British 68mm threaded BB for 30mm Cannondale Hollowgram triple crank
Quoted: 1163 Post(s)
Liked 442 Times
Usually folks are trying to take a bb30 pressfit bottom bracket and make it compatible with a 24mm Shimano HT2 crank but I am curious about doing the opposite.....
I would like to mount a Cannondale BB30 (30mm crank axle) crankset into a standard English threaded 68mm bottom bracket. I found one at the Kogel bearings site but it is over $200 and it says it is for Rotor, RaceFace and Easton. Not sure if Cannondale would work.
I was wondering if folks knew if such a bottom bracket could be set up like this. Bonus points awarded for an English threaded 68mm 30mm bottom bracket of good quality for less than, say - $60.
Cheers! From, Bill in Dayton, OH.
Quoted: 336 Post(s)
Liked 309 Times
Even if you can find a compatible bb, I wouldn’t use one, because the bearings that would have to be used would be far too small to be reliable.
The bb30 spindle is too short for outboard bearings on a 68mm BSA shell, so the bearings would need to sit between the bb shell and the spindle. The thread diameter is about 35mm, which means that the bearing assembly needs to be less than 2.5mm thick. That isn’t enough room for threads, races, and balls.
as far as I know, a solution for this does not exist.
Likes For aggiegrads:
Liked 442 Times
Senior member
Quoted: 943 Post(s)
Liked 659 Times
External bearing English threaded bottom brackets for 30mm spindles do exist. Here is one example. and not too unreasonably priced. https://www.raceface.ca/products/bsa-cinch-30mm
Likes For Dan Burkhart:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Likes For cxwrench:
Liked 442 Times
Thanks for your reply BTW.
Thanks Dan Burkhart for the link.
Quoted: 714 Post(s)
Liked 800 Times
As has already been said in post #2, the spindle of the BB30 crankset is not long enough to work with an external bearing like the Kogel or Raceface bottom brackets. Those bottom brackets work with cranksets like the Raceface cinch or 386EVO, which have longer or replaceable spindles.
Likes For dsaul:
Quoted: 336 Post(s)
Liked 309 Times
30mm spindle is not the same as BB30.
Quoted: 336 Post(s)
Liked 309 Times
cxwrench has much more experience than I have so he is really the authority, but I would double check with the crank manufacturer before you buy the BB.
Quoted: 2026 Post(s)
Liked 1,096 Times
The similar and contemporary ISIS bottom brackets did have a reputation for poor durability but that was because of poor materials and workmanship, not inherent weakness. The Shimano Octalinks were good.
Liked 442 Times
Bumping this thread to maybe jumpstart the conversation thanks to an idea I have about how to custom fit a Cannondale Hollowgram BB30 mtb axle onto a BSA road frame and take the guess work out of which spacers to use. My idea is to use a Cane Creek or Kogel 30mm pre-load adjuster. I think it just might work for "trekking" triple chainring set I mounted on the Hollowgram crank spider.
Quoted: 4420 Post(s)
Liked 1,568 Times
There's a reason you were told there is no good solution to mounting this crank on a BSA frame.
Likes For Kontact:
Liked 442 Times
If you take a Hollowgram BB30 crank for a 68mm shell and mount it on a different length spindle, your chainline will be off - usually by at least 11mm to clear the external bearings.
The granny ring is pretty small like a 26, I’ll need to re-check. There is maybe a mm or two too much clearance so maybe a difficult chainline…
I might use a “dub” pre-load adjuster in place of whatever drive side spacers I have on there right now in order to get the correct pre-load on the bearings. Also, this triple crank is going to need a really good triple compatible front derailleur like a Deore XT, XTR900 or SunTour. Shifting will be friction front with either a bar end, a SunTour Command paddle shifter or a retrofriction lever mounted on some Gevenalle Audax brake lever pods.
But with the BSA cups hand mounted (not yet torqued to spec) and some stack of spacers that seems close to what I am after, the “granny” ring has decent chainstay clearance so far on my oversized aluminum tube Cannondale Silk Tour 1000 frame.
My main issue is coming up with the right amount of pre-load on the bearings so that not only is there no slop, but also that I have not overtightened the preload.
The chainring set is 104/64 bcd, https://www.ebay.com/itm/25468409010...mis&media=COPY
Liked 1,568 Times
No one told me there was no good solution, just that I was on my own to come up with “A” solution. Since I’m using a triple spider on the Hollowgram BB30 crankarms, I mated it with a Hollowgram MTB axle that is like 131mm instead of the road double one which is 109.5. It might actually be 134mm, I’ll have to measure again with my calipers.
Liked 442 Times
I was really hoping to get these 104/64 bcd chainrings to work for this application. I will continue to work to take some more measurements and maybe play around with a preload adjuster, wavy washers or different length of 30mm hollow axles. Worst care scenario, I will scrap the plans for this crank on this bike and most likely put a shimano triple on there.
Likes For masi61:
Liked 1,568 Times
You will never be able to get those chain rings closer to the center than they are right now.
Should you ever be able to get the front derailleur to swing that far out to shift to the big ring with a custom clamp, you'll just be faced with the next problem; an impossible chain line.
As an aside, I am positive at one point in time in the early 2000s someone did produce semi-internal BSA bearings for Hollowgram cranks but unsurprisingly those quickly disappeared. They came with double rows of tiny balls that disintegrated in no time at all and required the use of the 122mm spindle.
Likes For Mackers:
Liked 442 Times
But why?
I’m trying to come up with my own pre-load system for Cannondale Hollowgram cranks. But,…
This bottom bracket system could fail based on a possible “bodge” where some were that lip on the axle I would think the inner bearing race could get worn out prematurely.
This is why I am considering moth-balling this project & instead - grafting the chainrings onto some Deore XT Octalink chainrings with a 104/64 triple spider.
Liked 442 Times
Is this your opinion or is this just how the Cannondale system is intended to work? I still am trying to wrap my mind around the way that these Hollowgram cranks attach to the spindle. It seems to me that the bolts need to be torqued to the correct spec using a torque wrench. But this could be done prior to preloading the bearings. So one of the things I plan to try out is to torque both crankarms to spec with a cheap chinese 30mm dub preload adjuster and see if it is possible to dial out the play in the system for optimal bearing function after the arms are already torqued to spec. I envision some re-flags with this idea though, to me a preload adjuster where the inner ring is super glued to the spindle, well this sounds bound to fail. I am at a loss here but I suspect that custom BB30 Hollowgram crank adjustable chainline bottom brackets should be achievable.
Liked 1,568 Times
This is not a new concept. Square taper and Octalink used 22mm or smaller spindles inside a 68mm shell that is 35mm in diameter. BB30 did the same thing, but the bearings are between a 30mm spindle and a 42mm diameter shell. 30mm spindles don't leave room for bearings inside a 35mm shell.
Likes For Kontact:
