Shimano Ultegra 11 Chain
#51
Bikes: Tcr advanced sl & Protos
Quoted: 116 Post(s)
Liked 60 Times
Supposedly the chamfers on the surfaces of the outer link plates are slightly different, such that the interior facing outer link plates are optimized for downshifts on a Shimano cassette (i.e., moving from a physically smaller to a bigger cog), whereas the exterior facing outer link plates are optimized for upshifts on a Shimano chain ring (i.e., from the smaller to the bigger). I only learned this a few months ago when I installed my Ultegra chain (CN-HG701) because it did not matter with my prior generation 105 chain (CN-HG600). Some do not believe this and claim that it is an elaborate hoax by Shimano to have its logo facing the right. If that is the case the hoax must be targeted at those with much better eyesight than me.
Some say not to reuse the quick link so I’ll likely buy a new one and switch it around.
Thanks to all of you for pointing it out. I’ve changed quite a few of these and maybe got lucky on some, but not on this one.
My chain was recently jumping past a cog. Adjusted the rear mech, but I wonder if the chain being wrong contributed.
#52
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1939 Post(s)
Liked 1,463 Times
Yeah. After my mistake I looked it up. Not too smart never reading the directions. I guess I learned. It likely has 1k miles on it.
Likes For SoSmellyAir:
#53
I respect the discourse but the clarification I would like to make is I have nothing but respect for the local bike shops as well as the distributors. My concern is with how the manufacturers can allow these back doors to exist and our businesses suffer while others are unfairly benefiting.
On factory lube - friction facts looked at that a while ago and found that factory lube is not great. It's primary purpose is to protect the shelf life of the chain and prevent oxidation of the metals while at the same time providing lubrication. If you want the slickest running chain, clean it off and lube with top end lube with the wax based ones being best - which also means you really have to clean that chain because the oils in the OEM lube coating is not compatible with waxes.
Oh, and Competitive Cyclist has Shimano DA chains now for $52. I just bought one.
Likes For JohnJ80:
#54
Liked 1,463 Times
That's how business is done in Asia. Even the biggest companies in the world (think $100B+ in sales) still will do special deals if someone shows up with a suitcase of money and they have a relationship with someone who can make it happen. Seen it happen all the time over decades especially at month end. I doubt it will ever change and I can't imagine Shimano is any different. I agree, it's infuriating but doubtful it will change anytime soon.
Good find! I guess if the Ultegra chains are all out one can pony up an extra $10 to $12 for a Dura-Ace chain.
#55
The efficiency of factory lubes varies greatly. Test results show some factory lubes have the highest frictional losses of any chain lube Friction Facts has ever tested, aftermarket or otherwise. Additionally, test results show that no factory lube is as efficient as the top performing aftermarket lubes.
The wax based lubes did the best but almost as good as those were some top oil based with PTFE lubes like Rock n Roll and some others. As FF says, pretty much any of the top lubes are better than the OEM. It's simply matter to do a quick clean of the chain on the bike and add something slicker. So I'd take that heavy OEM "lube" off as much as I could. So it doesn't have to be wax and it's better to take off the OEM lube because OEM lube is pretty bad.
But I get it - chain cleaning and lubing is not high on my list of fun things to do either.
Likes For JohnJ80:
#56
I, too, cannot find a replacement chain for my Shimano 11-speed chain. I was talking with the guy in a local bike shop and I asked him why are chains hard to get. I can get just about anything else I want rather easily, yet chains seem impossible to get. I would imagine chains to be manufactured with a minimum of human input much as the steel used for them is made in fully automated steel plants. So where is the bottleneck in chain production? It's not as if this is a high demand product. I'm sure there are good explanations for the shortage, but you would think that in the modern world folks might be able to figure out how to maintain production levels despite the pandemic.
#57
https://www.competitivecyclist.com/s...NDYXQxMDA0Njg=
And with this stuff, it's less the manufacturing than it is the supply of raw materials on a consistent enough basis to maintain production. It's the labor intensive steps upstream not the actual automated manufacturing.
#58
JohnJ80,
Thanks for the info and tip. I just bought the Dura-Ace chain.
#59
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
#60
Liked 1,463 Times
Photographs of box that current chain came in (left) and new spare chain (right). Both times I purchased 116L version but got 126L version instead.
#61
Quoted: 1104 Post(s)
Liked 1,824 Times
You mean there's another component manufacturer besides Campagnolo???
In all seriousness, if cycling is a big part of your life and you aren't hoarding consumables, I don't know what to tell you.
#62
Liked 1,463 Times
As the first step of my annual bike wash earlier this afternoon, I cleaned my chain, which has just < 300 miles with the Shimano factory lube. About 5 minutes through a Park Tool CM-5.2 chain scrubber filled with degreaser, then further cleaned with degreaser using an old Sonicare toothbrush. Chain looks clean and shiny and barely leaves a mark on the rag, but I can still "feel" the factory lube in the roller. This is about the best I can do with the chain still on the bike. In the past, when I have gone through the same steps to clean a higher mileage chain that has gone through multiple periodic applications of Boeshield T-9 or Rock N Roll Extreme, the chain would squeak when it is very clean. So hopefully the solvent in the new lube takes off the remaining factory lube when I apply it later.
#63
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
I think a big part of the supply problem is shipping containers piling up in the US, and drying up in Asia. Oh, and the whole just in time model, which is anything but resilient.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
#64
Not to mention guns and ammo, whenever ppl get scared a ban is coming ... :-)
#65
If you are not using a wax based lube, oil compatible lubes will just infuse the remaining OEM lube and still be better. Another quick lube after maybe 100 miles will help accelerate the process.
#66
Quoted: 389 Post(s)
Liked 255 Times
From KMC:
We recommend never to degrease the chain completely. Also when changing to wax, we recommend to degrease the chain only on the outside. If you degrease the chain completely, we recommend to soak the chain in wax for 12–24 hours, so that this can penetrate into the inside of the chain.
Attention!
Cleaning
A new chain usually feels sticky at first. These are residues of the high-performance grease used during assembly. Remove this grease with a thin-bodied oil or cleaner (no aggressive grease solvents!), lightly oil the rollers and remove excess oil with a cloth.We recommend never to degrease the chain completely. Also when changing to wax, we recommend to degrease the chain only on the outside. If you degrease the chain completely, we recommend to soak the chain in wax for 12–24 hours, so that this can penetrate into the inside of the chain.
Attention!
- Never use acidic or alkaline cleaners (rust remover). These will damage the chain and in extreme cases can lead to breakage.
- Never use aggressive degreasers - these will loosen the factory applied grease from the pins. This allows dirt to penetrate and drastically reduces the service life of your chain! Furthermore, these agents are harmful to the environment.
- Chain cleaners also often contain solvents that can damage your chain.
- Clean the chain with a dry cloth.
- Important: also clean the sprockets, chainrings and shifting rollers.
- To remove dirt or sand, use a brush.
- If the chain is very dirty, lukewarm water with detergent or a cloth soaked in thin oil will help.
#67
From KMC:
Attention!
Cleaning
Attention!
I can tell you this - using oil based lubes, I’d get a chain to last about 2000 miles. With wax - at least the Silca lube I use -, I’m currently at 4500 and the chain is only half worn according to my KMC digital chain checker. I think the wax based lube is a better lubricant and I also think the oil based lines attract and retain road grit which leads to higher chain wear
through internal abrasion.
Using the Silca lube is less work than with oil based lubes. You have to clean the chain more thoroughly at the initial installation, but re-lube every 300 miles compare to 200 with oil based lubes. But most of all, I was surprised at how much better the chain runs. The decrease in wear is clear evidence it’s a better lube.
It’s almost cringe worthy when riding down bike paths, so many really nice bikes go by with chains so dry they squeak. As an engineer, that drives me nuts to the point where I almost want to ask if I could live their chain for them. I think this is the scenario that KMC and other chain manufacturers are addressing with their “don’t remove the grease” advice. They’re a lot more concerned with a durable lubricant for users who never lube their chain than they are with friction losses.
From my perspective, anyone buying an expensive high end chain should be more concerned with proper maintenance and low friction otherwise there is no point in buying a top quality chain.
Likes For Pacelineg:
#71
I went ahead and ordered a "Dura Ace" chain from China for $15.00. Knowing full well it was fake, curiosity got the best of me.
Here's some photos to add to this great thread. Ignore the fact that I was suppose to receive a 901(hollow pin) chain but instead
received a 701 (solid pin) chain. I pulled a real 701 I had to compare to this fake one.
*** Notice the CN-HG901 stamped into the link on this solid pin fake Shimano chain.
