Mid drive motor install on Schwinn Loop bike
I recently purchased a 20" Schwinn Loop folding bike. I would like to install a Bafang Mid Drive electric motor. Has anyone successfully installed a mid drive motor on the Schwinn Loop bike? I am interested in clearance and fit when placing the motor on the bottom bracket housing before purchasing this electric motor. Any information would be greatly appreciated. Thanks in advance.
LET'S ROLL
I don't think you can install mid drive motors on bikes. Mid drives are designed from the beginning to be that way.
To modify your non electric bike; the labor/machining would probably cost more than the bike and motor combined.
Options would be a motorized front or rear wheel. There are also motors that spin the wheel thru friction; like the old
dynamo lights.
dynamo lights.
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
55+ Club,...
Bikes: 9+,...
Quoted: 1114 Post(s)
Liked 848 Times
Actually, bafang makes mid drive motors to install on any bike. All you need to do is remove the crank arms/bottom bracket, and then install it.
https://lunacycle.com/bafang-bbs02-750w-middrive-kit/
My only issue is the quality, or reliability, of a Schwinn Loop. I'd recommend a better folding bike.
It's not a good project IMO. The BB shell is fit oddly in a mess of tubes which will probably interfere with the motor, plus I wouldn't trust that frame and brakes to handle the power. Those BBS mid-drives are FAST.
Quoted: 340 Post(s)
Liked 275 Times
The BBS02 normally sits parallel to the ground on most bikes, as the lower downtubes usually swoop upward with sufficient angle to allow that. I have one on a regular mountain bike,
If this Schwinn Loop is like your folder, the horizontal downtube would force it to hang perpendicular to the ground. It will also probably keep you from fully lowering the seat for transport as the seat probably hits the motor.
The lower part of the motor will extend 6 inches from the centerline of the bottom bracket. On my folders that would leave it 5" above the ground. I don't know if that could hit anything.
Lunacycle puts their BBS02 on a Mossa folder. It hits 25 mph easily. Don't know if the Loop is going to feel good going that fast.
55+ Club,...
Bikes: 9+,...
Liked 848 Times
I only posted the link to Lunacycle as a reference for typical BBS02 mid drive kits, so it's not the exact spec'd mid drive kit the OP plans to use. But, installing ANY mid drive kit on a Schwinn Loop is a seriously bad idea. Poor frame strength, inadequate brakes, etc,...
Shopping sequence, may have it backwards ... motor as a forethought rather than an afterthought ..
your choice may be more suitable for a front wheel motor..
Thank you, everyone, for the info, insight, and recommendations. I value your input. Apparently, the mid drive motor install will not be a good option for the Loop bike. I am more interested in some type of pedal assist, not so much for speed. Any recommendations for a front or rear wheel drive motor?
Quoted: 340 Post(s)
Liked 275 Times
I am using the the Q100H from Bmsbattery.com on our two folders, At ebikes.ca, you can get a Bafang G311 motor on a 20". wheel, However, I believe that you can buy a inexpensive folder, like the Ancheer 20" for about $600, and that will be less than what it costs you for a kit, battery and the Schwinn Loop, and it will have an integrated battery. The rest of us are having to hang batteries on our frames.
Quoted: 340 Post(s)
Liked 275 Times
We were looking for a step-thru folder to convert to electric, and the only models I found were the Loop and the CItizen Barcelona. Wanted to do a rear motor, so picked the Loop because I would be tossing out the nice geared hub on the CItizen, Bought the Loop last year on ebay for $240. Boo om tariffs. This used to be a $200 bike,
My initial ride of the Loop last year didn't have it feeling too bad except for tiny brake levers and sloppy rim brakes. Installed a 250W motor on the rear, but it was a bit wide, so had to use a 6 speed freewheel out of spares bin, Electric bike brake levers were full size. Still using the 7 speed barrel shifter. My wife understands them better than trigger shifters. Top speed with motor only is about 20 mph, Replaced the 42T crank gear with a for a 52T from my parts bin. It barely clears the chain stays. Put on a softer seat.
The most effort was replacing the stock one piece steerer with a telescoping unit. That turned out to be too long, so I had to cut it, and put in new slots and relief holes. It's still too long, and I used a heavy steel handlebar from parts bin. I did a half mile test ride and while the electrics work fine, the steering is a lot twitchier than I remembered. I noted that the wheelbase appears 4-6" shorter than our Downtube folders.
I'll have to go back to the original steerer and see how that feels, This is only for sedate senior riding, so I'll have to make sure the local hills don't cause trouble,. I find it kind of nice for getting on/off. Last fall I dismounted my trusty Trek 830 and got my pants leg caught on the luggage rack. Would have been a embarrassing tumble.
Bikes: Trident Spike 2 recumbent trike w/ e-assist
Quoted: 1321 Post(s)
Liked 374 Times
You can put a front hub motor kit on that Schwinn if you really want to use that bike. Grin Tech., Hill Hopper, etc. Complete kits. You can also purchase the Swytch for it. Lots of info on front hub kits in the e-bike forum. But, as was stated, if you want to go fast instead of pootling around, you want a bike that rides well at higher speeds to put the motor on.
Quoted: 350 Post(s)
Liked 122 Times
I've never used a motor, but I've read that since more weight is on the rear wheel than the front wheel, you'll get better traction if you put the motor in the rear wheel. I think there were some threads about how the front wheel motor lost traction on wet or bumpy surfaces and spun out or fell down.
Liked 374 Times
I do indeed have a motor I use with both my Bike Friday pakit and my Dahon Mu Uno. It's not a hub or mid-drive (OneMotor friction drive). Since folders typically do better with a little more weight up front, if your system isn't all that heavy (a hub motor of around 3-4lbs maybe) then a front wheel would be fine. Unless you gun the crap out of it going up a hill, it won't be a problem. A 250-350w system is fine up front; if you install a 500+w system it should definitely go on the rear. That said, a rear mount can be fine if your battery placement can balance out the weight of the hub in the back. I would not recommend hanging the battery high off the saddle, which I have seen some folks do. Try to place it on the main tube if possible. Keep in mind if your seat has to drop to fold the bike, then a seat post battery will not be as convenient, either.
Quoted: 340 Post(s)
Liked 275 Times
I cut my new steerer tube and dropped the bars on my electric Loop to the same height as the original Shchwinn bars. Took it for a test ride and saw that I could ride it no hands, so the twitchiness is no longer a concern.
I changed the tallest gearing to 52T14T, originally 42t/14T. It's not enough for me, but I believe my wife won't mind. I was still swinging my leg over the saddle, but when I put my mind to it, it was easy to use and appreciate the step-thru-ness pf the bike, I'll post a pic in a new thread.
