New here looking for advise.
Quoted: 5 Post(s)
Looking for some advise as to what to do. I currently own a 2012 Trek 1.5 with less than 3000 miles on it. I have upgraded tires and tubes already and have also replace the bar tape, other than that it is factory stock. I currently don’t have the money to replace my bike at this time but was thinking about saving up and getting a new bike next year, I really enjoy riding but haven’t had the time up until now.
I will be mainly riding roads and bike paths. Would I be better off to get a new bike or should I keep what I have? If I keep what I have should I change/upgrade any thing or just keep it stock?
I don’t know exactly what kind of mileage I will be putting on a month but would like to be up in the area of regular 50-75+ mile rides almost weekly along with several others during the week ranging from 10-25 miles.
Thank you for any input you may have.
My vote is for keeping what you have. It's adequate for the job, if not the lightest and shiniest. Save your money for stepping up in overall quality for a whole new bike.
You might want to get a chain wear measuring tool, and keep track of the chain "stretch". 3000 miles isn't a lot for the original chain, but depending on how it was maintained, you could need a replacement chain soon. If you ignore it, you can wear out your cassette and front chainrings with a worn out chain, and replacing all that stuff is expensive. Get a new chain now and have it when you need it. You'll still wear out the rest of the drive train eventually, but it'll take two or three chains, replaced when each one wears out.
Likes For DeadGrandpa:
Quoted: 624 Post(s)
Liked 396 Times
Unless something is broken or you are not comfortable with the way your bicycle rides than don't worry about a replacement right away. As you ride more you will gain experience and knowledge riding with others. From what I have seen it is more difficult than usual to find new bicycles currently. I started out on a bicycle not much different than what you have and found that it was a lousy ride on tank trails on the base. The tires wore out to quickly also. So my next purchase was a touring bike. I currently ride a touring bicycle with 2" wide tires. Being the hot season I do most of my riding at night or early morning. Its 110 degrees right now.
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,204 Times
Replace or Maintain
Welcome to Bike Forums.
I spent 2020 riding around on a 2011 bike. Did 2,000 miles on it.
Assuming your bike is not giving you terminal troubles, continue riding it.
If you've a hankering to spend some money in the bike dept..... Then some tools to assist with it's maintenance and upkeep would be a good place to start.
You might also learn some new skills along the way.
Drivetrain maintenance is a good place to start.
Chains stretch with age. A chain wear tool will allow you to determine if the chain has stretched past the usable limits.
Dricetrains also require a good cleaning.
The tool to remove the Cassette from the wheel (for cleaning) and a Torque wrench in order to replace the cassette correctly are good options.
You'll also want to remove the chain for cleaning.
Maybe your chain has a master link (quick disconnect), you'll need master link pliers.
Maybe you chain doesn't have a master link, you'll need a chain break tool.
If you do have to "break" the chain to remove it. Do consider using a master link for reassembly, makes things much easier.
Just some ideas. After all, if you were to purchase a new bike, the tools to maintain it are still required.
I couldn't imagine having to take my bike to a mechanic every time my chain needed a cleaning.
All the best
Barry
All the best
Barry
Bikes: yes, i have one
Quoted: 1136 Post(s)
Liked 1,182 Times
i have a similar ride, Trek 1.2 i bought new in 2007 or 8. i have replaced tires, brake pads, chains, RD, RD hanger, and most recently the bottom bracket. i've added clip on aero bars and that is it. i now put on about 6K mi/year. i am looking to get a new ride.
EDIT: i guess my point is that if it is functional just ride it.
Bikes: 2006 Lemond Tourmalet; 1992 Giant Rincon
Quoted: 5 Post(s)
I would also agree with the keep what you've got crowd.
I bought my first road bike (a 2006 Lemond Tourmalet) last year used. To get something new that is comparable to your 2012 Trek 1.5, you'd have to spend $1000 or more. Those prices are crazy to me if your current bike doesn't have some major issue. Just keep the normal maintenance up and replace wear items (chain, tires, tubes, brake pads, etc.) as needed and ride it.
I looked at some other bikes after I found my bike, but I didn't see anything that even came close to making we want to buy anything new. Sure there are a few things nicer with a new bike over my 2006 version, but I'm really happy with my bike as it rides. I definitely don't see anything on "comparable" level new bikes that would justify spending about 3 times what my current bike cost.
Quoted: 313 Post(s)
Liked 680 Times
The answer is always to buy a new bike, because new bikes are nice.
Will it make you faster? Possibly, depending on what you choose. An aero bike will make faster easier. If your current bike is in good condition, fits you well and is a joy to ride, then stick with it.
On the other hand, if you can afford a new modern road bike, then go for it!
Likes For tempocyclist:
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Save your money right now, ride what you have, and reevaluate next year when you see how much riding you're actually doing, what you'd want in a new bike, and you'll know whether the shortage is over. If you're enjoying what you're riding now, getting experience enough to know what you do and don't like is very valuable information.
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,646 Times
Keep it. It's a pretty darned good bike. A new bike may make no difference whatsoever in the longer rides you hope to make. If after you start riding those longer rides, you feel like you want a new one, then reward yourself. Maybe availability will be better by then.
Quoted: 4401 Post(s)
Liked 4,849 Times
As you are planning frequent and relatively long rides it would be worth considering your contact points ie shoes/pedals, clothing and saddle. Those can all potentially be make or break items once you start clocking up regular mileage.
Providing the fit is good and well maintained, I would rather ride an older bike in my most comfortable bike gear than a brand new $10k super-bike that left me sore and sweaty after 75 miles.
Likes For PeteHski:
Bikes: 2015 Felt Z75 Disc, 2008 Fuji Cross Comp, 2010 Trek Navigator 1.0, 1974 Raleigh Sports, 1974 Schwinn Le Tour, 1981 Schwinn Super Le Tour, Surly Cross Check, 2021 Giant Talon 2
Quoted: 202 Post(s)
Liked 71 Times
check out the Frugal Average Bicyclist
Frugal Average Bicyclist – The goal here is to help you keep cycling on a budget.
Likes For prj71:
Quoted: 2952 Post(s)
Liked 3,106 Times
This bike is barely broken in. Ride the heck out of it.
Likes For caloso:
Quoted: 5 Post(s)
Thank you all for the replies. I tend to have a very impulsive purchasing quality about me and have been trying to make more informative decisions. I figured that a new bike probably wasn't going to the answer I would get but I have not really been following the bike world for a while so I wasn't sure what all has changed, I also wasn't sure if my equipment would be considered very low end or if it was in line with what I am looking to do with it.
I did do some research into the new bikes and did notice that to get some of the same equipment that I have currently I would be spending over $2000 on a new bike. This seemed a bit high to me considering that my bike was only around $1100-$1200 when I bought it but as with everything I am sure the prices went sky high.
I think I will first look into upgrading pedals and shoes as I am currently using mountain bike equipment and then put some money into tools and maintenance needs.
Getting a new bike can wait another year or two, if at that time I decide it's it the correct time to change things up I will do so. I have never really been unhappy with this bike and it has never let me down so I guess that is a good enough reason to keep it around for a while longer.
Thanks again.
Thanks again.
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times
Yup
Just make sure you have tires appropriate for where you ride. Many have discovered that wider tires are comfortable and versatile. 28-38mm wide range is pretty good for most pavement and gravel roads. Measure to see what will fit. After you wear out the upgrades you already did, of course. A new bike isn't going to get you much, if any better results.
Quoted: 6193 Post(s)
Liked 4,808 Times
If it's the 50/34 front and 12-30 rear 10 speed that the Trek archive show, then you should be good for most anything paved.
https://archive.trekbikes.com/us/en/...t_2012/details
If it takes you another almost ten years to put 3000 miles on it, then you might never get your legs use to the effort of riding rolling terrain and hills. Aim for at least 3000 miles per year.
Liked 3,106 Times
I'd be surprised if you could fit anything wider than 25mm tires on that bike, but that's fine for road and bike path.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Thank you all for the replies. I tend to have a very impulsive purchasing quality about me and have been trying to make more informative decisions.... I have never really been unhappy with this bike and it has never let me down so I guess that is a good enough reason to keep it around for a while longer.
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
I have a similar vintage Trek 2.3 which most likely is the same frame (carbon seat stays and fork) with slightly higher level componentry to your bike. I am looking for a modern endurance bike simply for the geometry/comfort benefits. That being said I am going to wait a year due to availability. I really don't need a new bike but would love to have one.
As it is I have been busy putting vintage 7900 series Dura Ace components on my bike. Just a front DR and shifters and a cassette and it will be full Dura Ace !! I actually like the factory Bontrager wheels but they may get upgraded soon. I get a real kick out of working on it.
Ride the crap out of the old trek and if you are really hooked treat yourself to something new.
ETA My bike is a 2009 ...Yikes time flies.
Grouchy Old man
Clean it up really good, tune it up, overhaul it? You have to do what you think is best....
Quoted: 1572 Post(s)
Liked 643 Times
Ride the bike that you have now.
After every ride, make a list of the things that you like about the bike that you have now and the things that you hate. If you do that, by the end of autumn you'll have a much better idea of what to look for in your next bike.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
First plan for a new bike in the future. Year or two out. There are not many available now and you may settle on something because it’s available. Then in a couple of years get buyers remorse. Maintain and ride what you have. Sounds like a good fit with the distance you can ride. I have a 2005 Madone so yours is not old.
Anyway I’d go ahead and get a new chain and measure tool. Just to have when you need it.
Bikes: Specialized ruby carbon, giant hydrid, electra ladies, Raleigh SA 5 spd
Quoted: 252 Post(s)
Liked 67 Times
I'd keep what you got, plans and actual implementation of them are two different things. I suggest you first start actualizing those plans on the current bike and take it from there.
Quoted: 3352 Post(s)
Liked 1,056 Times
