How to make use of Large Chain ring, Small Cog?
I use the Large Chain ring , small cog a lot on level surfaces after I get up to speed. After you get rolling a while, it can be a really good combination. At least I thought so.Today my Chain kept falling off the large ring when I hit a bump, so I had to use the next largest Chain ring. When I finished, I noticed on phone my time for 25 miles was 5 minutes faster, even with 2 stops to put my Chain back on.What do others use the Large Chain ring, small cog for?
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Bikes: 2021 Salsa Warbird, (Specially Love my) 2021 Salsa Cutthroat, 2012 Surly LHT, 2015 Surly Cross-Check, 2008 Giant OCR A1, 2005 Leader 735R, 2005 Gary Fisher Montare, 1991 Nishiki Pueblo,
Quoted: 84 Post(s)
Liked 57 Times
My Large chain ring is the size of an extra Large jumbo family size Pizza pie and my small cog is only a 3 tooth ring and I ride this sweet baby combo all the time rain shine or snow no problem all the time,
Likes For Eds0123:
Super Moderator
Quoted: 1173 Post(s)
Liked 929 Times
I ride in what ever gear enables me to pedal about 90 rpm.
If you never use the big ring and smallest sprocket, then your big ring is too big. The small chain ring and smallest sprocket can't be used on modern 12 speed bikes. I use 46/30 chain ring and 10-36 cassette. I use every sprocket on some routes, but some only require my 30/32 for seated climbing.
Switching to the little ring is typically only done for climbing. I have an 8-13% grade on most of my routes and that's when I use the little ring. On lesser grades, I may stay in the big ring and pedal standing.
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
My bikes only have 42t chainrings, and I use the small cog mainly for ramping up before a tuck on a descent, taking a standup break on a long flat stretch or doing interval work on the flats.
Otto
Otto
Klaatu..Verata..Necktie?
Quoted: 10444 Post(s)
Liked 11,923 Times
The thing about being a larger cyclist in a hilly area is, you use ALL your gears, from the smallest to the largest, in a single ride.
"Who uses a 53 x11?" This guy.
"Who uses 36 x 34?" This guy.
Likes For genejockey:
I used to be the designated sprinter on my team. On those few occasions I was still in the pack in the last 1km, a 53-11 was the universal combination. Either your chain is too long, or you need to add a little tension to your derailleur.
Likes For 50PlusCycling:
Quoted: 18428 Post(s)
Liked 15,582 Times
I’m not taking the bait, but help yourselves.
Quoted: 505 Post(s)
Liked 639 Times
Seriously though, a lot of inexperienced cyclist equate bigger gears with faster speeds, leaving the RMPs out of the equation. Most (fit) cyclists will be fastests in the largest gear that they can "stay on top of" if you shift up from that, you start plodding.
Likes For wheelreason:
No way. If you're able to use the smallest sprocket on flat ground, you're going to be under-geared (i.e. spinning out) very early when descending. But if you live in a flat area, while you're rarely going to be descending you'll still be happy you have that extra range when you DO have to descend.
Quoted: 505 Post(s)
Liked 639 Times
Quoted: 6199 Post(s)
Liked 4,816 Times
Small cog on the rear is the one with the fewest teeth right?
Perhaps your high limit on the rear or front DR isn't set correctly or your chain is too loose. Possibly from being too long. The rear DR is gummed up and the cage isn't keeping proper tension on the chain. The rear DR is out of spec for the range of cogs on the rear and/or the rings you run on the front. Or your chain line is way off.
Quoted: 506 Post(s)
Liked 639 Times
climber has-been
Liked 3,567 Times
The answer to "what is efficient?" depends on your definition of efficient.
Low cadence is metabolically efficient, high cadence is metabolically inefficient.
Low cadence increases muscle fatigue, high cadence reduces muscle fatigue.
Likes For terrymorse:
Liked 4,816 Times
We don't know the ring size or cog size. An older bike with a freewheel probably only has a 14 tooth for the small and with a large ring of 50 or smaller on the front, that's a very easy gear to push when up to speed as the OP said they are.
Even on my Raleigh Competition GS with a 6 speed rear of 14-28 and a front 53/39 I was often in that 14 tooth cog with the 53 ring.
Quoted: 3957 Post(s)
Liked 7,310 Times
Liked 11,923 Times
80-85 is about where I like to be on longer climbs, and so far I haven't left bits of asploded knee all over the pavement.
climber has-been
Liked 3,567 Times
just another gosling
Quoted: 3894 Post(s)
Liked 1,943 Times
However, for normal people, yeah the big-small combo is great for whupping butt on a long shallow descent. If you're running small gears, you're not even in my mirror (53X11). We had a very good LD rider on BF long ago who used a 60t on the east slopes of the Rockies. But like I said above, using a big gear on the flat takes special training. My rollers produce about the same watts per unit speed as I see outdoors. Yesterday, I was doing 10' intervals,18.5 at 54 cadence, 137w, 114HR, not tired. Hard to find a flat longer than 3 miles around here. There ya go.
Results matter
Results matter
Likes For Carbonfiberboy:
Liked 11,923 Times
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
I ride low cadence on the 53x11 to go very fast, and my knees are fine (I'm 62, and been doing some variation of this my entire life). Yes, that's an anecdote that proves nothing, but it sure made me curious about all this "blow your knees out" talk. I've looked into the medical literature and can find virtually nothing that supports this myth of knee issues, just a bunch of trainer lore and anecdotes..
Likes For livedarklions:
climber has-been
Liked 3,567 Times
Liked 11,923 Times
