Picked up a set of rollers
Henderson, NV
Bikes: Trek Alpha 3700, GT STS DH, Raleigh Grand Prix, Fisher Montare, Fisher CR-7, Fisher Aquila, Diamondback Sorrento, The Bike Beat Revolution, KHS XC 504R
Quoted: 322 Post(s)
Liked 597 Times
Found these roller locally for cheap.
I'm going to give them a try for training. Put my Dawes on them and they seem to be hard to get rolling.
Can the roller resistance be loosened?
We'll see how this training goes......
Bikes: Pinarello Gavia TSX; Bianchi Intenso
Quoted: 167 Post(s)
Liked 92 Times
I don’t see a resistance unit on those rollers? Also they do not look to be set long enough for the wheelbase of your bicycle.
Henderson, NV
Quoted: 322 Post(s)
Liked 597 Times
Quoted: 1105 Post(s)
Liked 1,825 Times
Fold up an old towel and place it under the rear roller drum. You can adjust the resistance by folding the towel thicker or thinner. As for correct sizing, hang a string with a weight on it from the middle of the front axle, it should strike a line with the middle of the drum.
Likes For nomadmax:
Quoted: 472 Post(s)
Liked 1,056 Times
Give it time. Be persistent. I find they’re worth it.
Likes For Prowler:
Quoted: 167 Post(s)
Liked 92 Times
Rollers look to be alloy. If that is the case, consider Neodymium magnets for resistance.Don't need the friction from the towel.
Likes For gkamieneski:
Henderson, NV
Quoted: 322 Post(s)
Liked 597 Times
I wasn't looking for more resistance. I was looking at less resistance for easier cadence.
Bikes: yes, i have one
Quoted: 1144 Post(s)
Liked 1,187 Times
How much resistance if you spin each drum by hand? No rubber band of course. Maybe one or more bearings needs some work?
Henderson, NV
Quoted: 322 Post(s)
Liked 597 Times
Thanks for the suggestions.
I adjusted the rollers and moved the front roller up two spaces. They spin freely by hand now.
Sold the Dawes Lightning 1000 so I will be trying the rollers with my mountain bike.
Quoted: 472 Post(s)
Liked 1,056 Times
Good. Nice roller set (I prefer solid metal stuff vs “modern” plastic and rubber. I hope your mtn bike tires are pretty smooth. Many folks find that mtn bike tires are too rough on smooth rollers and too noisy. You can buy street tires if needed. At least get mtn bike tires with a continuous line of solid tread down the center.
This never occurred to me as I use a drop bar road bike on mine: if someone rode a more upright mountain bike on rollers (less weight on the front wheel) would the bike behave badly? If you rode a classic long TT and long stem mtn bike it may be fine. Let us know how the mtn bike works. Post photos.
Quoted: 167 Post(s)
Liked 92 Times
Maybe it's just photo perspective but your last photo seems to show the middle and back roller an awfully far apart. They look to be very good rollers. I like the measurement scale on the front roller position.
Now that you've got them spinning freely, I will bet you will be considering resistance. Smooth rollers without resistance are great for warming up or cooling down at the velodrome, but for training, you'll soon want to be able to add to the load. If they should stop spinning smoothly, most rollers use fairly common sealed cartridge bearings and can be easily replaced.
Quoted: 1463 Post(s)
Liked 1,487 Times
I can get a good workout spinning on no-resistance rollers, but need to really ramp up the cadence. Rollers are great for smoothing out your pedal stroke and require a lot of concentration/balance and ability to maintain a good line. I think they helped my riding quite a bit at the beginning, but after a while I got bored with them and switched back to my regular trainer.
In a perfect world, I'd have controllable resistance rollers that worked with Zwift (and attached to something like a Kickr Climb to simulate grade). I'm sure it's coming.
I've got some really crappy tires (kenda kwick roller sport 32mm, that came stock on one of my bikes) that provide a crazy amount of resistance on the rollers (almost half the speed at the same power level as a pair of 4000 GTs 23mm). There are lots of different ways to add resistance if you get to that point.
Bikes: Garmin/Tacx Bike Smart
Quoted: 646 Post(s)
Liked 289 Times
I rode a set of Kreitler rollers for about 20 years. Once you get the hang of it they're OK. Hint: get a couple extra belts. ;-)
Likes For dmanthree:
Bikes: two blacks, a blue and a white.
Quoted: 445 Post(s)
Liked 848 Times
Be near something you can reach out and grab, like a railing. Don't watch ride videos made with a helmet cam - if creator turns their head, I always flinch, sway and sometimes slide off sideways. get a box or a couple 5/4 thick boards to step up on for mounting.
Likes For blacknbluebikes:
Henderson, NV
Quoted: 322 Post(s)
Liked 597 Times
I tried my rollers with a Dawes Lightning and was able to ride..OK.
I sold my Dawes so I decided to try my Trek MTB on them.
The tires were kinda low. I started spinning and in short time caught myself before falling to the ground.
Going to give it another go after I air up the tires and move the front roller to the last mounting spot. I'm sure something better than knobby tires would roll better.
Reference pics only. The rollers are usually out back on our patio area.
Henderson, NV
Quoted: 322 Post(s)
Liked 597 Times
Well.....called it quits.
Sold the rollers. I was able to ride but never felt comfortable.
I fell a couple of times and my wife said I was going to hurt myself. So, off they went.
Likes For Desert Ryder:
