3 spoke track wheels ok?
Looking to buy a new race wheel set and found a decently priced 3 spoke tubular wheel set. I’ve never used 3 spokes before, are they stiff enough for use in points race, elimination race and the like?
Or is it better to stick with more normal wheels like carbon rim 50mm ish and 20/24 spokes?
there are a lot of 3spokes out there of varying quality.
The most common is the dupont/specialized design (HED3) which are good wheels but built on the old "narrow is aero" philosophy where tire selection is critical to them being aerodynamic. (with wider tires they often test worse than standard box section wheels)
The general communal thoughts on the 3spoke for track is it's good for timed events (pursuit specifically) but not stiff enough for sprinters. Events in between kinda depends on the rider.
Another thing to consider is if you're riding an outdoor track double trispokes can be a little twitchy in some wind conditions. Depending on your group riding prowess you might not make a lot of friends in bunchie races on them.
I ran a trispoke (light bicycle, based on the Revolver design) for all the events at masters nationals this past week at T-town. The gamut of wind conditions, and at no point did I have stiffness or twitchiness issues.
I'm not a true sprinter, but I am 185lbs, for what it's worth.
My only other points of reference are a deep (88mm) conventional spoked wheel, and a FFWD 5-spoke, and both are far twitchier in the wind. I'm not sensitive enough to notice any stiffness differences between the three.
End of the day it likely comes down to the specific wheelset you're considering, not something inherent to trispokes.
^The design of 3 spokes (in regards to stiffness) is the issue. It's why mavic developed the iO as 5 spoke vs. their 3G wheel for sprinters.
I agree with your assessment for the most part though as for the majority of us we aren't breaking chains or worrying about stem / bar stiffness either.
Quoted: 1851 Post(s)
Liked 679 Times
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
Been there - (waiting on DHL that is ) Hopefully those wheels will serve you well
For future reference if it ever comes up or you need to borrow a wheel for an event or something, rest assured that the 3 spoke will be fine too - ive never had the outcome of an event decided by whether i was using a 3 spoke or a 5 spoke, and i have both
With clearances like this, any issue with stiffness would show up in the form of tire scrub too
Bikes: Allez sprint, Planet X, Langster pro, langster atlantis, epic expert, toyo Godzilla, starck pista, Medici pro pista, volume thrasher, scepter
Trispoke feels faster and looks badass
