Anticorrosion for frames
Hi all
What do you use as anti corrosion coat for internals of frames?
Any advice?
Any advice?
Quoted: 803 Post(s)
Liked 2,981 Times
Are car products for same will work fine? Some of them have wax in them they good or try to find without wax?
Bikes: HVZ Meteor 1979, HVZ Champion 1962, HVZ SS Moskva80 1981, Dürkopp 1936
Quoted: 41 Post(s)
Liked 350 Times
Good quality car cavity wax should also work fine, brands like Teroson for example.
Catching Smallmouth
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 88 Post(s)
Liked 134 Times
Linseed oil mixed with mineral spirits inside the frame tubes.
Likes For BradH:
Quoted: 834 Post(s)
Liked 2,126 Times
This Zombie Thread is worth a read. Make sure you scroll through to the end.
https://www.bikeforums.net/classic-v...atments-4.html
(If you just want a product name, and don't want to be bothered reading through that thread: Try Corrosion Block. I haven't tried it, personally, but that's what I plan to use the next time I treat a frame.)
Bikes: too many
Quoted: 411 Post(s)
Liked 234 Times
Linseed oil with mineral spirits (to improve initial flow and coverage of the linseed oil) would be like bicycle concours correct for say a pre-80's resto. Linseed oil is/was recommended for garden and carpenter tools, BITD, if me remembers correctly.
Quoted: 964 Post(s)
Liked 1,451 Times
I'm going to get flak for this...
Has anyone actually had a frame fail from internal corrosion? I think the concern may be overblown.
Yes, I've seen some bikes rust through. From things stuck down the seat tube to make it collect water. And there was one honestly-rusted-through frame in a thread a few months back, in southeast Asia, I think. Looked like it had lived a very hard life, perhaps always outdoors or laid on the floor of a leaky shed. But your average frame, well cared-for? I doubt it's a concern.
