SquidPuppet's Avatar
Bikes: 3 Chinese Gas Pipe Nerdcycles and 2 Chicago Electroforged Boat Anchors
Quoted: 2358 Post(s)
Liked 33 Times in 26 Posts
Yep, just mask well. Look up soda blasting.
SquidPuppet is offline
Old 07-05-18, 12:25 AM
machinist42
mycocyclist
machinist42's Avatar
Quoted: 910 Post(s)
Liked 822 Times in 453 Posts
Birds Of A Feather?
As I very recently acquired a Falcon San Remo Straight/Plain gauge 531 with Reynolds 531 forks, I may be able to provide reference information if you're interested in restoring your Falcon? It's in essentially original condition, and probably is a 1972 from the date codes on the Campagnolo NR RD and FD. It has stamped dropouts. It's no doubt one of the "Numbered" San Remos and definitely not an "Equipe". I have yet to ride it, or photograph it, but here is one of the seller's pictures from their ad on FB Marketplace for a "Project Bike Needs Rebuild". One notable feature is the only braze on is a post on the underside of the downtube to fix the DT shifters, though in this case it's used to secure the Campagnolo cable guides for the Suntour Bar Ends.
I don't want to hijack your thread. I will be opening one for this bike, and if I can find a "Show Me Your Falcon" thread, I'll post to that eventually, too.
I'd sure like to see pictures of your bike!
machinist42 is online now
vintagerando
Classic & Vintage
41
11-27-18 09:35 AM
polymorphself
Classic & Vintage
10
10-03-18 08:35 AM
SamSpade1941
Classic & Vintage
10
08-26-18 12:46 AM
sloar
Classic & Vintage
49
06-15-18 08:56 AM
