Tire Repair
Old 03-11-10, 09:10 PM
UprightJoe
Tire Repair
I hit a little piece of debris on my ride home tonight that was as sharp as a razor. It made a clean slice in a nearly new puncture-resistant tire about a centimeter wide. I carry a folding spare so I just rode my spare tire home. Is this something that can be permanently repaired with a boot or something?
I don't want to throw out the tire if it's repairable but at the same time, I don't want to flat constantly because I'm too cheap to buy a new one.
UprightJoe is offline
Old 03-11-10, 09:21 PM
canopus
canopus's Avatar
Bikes: Road, Touring, BMX, Cruisers...
Quoted: 135 Post(s)
Liked 173 Times in 111 Posts
You could patch it from the inside. Or leave a dollar bill on the inside between the tire and tube. Move it to the front if you are really worried about it. Might as well try it before throwing it out.
canopus is offline
Old 03-11-10, 09:25 PM
cnnrmccloskey
cnnrmccloskey's Avatar
Bikes: '82 Giante super challange, 70 Gitane Tour de France, GT Gutterball
Bad advice, if you have a wheel that could flat unpredictibly you would want it on the rear wheel, when front tires fail its gonna affect the handling and you can easily crash.
Tire boots are temporary solutions so you can ride home/ to the shop, it is not an appropriate long term fix, sad story but your tire is trash, time for a new one, you'd be upset that you didn't when your 20 miles from home walking your bike after that boot fails.
cnnrmccloskey is offline
Old 03-11-10, 10:11 PM
simplify
ride, paint, ride
simplify's Avatar
Bikes: Cannondale R300 Caad2
Agree completely. Been there, lost a very expensive tire on its first ride. It hurts but it's not worth taking a chance, because once the casing is cut through, there's no way to make a permanent, completely safe and longlasting repair.
simplify is offline
Old 03-11-10, 10:17 PM
Wanderer
aka Phil Jungels
Wanderer's Avatar
Bikes: 08 Specialized Crosstrail Sport, 05 Sirrus Comp
Quoted: 202 Post(s)
Liked 86 Times in 60 Posts
A Centimeter wide!!!! That tire is toast if it went thru cords!!!!!!
Wanderer is offline
Old 03-12-10, 09:56 AM
Metaluna
Bikes: Niner RLT 9 RDO, Gunnar Sport, Soma Saga, Workswell WCBR-146
Quoted: 114 Post(s)
Liked 19 Times in 19 Posts
Yes, there's no way a little rubber patch is going to replace the strength of an aramid belt.
I once rode over a utility knife blade that some a$$ had left laying on the shoulder. Sliced a nearly new Michelin Carbon clean through from sidewall to sidewall.
Metaluna is offline
Old 03-12-10, 01:42 PM
dstrong
dstrong's Avatar
Bikes: Specialized Roubaix, Interloc Impala, ParkPre Image C6
Quoted: 254 Post(s)
Liked 86 Times in 56 Posts
Originally Posted by Metaluna
I once rode over a utility knife blade that some ass had left laying on the shoulder.
FIFY. You can say "ass".
2014 Specialized Roubaix2003 Interloc Impala2007 ParkPre Image C6 (RIP)
dstrong is offline
Old 03-12-10, 02:04 PM
Kimmo
Kimmo's Avatar
Quoted: 1529 Post(s)
Liked 718 Times in 510 Posts
One sure-fire way to tell if the casing's damaged is to see if there's a corresponding bulge. A boot's not gonna fix that, which is the main reason it's junked.
...I can't help feeling there should be a way to repair such damage... some sort of steroidal gaffer tape or something... it basically needs to support the tyre from bead to bead.
Kimmo is offline
sdimattia
Bicycle Mechanics
7
05-22-19 03:42 PM
Bad Lag
Classic & Vintage
20
11-16-16 04:20 PM
XXLHardrock
Bicycle Mechanics
19
07-14-15 06:35 PM
Solorouleur
Road Cycling
6
09-05-10 05:34 PM
flattireJason
Bicycle Mechanics
8
06-24-10 09:15 AM
