Frame scratching help
Notice this scratching on the frame of my bicycle near the large chain ring. I kinda ruled out chain suck, as if I manually pull the chain up it hits the frame further out than these scratches. I have painted over this area once, but it keeps coming back over time. Any ideas?
Steel is real
is the chainring bent?
Location: Creede CO in summer & Okeechobee, FL or TX Gulf Coast in winter
Bikes: Zenetto Stealth road bike & Sundeal M7 MTN bike
Quoted: 90 Post(s)
Off road "stuff" twigs, dirt clumps rocks etc.
Well, it is chain suck on the small chain ring. It hits perfectly if I hold the chain on the small chain ring on a revolution. I was doing the large chain ring at first. Now I have to figure out what to replace or did this happen because I shifted under load. The chain is close to being worn out, but still shows good using: https://pedros.com/products/tools/ca...ecker-plus-ii/ The bicycle has around 10K on it and I am on my third chain. I have a new cassette ready and actually have the chain rings also. But was going to run this chain till the checker says it is worn out(.5%) and just replace the cassette and chain.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
I'd go back to the manufacturer for a warranteed frame replacement. Fatal design flaw IMO.
Bikes: 1984 Fuji Club, Suntour ARX; 2013 Lynskey Peloton, mostly 105 with Ultegra rear derailleur, Enve 2.0 fork; 2020 Masi Giramondo 700c, full Deore with TRP dual piston mech disk brakes
Quoted: 324 Post(s)
Liked 81 Times
That sucks.
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
that may have been a brutal answer but seriously if that were my ride I would have been in my LBS so dang fast. I can't see I have ever seen this short of a bent chainring. Worst case the bottom bracket shell/frame had an impact and its not true. This would worry me and anger me to no end.
Quoted: 714 Post(s)
Liked 800 Times
Bikes: 630 Beach Bike Schwinn Hurricane ATB
Quoted: 35 Post(s)
There looks like a quarter sized circle where the lighted part of the frame meets the shadowed part.
Bondo?
Bondo?
https://reviews.mtbr.com/wp-content/...escription.jpg
There is no frame crack. It is just a set of scratches through the paint and primer. The white is the primer I assume. I ended up for now trying this:
https://reviews.mtbr.com/workbench-h...your-chainsuck
From the link: "Finally, if you’re worried about chainsuck messing up your beautiful paint job or carbon chainstay, add a “peeler” to knock the chain loose if it ever tries to wrap back up and around. Zip-ties can do this pretty easily. (See the photo below.) Position them as close to the chain ring teeth as practical so that they can catch the chain before doing damage."
I touched up the area again with some matching paint I have. Covered this with a piece of 3M electrical sealing tape and then a zip tie on top of that. The tape keeps the zip tie from moving down the chain stay as it is tapered to the BB. Went on a good ride today and tried all kinds of different shifting patterns on the front chain rings and no chain suck happened. The bicycle shifts perfectly all around and the drive train is quiet. I see no bent chain ring teeth, but I would say my large chain ring is worn as it is aluminum and shows some burring. The small chain ring is steel and is in much better shape.
