Worn Hub?
The Left Coast, USA
Worn Hub?
I have a couple of older wheels, fronts, with cone adjustments that feel fine off the bike, just the right amount of friction. But when I put the wheels on a fork I get side to side play, I can almost rattle the front wheel back and forth between the brake pads. I'm scratching my head, why are those wheels acting loose only when in the forks? I've tighten the QRs down pretty hard.
Worn hubs?
Worn hubs?
There is more to life than simply increasing its speed. - Gandhi
Quoted: 1163 Post(s)
Liked 442 Times
Worn hubs?
Worn hubs?
Usually the (slight) axle compression applied by the quick release skewer will make a perfectly adjusted hub start to bind slightly. Depending on the design of the hub, you may be able to do final bearing pre-load dynamically in the frame using your cone wrenches on opposing sides of the axle to subtly tighten the cones another one sixteenth to one quarter of a turn. If you can’t do this while mounted on the bike, then just remove the wheel, loosen on of the locknuts while keeping the cone steady with your cone wrench then tighten it the required amount before snugging up the outer locking nut against the cone once again. Then check it again after remounting I the frame and your previously coarse axle adjustment will now be approaching that ideal where it spins perfectly freely yet has (next to no) perceptible play.
The Left Coast, USA
Brilliant answer, thanks.
Really Old Senior Member
Tightening the QR REMOVES play in the bearings.
It sounds like you have the opposite problem, which frankly, doesn't make sense. You'd have to have a bent axle that straightened when clamped or something odd like that.
Did you describe the problem "backwards"?
Quoted: 4205 Post(s)
Liked 3,864 Times
No answer of even speculation but a comment about bearing adjustment and tightening in the frame/fork. It's well known that a QR skewer compresses the axle and causes some adjustment preload increase. JA Stein makes a tool for adjusting the hub bearings with a preload as will be the case when the wheels are in the frame. Here's the link. https://www.steintool.com/portfolio-...ub-axle-vises/ With nutted axles the compression is only between the lock nut/cone and the axle nut. There is no compression between the bearings, no change in adjustment.
One mistake I have made that resulted in weird adjustment and spin issues is to have one too many balls in the bearing. This even makes the rim look out of true, but at a changing location that's half the period of the wheel's rotation. Andy
AndrewRStewart
AndrewRStewart
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
Possible the hub cups are loose?
Seen this happen with old cheap Suzue hubs....basically the adjustment is fine, just that cone / balls / and cups are floating with hub shell free to wiggle a tad.
=8-)
=8-)
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
