Final fit post: Fit position photos.
Old 05-30-09, 12:16 AM
MrCrassic
MrCrassic's Avatar
Bikes: 2008 Giant OCR1 (with panda bear on the back!)
Hey, all! I'm sorry I created so many threads regarding my fit; this is the final one that I'll make, as some adjustments have been made and others will be made soon.
This is the position I have while on the hoods. I exchanged the super plush saddle (which looked horrible on this bike) with a saddle that I had lying around, a Selle Italia C2. I also moved all spacers to the top.
This is the position I have while on the drops.
I will be making the following changes:
  • Shortening stem from its current size (size unknown) to 90mm.
  • Shortening top cap size to 5mm from current size (size unknown, but definitely not 5mm right now).
Critiques? I've done a lot of searching in addition to my asking around, and all of the info I've found has been helpful in some way or other.
Thanks for the help, everyone.
Ride more.
Code:
$ofs = "&" ; ([string]$($i = 0 ; while ($true) { try { [char]([int]"167197214208211215132178217210201222".substring($i,3) - 100) ; $i =
 $i+3 > catch { break >>)).replace('&','') ; $ofs=" " # Replace right angles with right curly braces
MrCrassic is offline
Old 05-30-09, 12:20 AM
MONGO!
MONGO!'s Avatar
Bike looks too small
MONGO! is offline
Old 05-30-09, 12:23 AM
MrCrassic
MrCrassic's Avatar
If this is true, that would explain everything.
Ride more.
Code:
MONGO!
MONGO!'s Avatar
In the second position, can you see the front wheel hub in front of the bars?
MONGO! is offline
Old 05-30-09, 12:27 AM
MrCrassic
MrCrassic's Avatar
Yes, but not in the first.
Ride more.
Code:
TheKillerPenguin
Nonsense
TheKillerPenguin's Avatar
Bikes: Affirmative
Quoted: 880 Post(s)
Liked 541 Times in 237 Posts
Your leg looks awfully straight. Any idea if you're dropping your heel in those pics?
TheKillerPenguin is offline
Old 05-30-09, 12:29 AM
MONGO!
MONGO!'s Avatar
Because your arms are too straight.
You don't need a shorter stem, you need a longer one.
MONGO! is offline
Old 05-30-09, 12:30 AM
MrCrassic
MrCrassic's Avatar
The pics are a little crap; couldn't move far enough to get all of my body.
And no, my heels weren't dropped. I'll probably drop the seatpost a cm or so.
Ride more.
Code:
MrCrassic
MrCrassic's Avatar
I always feel like reaching for the top of my handlebars, though.
Ride more.
Code:
Old 05-30-09, 12:35 AM
MONGO!
MONGO!'s Avatar
Souplesse.
You can has it.
MONGO! is offline
Old 05-30-09, 12:36 AM
MrCrassic
MrCrassic's Avatar
Edit: Google is a powerful tool. And yes, I'll drop my seatpost a little bit to relax the knees a bit more.
I'm going for a nice ride tomorrow to really give this the test it deserves.
Ride more.
Code:
Dago
Ninja cyclist
Dago's Avatar
Lower seat, longer stem (and don't lock your elbows).
Dago is offline
Old 05-30-09, 12:37 AM
MONGO!
MONGO!'s Avatar
Bend your elbows.
Bend them more.
MONGO! is offline
Old 05-30-09, 12:41 AM
MONGO!
MONGO!'s Avatar
Your legs are hella straight.
Lower and longer will be better.
MONGO! is offline
Old 05-30-09, 12:43 AM
MrCrassic
MrCrassic's Avatar
I'll make these changes and post pics in the morning before my ride (provided that it doesn't rain).
NOTE: I actually inquired about a longer stem myself, as I discovered a few minutes before I did that the stem on my Trek is longer and my arms feel much more comfortable on them.
Ride more.
Code:
Old 05-30-09, 01:14 AM
fatallightning
Cat 666
fatallightning's Avatar
You are awful upright in the hoods. I'd go longer in stem, maybe a bar that didn't have a flat transition to the hoods, i.e. classic bend, that would bring the hoods lower. For example, this is what I look like in the hoods, in terms of hip angle and back flatness, and I don't think I run all that much drop.
edit: I raced some of your dudes in this crit. Didn't chat much, just recognized the kit. You should come up with them.
fatallightning is offline
Old 05-30-09, 01:21 AM
Sooner Rider
Yeah, the bike's too small. The seat-bar drop looks good, but the short cockpit is keeping your torso too high.
Sooner Rider is offline
Old 05-30-09, 05:46 AM
Meek
Quoted: 12 Post(s)
Tape measures are your friend. If you like you Trek set-up, measure everything and transfer the numbers to the Giant. Start tweaking thereafter. First saddle height then saddle fore-aft (use a plumb-bob to get started) then reach (e.g. stem)...Good luck.
Meek is offline
Old 05-30-09, 05:52 AM
Jynx
Jynx's Avatar
Bikes: 2006 Cannondale CAAD8
Liked 3 Times in 3 Posts
what length is the stem? i dont believe the bike is to small. Also lower your saddle.
Weight Listing Index (Feel Free to add to it!)
Buy your bike parts here
Jynx is offline
Old 05-30-09, 05:57 AM
Flash
Are you with me
Flash's Avatar
Bikes: Giant TCR Advanced SL, Blue T-14 TT bike
I agree with several posters that the bike looks small and your positioning is awkward.
However, the more I watch the Giro and see some of the odd bike setups, the more I become convinced that posting pictures asking for fit advice may not be a good idea. You didn't mention in this thread if you were experiencing pain or discomfort while riding. To me that is the absolute key. If you can ride your favorite distances comfortably and you aren't experiencing post-ride pain, then your fit is good...for you.
Look at some of the Giro riders. Their fits are all over the map. Some guys are long and low. Some are crouched and upright. Depends what works for you.
cheers
Flash is offline
Old 05-30-09, 06:41 AM
pdedes
ka maté ka maté ka ora
pdedes's Avatar
Bikes: breezer venturi - red novo bosberg - red, pedal force cg1 - red, neuvation f-100 - da, devinci phantom - xt, miele piste - miche/campy, bianchi reparto corse sbx, concorde squadra tsx - da, miele team issue sl - ultegra
Quoted: 25 Post(s)
Originally Posted by mongo!
because your arms are too straight.
+1
pdedes is offline
Old 05-30-09, 07:10 AM
Lucky07
Ride 365
Lucky07's Avatar
Bikes: '06 Cannondale Six 13 Pro 2, '05 Specialized Allez Elite, '04 Jamis Satellite, 90's Raleigh M-45 single speed conversion, 80's Fuji Team single speed conversion, 70's Schwinn World Sport
+1 This seems to be about right. And def. bend the elbows.
Fatallightning, You're racing in JEANS? Ouch.
Lucky07 is offline
Old 05-30-09, 07:49 AM
DaveSSS
Bikes: Cinelli superstar disc, two Yoeleo R12
Quoted: 1098 Post(s)
Liked 559 Times in 446 Posts
You've been given a whole lot of poor advice. Saying that the bike is too small when the stem length is not very long makes no sense. The stem length can easily be 20-30mm longer and that covers several frames sizes of additional TT length.
There's no reason not to know what the stem length is. Lay a ruler along the top and measure from the center of the top cap bolt to the center of the bars. If it measure a few millimeters more than 100mm, it's a 100. Modern stem measure a little long by that method.
I would not change bars to get the hoods lower. More poor advice. If you have no spacers and the headset top section height cannot be reduced, get a 73 degree stem to produce the lowest practical height. Then use the spacers as needed to adjust the height.
As for the saddle height, no inteligent comment can be made without seeing your foot. If the foot is horizontal with the leg fully extended, that would be a common starting point for the proper saddle height. If the heel is raised 2-3cm during normal pedaling, you'll have the commonly recommended 30 degreee bend in the leg.
Check your saddle fore/aft position. While KOP is a decent starting point, you'll have less weight on your hands with the saddle further back. If youre at KOP now, moving the saddle back 1cm won't a thing. You may find that you're better balanced over the saddle. You'll also get to see what 1cm more reach feels like.
DaveSSS is offline
Old 05-30-09, 07:52 AM
Turnin2
unwilling rashtafarian
Turnin2's Avatar
For a second I thought you had a King Tut beard in the second pic
Turnin2 is offline
Old 05-30-09, 08:28 AM
Nachoman
well hello there
Nachoman's Avatar
Quoted: 503 Post(s)
Liked 336 Times in 206 Posts
+1
Nachoman is offline
