135mm rear hub into a frame with 132.5mm drop-out spacing
Bikes: 1975 Schwinn Voyageur II (Made by Panasonic), 1988 Schwinn Voyaguer (touring)
Quoted: 11 Post(s)
What is required to put a 135mm rear hub into a road frame with a 132.5mm rear drop out spacing??
I am under the impression a frame with 132.5 DO spacing can accept wheels with either 130mm hubs (add spacers on both sides???) and 135mm hubs. I am having trouble with the missing 2.5mm between the DO spacing and a 135mm hub.
My original question about 132.5mm DO spacing ("Can someone explain benefits of 132.5mm dropout spacing") was not specific. The comments I received were good, I just asked an imprecise question.
Quoted: 5888 Post(s)
Liked 3,471 Times
Piece of cake; the wheel will fit with no problem. You may have to push the dropouts out a bit by hand to make this work.
Quoted: 514 Post(s)
Liked 451 Times
That's the idea of 132.5. It fits 135 and 130 equally badly (or well).
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
Simply install the wheel. You can easily spread the stays of any bike 2.5mm with finger pressure. I used to cram a 135mm width wheel in a heavily triangulated, 130mm width recumbent frame with very little struggle.
Jeff Wills
Jeff Wills
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
Go, past "go", collect $200.00.
=8-)
=8-)
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
/K
Señor Member
Quoted: 649 Post(s)
Liked 293 Times
correct responses
just squeeze the 135mm hub in
close the qr
and ride
if you had 130 mm hubs
you just have to screw the qr down a couple more turns to take up the space
close the qr
and ride
i would bet there are a lot of mass manufactureed bikes designed to havce 130 or 135 mm spacing that has 2.5 mm variance from nominal
just due to manufacturing tolerances
close the qr
and ride
close the qr
and ride
Quoted: 128 Post(s)
Liked 12 Times
just do it.
as oldbobcat said, the whole point of frames designed with 132.5mm spacing is that they'll work easily with 135mm or 130mm-spaced rear hubs (the two most common standards).
realize that whether going up to 135 or down to 130mm, you're flexing each stay 1.25mm each. That's next to nothing - probably with an aluminum frame, and totally fine with steel.
"c" is not a unit that measures tire width
