Downtube Shifters
#101
one trick with DT shifters is to put a little slack in the cable of the left hand shifter ,
this will make double shifts easier as the left lever will be closer to the position of the right shifter.
the left lever does not have to travel as much so you will still have plenty of travel.
Likes For cjenrick:
#102
Not my preference, but to answer your question, it is much easier to learn than balancing and pedaling your bike.
I would rather have a bar end shifter. You can convert it easily, if you prefer.
#103
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,488 Times
#104
Quoted: 3352 Post(s)
Liked 1,056 Times
The bottom line tho about down tube shifters is the low friction, since the only cable tubing might be at the turn around at the RD. They stay in adjustment much longer. The other plus is the clean look since there is far less tubing flapping around in the wind.
Likes For rydabent:
#105
Quoted: 2281 Post(s)
Liked 1,710 Times
I just got a bike with downtube shifters last summer, and at first they took a little getting used to. In fact, I think I'm still getting used to them because I find it hard to keep pedaling (gently) while shifting due to balance and my knee possibly hitting my hand while shifting the lever. But it's no big deal to stop pedaling & shift, then resume pedaling. But they are indexed shifters and I don't feel like I need to shift all that often, so it's good. But yeah, when I first got the bike it took me a while to know where to reach for them with my hand.
#106
you could gain clout in the old days if you had a pair of Campagnolo down tube shifters, all the other teenagers would be in awe, they gave your bike a real cool look, only problem was now you had to watch your bike all the time.
hard to tell what kind of index system you have just by the looks.
#107
señor miembro
Liked 6,488 Times
This reminds me when I was in the bike shop years ago looking through their bins of used parts. I had one of my vintage bikes with me with its down tube shifters and clips & straps. This random ogre approached to say clips and straps were unnecessary and he hit his knees on down tube shifters. I tried to be kind for a short while, but he kept on. Very bizarre behavior. Like he was trolling me in person. I finally said I didn't work there and he needed to tell his troubles to an employee. One of the guys behind the counter overheard me and appeared not too amused.
#109
Liked 1,710 Times
#110
señor miembro
Liked 6,488 Times
#111
Quoted: 11 Post(s)
For me it's downtime shifters with straight up friction shifting all the way. No Syncro shifting. No SIS indexed shifting. No Brifters. My reasons is simple: A friction shifter setup allows me to run my bike as a 6, 7, 8, 9, or 10 speed by doing nothing more than swapping out my rear wheel and chain. Try that with an indexed system!
Why would I want to do this? I like the flexibility of being able to ridie a vintage bike as it was intended with its original group-set when I'm feeling nostalgic one day and then quickly switch over to a set of modern wheels that are lighter, roll faster, and have a few more gears when I am training in hilly country.
Other advantages? For those with carpal tunnel, arthritis, or elbow tendonitis, down-tube shifters place much less strain on the body than say brifters. They give you a bio-mechanical advantage by engaging your whole arm (wrist, forearm, elbow, upper arm and shoulder) when shifting, thereby reducing strain on the wrist induced by brifters. Down-tube shifters also get you to vary your position frequently by force you to get off the hood, drop your shoulder, and swing your arm slightly. In my experience, this helps prevent numbness of the hands on longer rides. If you have ever been on a ride and found your indexing is off resulting in poor shifts or a noisy drivetrain, you will appreciate the ability to trim your gears on the fly when using friction shifters -- no need to waitfor a tune-up. I could go on . . .
#112
there is one place where you do not want to be fooling with DT shifters, and that is if you are going like 50 mph and you want to drop your buddies, so you need to shift to hit 55 like fast freddy, can you hear all those clicks?>
#113
Quoted: 252 Post(s)
Liked 67 Times
I still use downtube shifters, but went to index from friction in 2015.
What I find interesting about downtube shifters is the right or left hand shift technique. I learned to use my right hand for the right shifter and left for the left. But there are those that use their right for both and reach across.
John
John
I ride DT frictions shifts exclusively (still) and I am tired of it and don't see how it can have appeal, at least from a practical view. Constant reaching down is worse for those of us who ride with hands mostly on bar tops, it distorts your body geometry on the bike and saps your energy, if ever so slightly but you notice it when you mess up with shifting and you need to fumble down there longer than usual (bike pros would certainly consider that big minus nowadays when every watt is counted). It doesn't help that I ride my circuits on a very up and down rolling roads that require very frequent shifting to maintain efficiency (I talk about sporting rides).
Once when I visited my sister that lives some five miles away, I counted how many times I shifted to get there and I was myself surprised at the high count. It was because I talked about getting newer bike with this more modern shifting, indexed and on bars, and people around questioned why would I need it. To people who ride bikes for light recreation and hardly shift gears at all, that seemed like pure fashion upgrade, waste of money.
#114
Quoted: 321 Post(s)
Liked 263 Times
I still use downtube shifters, but went to index from friction in 2015. I have used STI’s and they are better, but downtube can be fun. They work well with a triple crank and massive gear changes can be down quickly.
I changed to index for those times when transitioning from downhill to a quick out of the saddle uphill and hitting the downshift perfectly. As I’ve gotten older I need more of a downshift and I wanted the shift to be there.
John
John
They have a lot to recommend them. Perfectly easy to use especially if indexed. If not indexed especially easy to adjust. Very easy to change cables. They can be disassembled by people who aren't Japanese robots with seven hands and don't cost 200 notes a pop if you fall off and get sand in them.
#115
Quoted: 321 Post(s)
Liked 263 Times
I wonder if cassettes/freewheels also used to last longer before indexing. They were just plain old teeth not all thin and twisted and strange looking.
#116
Quoted: 11 Post(s)
My bikes are from the early to mid 80's. The front forks on road bikes of this era generally have the same 100 mm spacing as modern wheels that use quick releases. The rear spacing of the dropouts on these bikes is 126 mm. So, yes, the rear fork needs to be opened up 2mm on each side to accommodate today's QR rear wheel as these require a 130 mm spacing. One bike has longer rear stays than you would see on a modern bike and it can be opened easily to occomodate my Campagnolo Zonda rear wheel. Another with shorter rear stays was more resistant, so I cold set the rear triangle to 130 mm. Not something I would recommend for a truly collectable vintage bike, but doable. There a threads detailing the process in the Vintage Bike section.
#117
Quoted: 405 Post(s)
Liked 430 Times
5 speed = 120
6 speed = mostly 126, some 120s (Suntour "Ultra-6" freewheels were designed for this)
7 speed = mostly 126, some early 90s bikes were 128 so that they didn't have to build 2 different frames.
120s usually require cold-setting. I've never had a problem putting a 130 hub directly into a 126 frame, regardless of material. I wouldn't sweat it.
--Shannon
--Shannon
#118
the top ten racers of all time used downtube shifters , no wait, what did Valverde use?
far more races have been won with DT shifters but that will change some day,
1. Eddy MERCKX
58793 2. Sean KELLY
46053 3. Gino BARTALI
45784 4. Alejandro VALVERDE BELMONTE
42837 5. Francesco MOSER
38430 6. Joop ZOETEMELK
37781 7. Raymond POULIDOR
35748 8. Roger DE VLAEMINCK
35564 9. Felice GIMONDI
35319 10. Bernard HINAULT
1. Eddy MERCKX
58793 2. Sean KELLY
Likes For cjenrick:
#119
Wireless, digital, virtual downtube shifter kickstarter. Who's in? But seriously, my daily training ride for the last 40 years was an old Cannondale Black Lightning, till I turned my back on it for a minute. Downtube shifting becomes second nature and plenty fast enough for solo rides. Really miss that bike, but pity the poor soul who tried to pawn a bike cost me $45 used at a Trexlertown swap meet,
#120
Quoted: 252 Post(s)
Liked 67 Times
Actually at the time, I wasn't aware that that is because of newer standard, I thought it was because of the wider cassette. I bought new clincher wheels for the bike (the originals were tubular rims) and the rear one came with the cassette already mounted. I was in a bike shop and I said to the guy selling there that I liked the wheels on one of the bikes in showroom and asked if I could buy such wheels and the guy quoted me a price and took them off the showroom bike right in front of me ...
#121
Bikes: 1984 Gitane TdF, 1986 Look Équipe, 1983 Colnago Super
Quoted: 113 Post(s)
Liked 137 Times
This question is another reason for n+1
I have 3 road bikes, one with STI brake-shifters, one with Suntour bar end / barcon shifters, and one with Simplex down tube shifters.
If you can only have one bike, then I'd recommend integrated brake-shifters. It's nice to be able to shift relatively easier while out of the saddle, or going uphill. Also, while on group rides most others have them, and I believe it's easier to stay in-synch if you have the same system.
That said, I don't find myself riding significantly faster on the newer bike with brake-shifters. Some of my PR's on Strava segments are with my 37-year-old, down tube shifting bike, and it's 4 lbs. heavier than my 7-year-old bike. I think it's because I get out of the saddle more often on the bike that has fewer gears.
I have a theory that the best technology is what was state-of-the-art when you were 23...
#122
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
I had never used them before but recently bought an old bike with them and I find I love them. For some reason, when I ride my bike with stem mounted shifters, I reach for the STIs and when I ride my bike with STIs, I reach for the stem. But this bike with the DT shifters just feels so natural.
Likes For Chuck M:
#123
My first race bike had Campagnolo bar end shifters until someone came alongside me on a hill and dropped me into fith gear and out of the race. Switched to downtube shifter then and never went back.
The Mondia I now ride has Suntour Skitter drive set which has the larger cogs front and back as the start or base gear. I still get confused when switching bikes.
