View Poll Results: Your Max Power
11+ full enchilada
7
38.89%
lower gear + higher rpm
11
61.11%
Voters: 18. You may not vote on this poll
Max Power
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
In the real world, your speed is your speed. In Zwift if your trainer misses picking up a few rev's in your cadence in a sprint that could mean you wind up going slower. In real life you still go whatever you're going to go, the reading on your meter might just be different.
All things Zwift is a grain of salt and usually not what is optimal in real life.
If you care about such things, I think the best thing to do would be to join one of the numerous Z1 "stay together" group rides where they lap a flattish short course like London or Richmond with the sprint banners. Then they turn off the banding for the sprint. Try stuff out. Try different postures or ways of racking the bike on the trainer for Zwift. See what you can get.
In Zwift I can't figure it out. I'm always a solid 300w or so less on my peak and probably 400w less on my "hold" when sprinting. So, any Zwift racing ending in a sprint I'd just not make out too well.
Zwift is also a grain of salt as DCRainmaker said he gets funny figures on some smart trainers for sprints. Then he has given the feedback to the vendors who claim to do firmware updates.
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
Lots of NFL lineman have legs way stronger than Usan Bolt. But could dust them running at any distance easily. Tells me power is about efficiency and task specific.
pan y agua
Quoted: 1447 Post(s)
Liked 724 Times
In my experience you can “game” max power on a power meter for a second or two with a lot of torque in a big gear. However, I think it’s mostly a measurement error.
Real world, start out in a gear you can turn 100rpm. Shift up one. when you start feeling that spun out, bang one up shift, get on top of that, and before you spin it out the race is over.
You could get lost and die.
You could hit a tree and die.
Likes For merlinextraligh:
Stupid question: How do you accurately measure your cadence on Zwift or on any other indoor cycling application?
My trainer reports some sort of generic cadence with delays of 3-5 seconds in updating and it is also very dependent (some +/- 20%) on my position on the bike (standing vs on the saddle). A cadence sensor mounted on the crank does not do a much better work: just that its reading does not depend on my position, but the delays are long and its jumps between figures have nothing to do with real life, where it sends a smooth and very consistent reading to a Gamin device.
Quoted: 2482 Post(s)
Liked 2,952 Times
I know next to nothing about how the software works, but BigRing VR has a "Preferences" section where, among other things, you can change the frequency of cadence updating. I just leave it at the 3-second setting.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4387 Post(s)
Liked 3,016 Times
Liked 3,016 Times
My sprint power won't impress anybody, and personally I don't pay much attention on the road, as I don't race, but I do care on Zwift. For a while, I couldn't break 600 watts for a 5 second sprint, but then one day I was in an easier gear and I did 650 W. Normally, my sprint was at 95 RPM, but the better power was at 105 RPM. Lesson learned.
I'm somewhat encouraged by the people saying they get higher power on the road than on a trainer. Maybe my 5 second power numbers aren't as pathetic as I've assumed. (I'm 72 kg)
Liked 3,016 Times
Quoted: 18883 Post(s)
Liked 10,646 Times
Your pedals can't be wrong (about cadence) by much and still hit the +/- 2% accuracy spec. Or whatever it is for yours specifically.
@RChung knows more about this than anyone and pointed out the that one second every few rides where I'm doing 140 rpm but not really isn't the only time it ever makes a mistake. He uses PMs differently than most people and needs more precision, for practical purposes you can just treat your pedals' cadence as right and bob's your uncle.
Perceptual Dullard
Quoted: 918 Post(s)
Liked 1,149 Times
Not just accelerometer-based cadence can be off. I used to have a reed-switch sensor for speed and it used to go crazy occasionally, where I'd see speeds of a couple hundred km/h for 2 seconds. So I examined my data files and realized they all occurred on a certain route, a particular distance from where I'd habitually hit the lap button. So the next time I went out that way, I counted that distance from the place where I hit the button and right there in the middle of the road was an understreet power vault. That power vault was leaking EM and it was interfering with my sensor. I bet the FCC didn't like that. Maybe not the public health dept, either. You can find out some interesting things if you pay attention to when things go wacky.
Likes For RChung:
Quoted: 1851 Post(s)
Liked 678 Times
Likes For topflightpro:
