Road bike gearing?
#51
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1939 Post(s)
Liked 1,461 Times
It's too bad that triples are essentially extinct. That allows close ratios along with very low gears.
I use my 34-32 low gear even on moderate grades. It's nice to have the choice to spin up the hill at 80-90 rpm.
And the 34-32 low lets me stay seated on 10-12% grades, where I would have to stand up with higher gearing.
14-32 cassette!
A few years ago, I got this idea from a BF thread: 50/34 front and a custom 14-32 rear. The link explains how to build it from a 11-32 and 14-28.
It was perfect for my fast-for-me group rides that also had some steep climbs. I had really close shifts from 18-24 mph, and the low climbing gears. I would spin out at around 30 mph, which was fine.
It's probably not too practical without electronic shifting -- in the 34 ring, the shifts are so close together that I would usually shift two cogs at a time. And I would shift the chainrings a lot more than with a wider range 11-32. To match cadences, a chainring shift needs 4 or 5 shifts in the rear, instead of the usual 3 shifts! Easy with electronic shifting.
Now, with smaller, less competitive groups, I'm back to 11-32, so that I have some high gearing to soft pedal on longer downhills.
14-32 cassette!
Bike Forums - View Single Post - Custom 12-28 cassette
#52
Quoted: 4384 Post(s)
Liked 4,824 Times
OK, another side thought. The trend is to easier gears, the days of the 53 chainrings and bigger are behind us - not saying it not ridden anymore, quite a few still have those rings but they are looked upon as not getting the message.
How does that trend square with the pretty well parallel trend to ever smaller cogwheel on the back, 12 to 11 and now to 10, where it probably has to stop, not because that would be enough but mechanical reality simply kicks in at this point.
And you bet that everybody with 30+ cogs on the back will try to merry (spelling?) it with the 10 on the small end. DOH
If you need that big plate on the back, maybe it is time to switch to triple chainrings on the front instead?
#53
At some point an additional small, very light weight, chain ring in the front makes a lot more sense than one or two more dinner plate size cogs in the back. Especially if you didn't already went to 1x and ditched the front DR all together.
Likes For Racing Dan:
#54
just another gosling
Quoted: 3883 Post(s)
Liked 1,936 Times
Well, that's what triples are. I like a 24 or 26 granny ring so I can have my rear cogs even closer together.
Results matter
Results matter
Likes For Carbonfiberboy:
#55
Liked 4,824 Times
So at what point is that then? I’m quite happy with a compact double on my road bike, which is probably why they are so common. I used to hate triples when they were standard on MTBs. Much prefer 1x gearing off-road.
#56
climber has-been
Quoted: 3405 Post(s)
Liked 3,535 Times
But there are still plenty of people around with nowhere near 4.25W/kg on tap who think a 34/34T gear is still too low to even consider for hilly rides. I pass them all the time grinding away at sub 50 rpm in their lowest gear when they would most definitely benefit from a lower ratio.
Personally, my legs are still managing okay with a 34/28 lowest gear. That gear rarely gets used--it's the "bail out" gear when I'm tired, or when the grade is double-digit for more than just a short section.
Pushing a bigger gear isn't the worst thing in the world. It will make your muscles stronger, and it's more aerobically efficient than spinning. FWIW, my best climbing times usually happen when I'm pushing a bigger gear.
My preferred climbing cadence is 65-75 rpm, and my four lowest gears give me several comfortable options in the sub-10 mph speed range:
from bikecalc.com
Ride, Rest, Repeat. ROUVY: terrymorse
#57
Canadian eh?
Bikes: 2020 Specialized Roubaix Expert
Quoted: 131 Post(s)
Liked 96 Times
I live right on a part of the Niagara Escarpment called the Oak Ridges moraine. We grew up knowing what an escarpment was
#58
Quoted: 252 Post(s)
Liked 67 Times
I made that post hinting at triple on the front to 'enrich' the discussion but I believe nobody enjoys shifting the front, besides it being disruptive on pace, most if not all chain drops are on account of that.
#59
The issue with recommending a triple isn't that they don't have merit in the context of this thread, it's that there aren't a lot of current options for them with modern drivetrains.
Likes For HTupolev:
#60
Liked 1,461 Times
#61
Liked 4,824 Times
I don't see very many low-cadence grinders these days. I do see riders using 34/34 on climbs, but they're not spinning high cadences. Maybe 80 rpm or so. One thing I have noticed: I never see them stand (not a good thing--alternating between seated and standing is better).
from bikecalc.com
from bikecalc.com
Now I'm interested that you say your preferred climbing cadence is 65-75 rpm. So what is your preferred cadence on the flat at the same power output? I'm assuming it's somewhat higher and in which case why would that be the case? I keep meaning to compare my climbing times on Zwift using ERG vs slope mode to see if I'm actually faster or slower at a higher climbing cadence than my road gearing would actually allow. I'm not talking about spinning as such, just a normal cadence around 80-90 rpm vs a forced 65-75 rpm due to running out of gears. I get the feeling it would be a bit faster overall, especially on a longer climb where muscle fatigue would be a factor at low cadence.
#62
Liked 1,461 Times
#63
Quoted: 741 Post(s)
Liked 412 Times
I believe the reason cadence is different on climbs and flats given the same power output is the effect gravity has in those two scenarios. The higher the effect of gravity, the less forward momentum.
Likes For colnago62:
#65
Most definitely. I can spin up a short 8% grade at 90rpm in 50 x 13, provided there was a long -8% grade right before it.
#66
climber has-been
Liked 3,535 Times
It's totally normal to shift to a higher gear when standing. It should feel like a walking cadence.
#67
Liked 1,461 Times
Likes For SoSmellyAir:
#69
climber has-been
Liked 3,535 Times
I also find it harder to maintain the same power on the flat as on uphills. It's not an aerobic limit thing, the legs just don't want to push as hard. Why? Also, no idea.
OK, maybe one idea: I climb often, and my body has gotten accustomed to putting out power when climbing. Body's not as accustomed to pedaling on the flat, so it's not as powerful there.
#70
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,849 Times
That's the great thing about modern shifting - you can shift two click up when you stand, and back two clicks when you sit back down.
Likes For genejockey:
#71
Liked 11,849 Times
Yes, my preferred flat riding cadence is higher, about 85-95. Why the difference? No idea.
On the flats 95-105 feels right.
#72
Liked 4,824 Times
I found that a power meter really helped me to pace better on the flat.
#73
Liked 1,936 Times
But yeah, it's about gravity.
Results matter
Results matter
#74
climber has-been
Liked 3,535 Times
Same here, it's when I recently got a power meter that I realized my power was much lower on the flat than when climbing. Even though the perceived effort felt about the same.
#75
Quoted: 528 Post(s)
Liked 230 Times
from bikecalc.com
from bikecalc.com
Likes For ZHVelo:
