road bike into a hybrid
Just bought a new carbon fiber road bike and I hate the way it feels. Being all hunkered over. Im use to mtn bikes with straight handle bars. Can I put straight handle bars on a road bike and change the shifter and brake leavers. Thanks for the help. I guess im trying to turn a road bike into a hybrid bike I think
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 672 Post(s)
Liked 417 Times
Why did you buy a bike you don't like?
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Bikes: Eddy Merckx San Remo 76, Eddy Merckx San Remo 76 - Black Silver and Red, Eddy Merckx Sallanches 64 (2); Eddy Merckx MXL;
Quoted: 143 Post(s)
Just a person on bike
Bikes: 2015 Trek 1.1, 2021 Specialized Roubaix, 2022 Tern HSD S+
Quoted: 132 Post(s)
Liked 86 Times
I'd talk to the LBS for suggestions. Since your bike is fairly new, they may be able to take in the original parts (the drop handlebar, shifters, etc) rather than have you pay the full prices for the new parts.
The value of your life doesn't change based on the way you travel. - Dawn Schellenberg (SDOT)
Speechless
Bikes: Felt Brougham, Lotus Prestige, Cinelli Xperience,
Quoted: 163 Post(s)
Liked 39 Times
If SRAM drive train, you will need double tap flatbar shifters and brake levers set for short pull. Tektro has models with both short and long throw. You could use a 10 SPD MTB RD, but not FD (cable pull is wrong). If you want to use a SRAM MTB front shifter, buy a shimano r-440 FD.
If current drive train is Shimano, you will need the flat bar road shifters (440, 550, 770), and you will still need the FD-440 or FD-770 to get road crank curvature and MTB cable pull. Same brake levers as above.
Buy a longer stem, as your hands will be too close in with the original stem. Pay attention to flatbar shape when you buy. I get flat bars with an angle in only one plane, where some like risers and sweptback. Remember you can cut down bar length to whatever you want.
Sell the road bike, buy a hybrid.
Given the number of new components you'll need and the price of carbon road bikes vs hybrids, its the easiest way if you come out ahead. If you can exchange the road bike for a hybrid, that would be ideal.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
pan y agua
Quoted: 1447 Post(s)
Liked 728 Times
You don't have to be "hunkered over" It's possible to set the bike up less aggressively, i.e. more upright, and still retain the advantage of having drop bars.
I'd go back to the shop where you bought it, and ask them to work with you on your fit, and tell them you want a more upright position.
Also if you want to ride on the flat section of the bars, you can add brake levers that allow you to brake while riding on the flat section of the bars for $30 or so.
https://sheldonbrown.com/harris/brake-levers-drop.html
These two modifications will give you what you're looking for, will retain the advantages of drop bars, and will cost a lot less than a flat bar conversion.
You could get lost and die.
You could hit a tree and die.
Bikes: 2014 Specialized Secteur Sport and 2016 Specialized Pitch 650b
My guess is you have an expensive road bike if it is carbon frame. I would sell it and get a hybrid that you are comfortable with.
You will take a small hit on the bike but you will still be able to get a nice hybrid bike.
Manny
Ghost Ryding 24/7
Bikes: Giant Defy with Dura Ace group, & Ksyrium SL's,Specialized Allez Shimano mixed/mashed,2011 Opus Sentiero,2008 Kona Jake the Snake,Custom built track/fixed,Stumpy Hartail,Kuwahara/ET bike.
pan y agua
Liked 728 Times
^ Could be worse.
I'm doing it wrong.
Bikes: Rivendell Appaloosa, Rivendell Frank Jones Sr., Trek Fuel EX9, Kona Jake the Snake CR, Niner Sir9
Quoted: 9742 Post(s)
Liked 2,812 Times
https://www.rivbike.com/product-p/hb3a.htm
Ghost Ryding 24/7
Well, you could go with a mustache bar, that way you can continue to use your current shifters and only have to buy the bar.
I'm doing it wrong.
Liked 2,812 Times
Ghost Ryding 24/7
I'm doing it wrong.
Liked 2,812 Times
The Op could also change his shifting from brifters to bar ends if he went the mustache bar route.
If he wants to stick with a straight bar he could do that but would need to change his brake levers and shifters. He could totally fred it up and use friction thumb shifters.....
Quoted: 1361 Post(s)
Liked 424 Times
You could easily keep the bike but swap the road bar for a flat bar and thumb shifters and the brake levers. Probably would need to experiment with the stem too. Where you ride and needs is all about you and not others.
This Giant Rapid 1 has road bike geometry and mostly road components - Shimano 105. Came with a flat bar and thumbies, but I cut 3/4" off each end and added drop bar ends. This bike is an all around sub 19 lb. machine. The drops come off in a few seconds, can swap for ATB bar ends, sometimes it sports a rack and fenders, AND runs road 23C width to 34C knobbies. Comfy fun from gravel grinding, off-road single track to riding century's. I love this bike and plan to do a similar set-up on an older steel road bike.
Ghost Ryding 24/7
Just get a CXer with interrupters on the tops.
Thunder Whisperer
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times
Community guidelines
