Good deal for $50?
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 460 Times
Good deal for $50?
This locally to me. Includes the box.
Really Old Senior Member
IF you don't have the tools jump on it.
Looks like a Helicomatic removal tool?
https://www.ebay.com/i/174227881560?...yABEgJHfPD_BwE
Not a spectacularly awesome great deal. But, yeah. I'd say that's a pretty good deal. A fair price.
Quoted: 550 Post(s)
Liked 325 Times
It depends on what sort of bikes you own. Modern ones wouldn't use any of those except the chain whip and tire levers. The spoke wrench may be one of the three common sizes that you need.
- Disc brakes don't use the offset wrench
- That looks like a freewheel tool which won't fit cassette lock rings
- Two piece cranks don't need an extractor
- Threadless headsets don't use a 32mm wrench
- Cartridge bottom brackets don't need a lock ring spanner
- That's not a high quality chain tool and modern narrow chains may not fit
- Cartridge bearing hubs no longer require adjustment with cone wrenches. Many use hex keys for disassembly not cone wrenches.
- Cartridge bottom brackets have no adjustable cup requiring a pin spinner.
OTOH, with a large vintage fleet you need all those things.
Quoted: 677 Post(s)
Liked 460 Times
Bikes: 1984 Fuji Club, Suntour ARX; 2013 Lynskey Peloton, mostly 105 with Ultegra rear derailleur, Enve 2.0 fork; 2020 Masi Giramondo 700c, full Deore with TRP dual piston mech disk brakes
Quoted: 324 Post(s)
Liked 81 Times
It's a good deal, but I would offer $40. I also can't tell in the photo but it appears that the tool box drawers are bent downward on the right side especially the top drawer, if that's the case I would offer $30 and explain the tool box is in poor shape.
That Park crank puller may be the very old style that had threads for both 22mm (most common) and 23mm (for old TA cranks). If you buy the tools and can't imagine owning a TA crank, or wanting to remove one, you could probably get a decent price for that tool alone. Just don't use it on the old Stronglight cranks as it will sometimes ruin them -- Stronglights are 23.35 mm, for some reason that even God doesn't know.
Quoted: 550 Post(s)
Liked 325 Times
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times
I have that same box I bought in the 1980s.
That box alone retails for $60 new. https://www.lowes.com/pd/CRAFTSMAN-P...Box/1000602661
Likes For FiftySix:
Quoted: 677 Post(s)
Liked 460 Times
SE Wis
Quoted: 2747 Post(s)
Liked 3,398 Times
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
You'll still need to buy a 17mm cone wrench for shimano rear locknuts but yeah, buy it.
Quoted: 1303 Post(s)
Liked 1,911 Times
Run! Don't walk to pick this up. It is the cost of two of those tools new. You will be on yer way to being a bike mechanic. And remember no one buys a Snap-On tool kit to start. Smiles, MH
Likes For Mad Honk:
Half way there
Quoted: 986 Post(s)
Liked 880 Times
I know that some people disparage the Park tools of that design as the lever arm is sort of short. But, it's always worked for me, over the years, and it does work on TA cranks.
Quoted: 1088 Post(s)
Liked 1,025 Times
If you plan to use the tools and either know or plan to learn how to use them then its a very good deal, not the most amazing bargain but you're making off with a great savings over new. If they'll sit and collect dust its a waste of 50.00
Agreed as short as the lever arm is I've yet to run into the crank it couldn't remove and its nice it slips past a lot of pedals. I bought a new park crank puller that used a wrench and the threads were so awful on it that even cleaning them with a cloth and lubing them they still stripped out a couple cranks. Tossed it in the garbage and went back to the old standby there. Hard to be something that just works.
The tools aren't the most exciting ever, but with the Craftsman it looks like a decent deal if there's stuff you need in there.
Quoted: 1572 Post(s)
Liked 643 Times
Everything has a value and a price. They aren't the same thing.
Take just the empty tool box for example. If you need a tool box, and that one is in good enough shape to meet your needs. Then the empty tool box alone has value. If you don't need a tool box, then it's not a good deal regardless how cheaply you are able to buy it. You'd actually be better off if you didn't own it because it's just taking up space.
"Just because it's neatly stored doesn't make it not a hoard."
Quoted: 883 Post(s)
Liked 823 Times
Pretty easy decision; good deal if you need and can use the box and/or some of the tools. Probably wouldn't be worthwhile for most on this thread because it would contain items not needed or duplicates.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
I would buy it for the price certainly you can try and go lower but a lot of cool vintage Park tools plus an old Helicomatic tool plus a box. Not a terrible deal.
