What tires do you tour on?
Old 03-09-05, 11:09 PM
John00
Bikes: 2 TiSports and a Ho Ko E Koo
Quoted: 53 Post(s)
I'm looking at tires for my 26" wheels. I have found tires from 1", 1.2" 1'3" up through 2" Some weigh as little as 250 grams up past 600. I want as fast a tire as possible, I'm used to 23 mm tires on my road bike. I found some 26" Continental Grand Prix 1' wide, 25mm. recommended as long wearing, puncture resistant touring tires over at biketiresdirect.com. I'm not planing on any off road riding, but I know sometimes it's unavoidable. Is 25mm too small? I'm not worried about ride comfort as my bike has a shock in front and a small 1" pivot less shock in the rear. I'll be pulling a BOB trailer with no extra weight on the bike.
What size tires do you use?
I've been considering these tires
http://www.biketiresdirect.com/produ...=Touring+Tires
John00 is offline
Old 03-09-05, 11:46 PM
Machka
In Real Life
Machka's Avatar
Bikes: Lots
Quoted: 2876 Post(s)
Liked 77 Times in 55 Posts
I used my Conti 1000 sport tires (700x25) ... same as what I use for Randonneuring ... same as what I use for training.
Machka is offline
Old 03-10-05, 11:18 AM
David in PA
Bikes: Cannondale C400
Hello,
I'm very curious to see the responses you'll receive on this one. My tires are also 26", fairly wide, not knobby. I've had only one flat in about a couple thousand miles. They hold up well with a full touring load, including camping gear, and provide good stability.
It seems though that it takes extra effort to pedal them around. I'd like to get tires that reduce this effort but still have the benefits I described.
Wolfy
David in PA is offline
Old 03-10-05, 11:19 AM
denisegoldberg
denisegoldberg's Avatar
Bikes: Peter Mooney (touring), Bike Friday Pocket Rocket (road), Bike Friday Air Glide (touring)
I've used Conti Top Touring 700 x 32 for fully loaded touring - 4 panniers, including camping grea, and Conti Top Touring 700 x 28 for less loaded touring (rear panniers only, no camping gear).
denisegoldberg is offline
Old 03-10-05, 11:54 AM
PurpleK
Velocipedic Practitioner
Bikes: Specialized Sirrus, Bianchi Volpe, Trek 5000, Santana Arriva tandem, Pashley Sovereign, among others
I've never had any problems with 700X28. However, my tours have never been longer than ten days and I seldom carry more than a set of rear panniers. Except for a gawd awful stretch of gravel highway near Parnu, Estonia, I've never been off pavement on a tour, so a wider tire may be better if there will be any unpaved riding.
PurpleK is offline
Old 03-10-05, 11:57 AM
Schumius
senile member
Bikes: 1 mtb converted for commuting (actually, collecting dust in the garage), a LHT with "durable components"
i toured with 1.95"s, but it was a pain to move around on paved road so i'm thinking about 1.75 for the front and 1.95 for the rear, think that it would improve the situation a bit. the reason why i'm not going with all 1.75s is that i'm doing the outback oz this year so it could be that 1.95 rear would be more suitable, i could be wrong though.
Schumius is offline
Old 03-10-05, 12:18 PM
acantor
Macro Geek
Bikes: True North tourer (www.truenorthcycles.com), 2004; Miyata 1000, 1985
Quoted: 29 Post(s)
Before the age of Kevlar-lined tires, I used 23 mm slicks when touring with only rear panniers. I usually got one flat per tour. These tours typically lasted ten to fourteen days. On its final tour with new tires and tubes, I had no flats. I did not stray from paved surfaces often, but I had no problems when I took the occasional logging road or pebbly country lane.
My new bike has Kevlar-lined tires. I heeded the advice of the bike builder, who recommended that I go for 28 mm tires. I am sure that they are not as zippy as 23 mm tires, but honesty, I do not notice the difference with 8 or 10 kilograms hanging off the bike. I do feel slightly more stable on gravel roads and cobblestones, but I still ride carefully on unsmooth surfaces. My bicycle was designed for touring on roads, not mountain trails.
Kevlar-lined tires are not immune from punctures. I got a flat on the second day of most recent tour while walking my bike along a sidewalk!
Alan
acantor is offline
Old 03-10-05, 01:32 PM
valygrl
Quoted: 163 Post(s)
On my first tour, I used a MTB with 1" Specialized FatBoys. These are just plain slicks. I was towing a bob at first, then switched to panniers. I got a few rear flats, and they wore out in only about 2000 miles. I didn't like them much - too many flats.
Since then I've been riding a tour bike w/700C wheels. I used the stock IRC's for an amazing 4500 miles (rear) and rotated the old front onto the rear, where it now sports a total of 6000 miles, and it's still ok !!! On the front I'm using a Conti TT 32mm, and it's doing ok after about 2000 miles, just starting to show wear. Neither of these tires perform well on gravel. I'm still looking for the perfect tire w/low rolling resistance but that doesn't drop you in the dirt.
Cheers,
Anna
But I'm pretty small, I think that makes a huge difference.
valygrl is offline
Old 03-10-05, 02:19 PM
Rogerinchrist
Rogerinchrist's Avatar
Bikes: TREK-520 & 830
Schwalbe Marathon or Marathon Plus .
Rogerinchrist is offline
Old 03-10-05, 02:45 PM
CdCf
Videre non videri
Bikes: 1 road bike (simple, light), 1 TT bike (could be more aero, could be lighter), 1 all-weather commuter and winter bike, 1 Monark 828E ergometer indoor bike
Haven't toured yet, but I just (today!) mounted 1.3" slicks on my MTB that I'm slowly making into a touring bike.
CdCf is offline
Old 03-10-05, 09:22 PM
Desertrat
Bikes: Co-Motion Americano, Rivendell touring
I have real good luck with Panaracer Paselas....700x37....for full loaded, 4-pannier touring.
Desertrat is offline
Old 03-10-05, 09:27 PM
tvphobic
Bikes: TiSport Road frame with Campagnolo Daytona/Centaur + Record/Open Pro wheels || 2002 Bianchi Volpe || 2003 Giant TCR 2 w/ Sun-Ringle ME14A rims/Ultegra 6500 hubs/ Bianchi SL Centaur (currently being refurbished)
I like Pasela too, but "TG" or "Compe" or whatever it is. The standard Pasela is too light and flats on a paper-staple, at least in the 28-32 I've used. I really like the Vittoria Randonneur... tough. Haven't tried the Armadillo, etc.
tvphobic is offline
Old 03-10-05, 10:24 PM
operator
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 31 Post(s)
Liked 6 Times in 6 Posts
How's the flat situation with those tires?
operator is offline
Old 03-10-05, 11:21 PM
Machka
In Real Life
Machka's Avatar
Bikes: Lots
Not bad. I change them every 3000K to 4000K, or so, whether they need it or not ... or in other words, I go through about 6-8 tires a year.
While I was touring in Australia, I covered 5000K, and I replaced both the front and the rear tires about half way through my time there. But in total I had 3 flats, and 1 of those was a "repeat" flat - where I didn't fix it properly, and it flatted again a little ways down the road.
Machka is offline
Old 03-10-05, 11:55 PM
velonomad
Older I get, Better I was
velonomad's Avatar
Bikes: '14 BD Lurch Fatbike, '10 homemade road,'03 homemade tourer, '94 Yokota Tandem, '88 homemade MTB
Quoted: 34 Post(s)
I have good experince with the IRC metro's in 26 x 1.5 with the kevlar belt I usually get a little more than 2000 miles from them. I have them on two bikes and a MTB tandem,
velonomad is offline
Old 03-11-05, 12:52 AM
bacardi
bacardi's Avatar
Bikes: Pluto R ebike
Liked 2 Times in 1 Post
I just switched from 1.95's to 26 x 1.5 City Slickers. A noticable difference in speed and handling. As for touring on them, time will tell.
bacardi is offline
Old 03-11-05, 02:21 AM
Juha
Formerly Known as Newbie
Juha's Avatar
I will second the Schwalbes.
--J
To err is human. To moo is bovine.
Who is this General Failure anyway, and why is he reading my drive?
Become a Registered Member in Bike Forums
Community guidelines
Juha is offline
Old 03-11-05, 07:23 AM
wheelin
This is very close to my reccommendation. Since you asked for 26", go for 1.25 Panaracer Paselas. Never ever use 1" tyre for touring.
wheelin is offline
Old 03-11-05, 11:53 AM
ilse
i third the shwalbs. I've got the marathon touring, and though i've only commuted with them as of yet, I've gone through loads of broken glass with a heavy pack strapped to the back, and not a single flat. They don't even deflate as quickly as other tires. The tread is far more capable on wet pavement without too much rolling resistance. A little heavier than most tires, but with all the glass that's unavoidably strewn between my home and every place else in town - it's an absolute miracle that I've not had a single flat. They're not the easiest to put on, either, but are so tough, changing a flat will be a very rare event. by the way, the kind i have are equipped with some kind of patented material, not kevlar, but whatever it is, shwalb boasts that you could ride through thumbtacks unscathed!
ilse is offline
Old 03-12-05, 05:51 PM
Ken Brown
cycling fanatic
Ken Brown's Avatar
Bikes: Cannondale T800
Quoted: 12 Post(s)
700x38 - perfect for a loaded bike. Never had a flat.
Ken Brown is offline
Old 03-12-05, 07:41 PM
wheelin
I find that a partially deflated tyre is very likely to cause flat. Please keep your skinny slick inflated to rec. spec. every morning before you start out, and lube the chain at the end of the day.
wheelin is offline
spectastic
Bicycle Mechanics
4
07-05-19 06:39 PM
phantomcow2
Foo
0
09-26-08 02:08 PM
