Am I missing anything not trying 650B wheel set?
Quoted: 569 Post(s)
Liked 581 Times
I have spent a lot of time on various steel and bonded Al & carbon frames, forks carbon to steels & Al, various geometries, saddles, etc. but never a 650b wheel set. Am I missing anything? Don't mind things like long reach brake changes, etc. I have an 26" MTB and a grocery getter Hard Rock 26".
it is just part of finding what I appreciate in my rides, so worth every penny to me. In my 70s touring is not in the mix.
Quoted: 838 Post(s)
Liked 1,080 Times
Well, think about the widest tires you’ve ridden and ask yourself if you loved the ride? If so, going fatter will likely be even more enjoyable, some people have their limits though.
Also, have you ever thought that the fattest tires you have on a bike were not fat enough to comfortably and safely cross the type of terrain you want to ride? 650b may be for you.
The there are probably lots of other benefits but fitting wider tires four the cushiony ride and hitting the trails is why most people like 650b.
All that being said you have some 26” bikes. I can’t speak to how small large the differences may be there, but I imagine not much.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I have spent a lot of time on various steel and bonded Al & carbon frames, forks carbon to steels & Al, various geometries, saddles, etc. but never a 650b wheel set. Am I missing anything? Don't mind things like long reach brake changes, etc. I have an 26" MTB and a grocery getter Hard Rock 26". it is just part of finding what I appreciate in my rides, so worth every penny to me. In my 70s touring is not in the mix.
Likes For ThermionicScott:
Quoted: 31 Post(s)
Liked 73 Times
cheaper than RH
There's nothing magical about the 650B wheel spec itself. The big draw that got lots of people converting to 650B was the very comfortable, yet fast, tires available in that size. Nowadays (well, starting about 10 years ago), there are some great options in 26" and fatter 700C tires, too. Put some RH 44mm Naches Pass tires (or Rat Trap Pass, if you can fit them) on one of your 26" bikes, and you will have most of the goodness of a 650B conversion right there.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
Didn't people usually like the Schwalbe Big Apple tires?
What really separates the Compass/ReneHerse tires (at least between something like the Pasela or Sand Canyon) is that plush-ness.
But lower the pressure in your tire to the point that it feels cushy but not draggy, and you don't feel like you're inviting a pinch flat.
Commence to jigglin’ huh?!?!
Liked 2,568 Times
Wouldn't we all like to get the finest things in life a bit cheaper?
I'm not aware of anything on the same level. It's too bad there isn't a Pari-Moto in that size, big fan of those in 650B and they're not expensive. The problem with most 26" tires, including the Panaracer Pasela 26"x1.75" I used to run, is that they're expected to be fairly durable, so they have thicker tread that makes them slower. They often have a lower thread count, too.
I'd love to be wrong; hopefully someone who's more up to date on fancy 26" tires can jump in with some good suggestions!
RUSA #7498
Originally Posted by noglider
Quoted: 3464 Post(s)
Liked 2,829 Times
30 years ago I was given a pair of slicks for my Ritchey mtb. Was quite surprised at how well it rolled.
younger and faster, a number of the racing set were despondent when they could not drop me on a hill and were dropped by me.
I stopped at a market and they were even more bummed when they pulled up and realized that my bike was 8lbs or more heavier too.
just added insult to injury.
Likes For repechage:
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 810 Times
Some worthwhile reading here:
https://www.bikeforums.net/classic-v...el-thread.html
and here
https://www.bikeforums.net/general-c...ease-help.html
and here
https://www.bikeforums.net/general-c...-75-2-0-a.html
and here
and here
Likes For fishboat:
Quoted: 4722 Post(s)
Liked 3,036 Times
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Same time frame, the big weekend doughnut ride in Toronto had a bunch of top riders and then pack fill like me, waiting to get dropped after a few hours of drafting. Mr messenger dude almost got up to the front on a rigid Stumpy with 1" slicks. They shut him down with some effort but it was impressive how he could spin fast enough to do > 50 kph.
Quoted: 31 Post(s)
Liked 73 Times
Quoted: 5888 Post(s)
Liked 3,471 Times
There's a lot to be said for riding a fat cushy tire. I especially like them for multi-day events.
Liked 3,471 Times
Tire selection has gotten spotty with the pandemic and supply chain disruptions. Tire selection for 26 inch tires has gotten worse.
Maxxis DTH tires are available. I like the Panaracer Protite 26 x 1.75 and the Schwalbe Supreme 26 tires but both are hard to find.
Quoted: 3810 Post(s)
Liked 6,690 Times
One advantage of a 650B conversion--versus riding a native 26"-wheeled bike that's not a racing MTB--is that you can really improve the ride of an 80s racing-oriented bike. You get the advantage of relatively light weight and likely somewhat steep frame angles, but soften out what is usually a harsh ride on 25mm tires by opting for 38mm x 584mm tires. My best example of that in the fleet is a 2001 Lemond Zurich with 853 tubing. With 38mm tires (the Pacenti version can usually be found for not too much $), it's a lightweight all-rounder.
IMG_1236
IMG_1236
Quoted: 569 Post(s)
Liked 581 Times
Nlerner, thank you. I am thinking my 70 year old body could use some easier rides. I have a '98 Zurich that has not been touched in years and we summer in the Bighorn Mtn foothills where the roads are not ideal. When I get back South for calipers I can measure but would appreciate and comment you might have on long reach caliper braking with the stock 6500?
Likes For easyupbug:
Quoted: 753 Post(s)
Liked 737 Times
I'm almost there. 650b Im doing next will have 45mm bars and a Bio Pace small ring is still on the table. Its a Bridgestone, but from just before they let Mr. Peterson off his chain. Oh well. If I hurry my breakfast pizza bagel will still take the skin off the roof of my mouth. ..
Quoted: 581 Post(s)
Liked 921 Times
SOme misunderstanding of the OP's situation, I think. Some folks were talking about fitting bigger and fatter tires with 650B, but I think OP mentioned two 26" wheel bikes, so switching to 650B will result in less clearance for fat tires, not more.
Bikes: 1978 Raleigh Competition-1974 Raleigh Folder-1983 Austro Daimler-198? Fuji Monterey-Surly LHT-Surly Karate Monkey-Surly Cross Check
Quoted: 43 Post(s)
Liked 97 Times
I tried a couple of 650b options for awhile and it just wasn't my thing. However, I can definitely see why some people would like it. The situation for me is that on most of my vintage bikes 25mm-28mm tires work great and provide the ride that I like. That is what my vintage bikes were designed for and so I stick to it. I tried 650b wheel on 2 different bikes. The first was a mid-80s Shogun 1000. It was OK but not much more than that. The other bike that I converted to 650b was an early-90s Trek 930 mountain bike and it worked out better. I found that with 650b wheels I could use Tektro CR720 cantilevers and get them to reach the rims. I also installed a dirt drop stem with Nitto road handlebars. This actually worked pretty well and I liked this bike. However, I still liked that Trek 930 much better as a mountain bike. That is one of the bikes I deeply regret selling. I should have never gotten rid of that bike. Also, the other reason that the 650b option wasn't for me is because I have a Surly Cross Check. While my Cross Check isn't vintage, anything my 650b bikes could do, my Cross Check can do better.
So are you missing anything? I think this is one of those things that really comes down to personal preference. There are some vintage road bikes that can accommodate 32mm wide tires. I would be inclined to try that first given that a new set of wheels isn't cheap. However, if you're like me and enjoy trying new things just for the sake of trying new things, then go for it.
Bikes: 1972 Fuji The Finest | 1990 Bianchi Giro | 1999 LeMond Buenos Aires
Quoted: 151 Post(s)
Liked 303 Times
Likes For AJI125:
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Yes: avoid them!
Okay, seriously, this depends on how sensitive you are to things like rolling resistance, suppleness, &c, all of which are subtle. I had RTP tires on two road bikes, having chosen 26" wheels over 650B. RTP are nice tires, but spendy. So I have a pair of Panaracer Ribmo tires that I use on one of those bikes. Sometimes I can tell the difference, but sometimes I cannot. Whether you can, I will not speculate. But there are not very many high quality smooth tread fat tires in 26". A lot of the tires made for 'cruiser' bikes are heavy and slow, perhaps to match their riders. The better 26" tires are mostly made for off road use. I've been meaning to try Continental 'town and country' tires but haven't. If you find a cheaper 26" tire that's as good as RTP's, please let us know. And... good luck!
www.rhmsaddles.com.
www.rhmsaddles.com.
Liked 6,690 Times
I put a set of Maxxis DTH 26 x 2.3" tires on my commuter MTB. It turned a heavy bike (since sold off) into a heavy bike with nicer tires.
Quoted: 896 Post(s)
Liked 2,063 Times
There's 650b conversions of old road bikes, new 650b bikes as a randonneuring style, modern disc brake bikes that use 700c or 650b in an attempt to be all rounder bikes, and then there's 27.5. So to answer the OP's question, probably the first in that list is the only thing that would be a miss - if you're missing out improving an old road bike.
For decent, affordable 26" road slicks, Primo Comet 26x1.5, about 38mm, sometimes can be found for $35. 1.5" being either too skinny, too fat, or just right, depending.
