Tire dilemma
Bikes: 2017 Soma Valhallen, 1992 Trek 820, 2011 Tern Joe C21, 2012 Tern Link D8, 20?? Takara Kabuto
Quoted: 10 Post(s)
Tire dilemma
I'm looking for some guidance regarding tires for attempting my first 200k brevet, the NER Narragansett Bays and Bridges 200k.
For background, I weigh roughly 225 lbs/102 kg though I try to ride light. My bike is a 1992 Trek 820 drop-bar conversion, currently equipped with 1.5"/38mm Tioga City Slickers. I've ridden these tires a few hundred miles commuting and only had one flat that I can recall, puncture from a large glass shard. Ride quality is ok, but I think slightly rougher than even the 2" smooth-center-tread knobbies I've run in the past (aside from cornering). Past frustration with frequent flats, both pinch and puncture, even with 32mm tires on my previous road bike has completely sold me on wider tires. Reading Jan Heine's blog and the glowing reviews of Compass tires here and elsewhere has me intrigued by wide tires with supple casings. I have my eyes on the extralight Compass Rat Trap Pass. The problem is, in case it's not obvious from my choice of ride, I'm cheap and lack a lot of disposable income. Further complicating the choice is the fact that I don't anticipate racking up serious mileage for the foreseeable future. My goals for this year are the upcoming 200k and optimistically a century or two in addition to the handful of shorter recreational rides I have done in the past. Before I spend more on tires than my bike is worth I wanted to get some perspective from the experienced group here.
Should I:
a. Buy the Compass tires. They are life-changing tires that totally live up to the hype
b. Keep my existing. Should be good enough for my limited goals and Compass tires on a Trek 820 would be like drag slicks on a stock '71 Pinto.
c. Something else? Perhaps some less-supple wider tires from my LBS for cheaper...
Should I:
Bikes: Trek Emonda SL6 .... Miyata One Thousand
Quoted: 63 Post(s)
Liked 23 Times
get the compass tyres .... (are your wheels 26 inch though, as I think that the rat trap pass are only for 26 inch?)
Quoted: 4362 Post(s)
Liked 25 Times
You don't have to shell out for an exotic premium tire to get a decent ride. There are plenty of very nice supple tires, readily available at reasonable prices, in the 1.6-2.0" range. Pick one.
It may not have equally low rolling drag, as measured in the lab, but it will be close enough not to matter in the scheme of things. After all, total tire drag is but a small percentage of total drag (wind + mechanical + tire), with wind dominating at speeds above 15mph. So some some small reduction of a small source of drag isn't really that significant.
OTOH - width matters, and is how you strike an overall balance between comfort and drag, as does tread and wall suppleness. So, look for a smooth tread tire with decently supple walls,in a width that seems right (1.9") at a price you can live with.
BTW - you might consider me biased. I used to buy H rated tires for my Miata for $85.00ea. I could never bring myself to paying close to that for a bike tire.
FB
Chain-L site
“Never argue with an idiot. He will only bring you down to his level and beat you with experience.”, George Carlin
FB
Chain-L site
Quoted: 13309 Post(s)
Liked 1,782 Times
What you ride is up to you.
I recently completed a Hybrid to drop bar conversion, and threw on some 32mm Michelin Protek Cross Max tires. Great tires, and no flats for 500 miles or so.
Nonetheless, they seem to be slow, and require extra effort to ride. More testing later. They aren't a big problem for a 10 mile commute, but it really ads up when one is doing 100+ miles.
I did take my Michelins up to Portland on my most recent trip, 130 miles northward, 160 southward. WHEW!!! Anyway, one can survive the trip.
In your case, I'd buy whatever tires you expect to be riding on the bike most as commuter tires, and just ride them on your upcoming Randonneur ride. Not a lot of sense getting tires just for a single event.
I used schwalbe kojaks for my first year of rando riding, they are fairly supple and I never had any flats on them. They make folding bead in 26” and 700, also a few different widths.
Do you think the tire speed could be the difference between finishing and not, or between having fun and not?
(I'd disagree with Clifford about not swapping for long rides vs commutes -- if you only have one bike and commute on glass-strewn streets, having more serious puncture-proof tires on for commuting makes sense, and the fancy tires should last a long time if you're only swapping them on for the occasional event.)
Uber Goober
Well, some of the randonneurs I know use Compass tires because they're the most wonderful things ever, etc., then you read of their adventures riding a 400k in the rain and having 8 flats in the process or something like that, and it makes you wonder just what they're thinking.
Anyway, my experience- riding Worksman cruiser, using 26x2-1/4" tires that run about $8 each- maybe a flat every 1,000 miles.
Got my Sojourn, it came with Vittoria Randonneur tires 35x700- and very few if any flats.
Switched to Gatorskins, 32mm and 28mm- very few flats.
On my single bike, using Continental 4 seasons- very few flats.
This leads me to believe that wide tires at low pressure don't prevent flats. Having "good" tires, from a flat-proof point of view, does.
Anyway, my advice, use whatever tire you have on there and go ride your 200k, no reason to experiment for that. If you change tires, get in a bunch of local riding before setting off on a 200k, but don't expect it to make a huge difference.
Liked 1,782 Times
Another option is to revisit the "road bike".
What happened to the one you had?
I'm not seeing a lot of budget conscious road bikes, but perhaps something like this Sirrus.
https://worcester.craigslist.org/bik...454051459.html
Or, even the Vilano.... not the hottest of bikes, but it could be tuned for the road.
https://worcester.craigslist.org/bik...468437783.html
Then, for puncture resistance, hunt down some "road tires", with extra puncture resistance, such as Gator Hardshells, Specialized Armadillo, Maxxis Refuse, or similar.
Although, I suppose you didn't really mention your budget, or height/size, so off course, the sky is the limit.
Quoted: 10 Post(s)
CliffordK, you are correct about the bike. My commute is short and I typically commute on a different bike, but I plan to use the Trek with whatever tires I choose for all my recreational road rides, not just the brevet. That mileage is limited to at most a few hundred a year, so it's hard to justify the expense of the Compass. I'll probably pass on the Michelins based on your feedback about the speed.
Compass tires are great. But a compromise tire (I'm not familiar with the ones you're running) might be your best bet. Like I run GravelKings sometimes (I don't think they make a 26", though) when I don't feel like ponying up for Compass/Grand Bois -- IIRC my brevet bike is currently wearing one of each, although I need to get some new rubber.
Anyhow, thanks everyone for the suggestions. I think I will probably just ride what I have for right now and look to upgrade when they wear out. I probably won't get the Compass tires unless I start doing a lot more riding and feel like I can justify it, which is pretty unlikely. That said, I'd love suggestions for cheaper tires to consider that are still wide, fairly light, and fairly supple. Preferably coming less than $50 per tire and 1.5"-2.3". I have had trouble determining which are supple just from description and specs. I know TPI can give a vague idea, but of course there are exceptions. In searching, I've seen some suggestions of Panaracer Pasela (not Tour Guard), Schwalbe Big Apple, Schwalbe Marathon Racer, Vittoria Randonneur Pro, and Maxxis DTH.
Thanks for the perspective antimonysarah, I'm optimistic I can make the time limit (barring injury or severe mechanicals) without the best tires, and I'm sure I'll have fun either way. I think I'm just caught up with the idea of improving my ride in terms of both speed and comfort. I do have a separate commuter bike (1997 Gary Fisher Marlin rigid MTB with touring bars). My commute is short so I'm far less picky about tires for it. These tires would be just for my recreational road riding.
Liked 1,782 Times
I'd dig out your Bridgestone 400, and at least try it out again.
Are you doing any "training rides"? Perhaps a good 50 mile ride or two?
1 flat every 100 miles... so maybe a chance of a flat in your century ride
I always ride prepared for flats (or just about anything), but am probably down to perhaps 1 flat every 500 to 1000 miles or so. Hmmm, I think my only flat this year so far was a flat trailer tire (MOPED)
Watch the tire pressure on the road bike.
Like I said, I've been tending towards Gator Hardshells on my road bikes, but did have one sidewall issue, so perhaps will hunt for my next favorite tire when the current ones I have run out. But, they do generally well with minimizing flats.
Quoted: 10 Post(s)
Liked 1,782 Times
Many of the Presta pumps have reversible heads.
Just pop off the cap, and reverse all the pump guts.
It seems like I end up doing the swap regularly between my own use, helping others, and both bike and trailer tires.
Bikes: Optima Baron LR, '14 Nishiki Maricopa,'87 Trek 330 Elance, '89 Miyata 1400, '85 Peugeot PGN10, '04 Fuji Ace, '06 Giant Rincon, '95 Giant Allegre, '83 Trek 620, '86 Schwinn High Sierra
Quoted: 187 Post(s)
Liked 104 Times
Don't go Kojaks. I have a set for my recumbent, and they are anything but supple. I was pretty surprised how hard of a ride they produced compared to my Primo Comet tires. I have my MTB bike equipped with Rubino Pro Slick 26x1.5 tires, 150TPI, supple as ever, and fast. These would make a perfect 200k randonneur tire if you didn't want to spend the money on Compass tires.
Jedi Master
I use compass extralights on my randonneuring bikes and like them a lot, but I don't use them on any of my other bikes. If you're just going for the 200k and don't have aspirations for the longer distances then use the tires you have and replace them with paselas when they wear out. I have 26x1.75 paselas on my tandem, and it's a good inexpensive tire.
Randomhead
Liked 1,038 Times
I don't think it's worth switching tires for a 200k, unless your current tires are really horrible. I had some Serfas 26" on my commuter that were noticeably draggy, upgrading those was like letting off the brakes. Rolling resistance really starts adding up at the longer distances, 300k+. I'm pretty happy with Gravelkings. I'm hesitant to go lighter than that right now. If I had a flat every 500 miles, I would cry. Changing a flat eats up any time advantage you get from using better tires
Quoted: 10 Post(s)
Everyone, I really appreciate all the feedback I got here, I feel like it saved me from spending more than I was comfortable with for an improvement I don't really yet need. Looking forward to my first brevet!
Check out the drop bar conversion thread in the classic/vintage section, lot's of setups with slick 26" tires.
I have Continental town and country tires on most of my bikes, cheap wire bead but honestly ride pretty great. I think it's because they have pretty thin sidewalls.
Also tried Tioga powerblock and Maxxis DTH tires, both folding beads with some very shallow tread. Both ride great and almost cheap if you look around ebay/amazon. Mostly stick to the Continental inverted tread town and country because they throw way less gravel at you.
Always wanted to try Kojaks, at least on paper they look good and are crazy light. The DMR supermoto is another one I see on the 26" drop bar thread, similar to the Maxxis/Tioga.
Continental Tow and Country comes in 1.9" and 2.1" I think.
Tioga Powerclock comes in 2.1"
Maxxis DTH comes in 2.15" and 2.3"
DMR Supermoto comes in 2.2"
multimodal commuter
Quoted: 1782 Post(s)
Liked 277 Times
I have a bike that I specially made for the Compass Rat Trap Pass tires. It's basically a randonneuring bike by design, Columbus SL tubing, low trail, handlebar bag, dynamo lights &c, but 26" wheels and plenty of clearance. Its purpose was to give me access to the unpaved back roads of New Jersey's pinelands, which are mainly sand, and often so soft that riding is impossible. Fortunately the sugar sand sections are usually small, and I'm back on the bike after walking fifty feet or less. Anyway, that's what this bike is for, though I've also used it for commuting and other rides, including (so far) one randonnee (200k and very hilly).
Anyway, the point of this long rambling post is: the Rat Trap Pass tires seem to me to be very comfortable but rather slow. I have no data to back this up; it's just my impression. Has anyone else used them for long distances? What's your impression?
Quoted: 10 Post(s)
multimodal commuter
Liked 277 Times
Sounds like a great bike! I'm curious if you are using the standard or extralight casings? I understand the standard casings are somewhat slower, but offer better sidewall protection. I've also read it can be difficult to determine tire speed by feel, from here: https://janheine.wordpress.com/2018/...es-are-slower/
I happily concede the point, that my impression (that these tires are slow) is subjective at best and probably useless. Maybe I'll ride that bike on an upcoming randonnee and report back.
My experience is that they perform phenomenally well on any surfaces that don't break up badly beneath them, which is basically anything except mud, super-loose sand, and oddball crap like loose railroad ballast. Even on paved roads, when my gravel bike is fitted with the Rat Traps, it seems to hold speed on the flats as easily as my skinny-tired road bikes. They're definitely lively and supple... the road hum astonished me on the first ride, loud even with butyl tubes installed, and much deeper than you get with narrow racing tires.
The paper-thin casing renders them very pressure-sensitive. They're squishier at a given pressure than most 2.1" tires, and quickly make a bike start handling like a boat if you drop too low. And with so little damping, pumping them too stiff is like riding on basketballs.
I'm okay with an occasional flat... I tend to figure that if I never flat my tires, I should switch to something flimsier.
Randomhead
Liked 1,038 Times
my rule is when I have a flat, I put on a new tire. I ignore that for flats caused by wires, that doesn't seem to be affected by tire age.
If my bikes were equipped with tires that never flatted except from wires or when they were near their demise, I'd replace them with new tires of much greater flimsiness.
Bikes: Mercian Audax Velo Orange Rando. Cannondale R800
when are you getting pinch flats? Shortly after installing a new tube? The couple I have had were from pumping up the tire too quickly and not letting the tube inflate correctly. I ride Stampede's and havent had a flat yet.
