Snapped off bottle cage braze on
Any ideas for putting this back on? Braze? I have a basic Home Depot brazing kit. Any chance I can get it back on in a sturdy way without massive paint damage?
Wasn’t planning on refinishing this one
Likes For thinktubes:
Likes For jackbombay:
Shifting is fun!
Bikes: Yes, please.
Quoted: 2193 Post(s)
Liked 4,587 Times
I'm not familiar with JB Weld, but if it is some sort of super glue, then yes, that's what I would do. And like jackbombay says, prepare the surfaces meticulously.
Likes For non-fixie:
Sounds promising. Would you trust it? I’m not too familiar with the product and this would be a build for someone else to use as a reliable commuter
Shifting is fun!
Bikes: Yes, please.
Liked 4,587 Times
For re-attaching a seat stay to the seat lug, probably not. But for a bottle cage, sure.
Quoted: 457 Post(s)
Liked 462 Times
Hmmm, I would certainly use it on my own bike, on someone else's the stakes are a bit higher, but its quite tough, JB weld website claims a tensile strength of 3960 pounds per square inch of adhesion surface.
Old fart
Quoted: 3583 Post(s)
Liked 3,395 Times
Not with a fuel/air torch; it would take too long to get up to temperature and cause extensive paint damage. To do it properly, you'll want fuel/oxygen and a high silver content rod. But before that, I'd try JB Weld or something similar, as suggested above. If it fails, you're no worse off than you are now, and can always use a clamp to hold the cage in place.
Quoted: 753 Post(s)
Liked 735 Times
Theres a black locktite thats used for gunsmithing as a basically a silver solder replacement. I think you need a very clean surface for that kind of non gap filling glues.
Quoted: 3464 Post(s)
Liked 2,827 Times
Wild, maybe a touch of silver at one point of the diamond, maybe, otherwise when flux becomes a structural bonding agent.
mask off well and often, abrade surface, the boss side will be the trick. Picklex 20? (too expensive)
thread a long bolt into the boss as a handle , run a nut to secure, and go at it with a wire wheel on a dremel?
Bikes: Numerous
Quoted: 1676 Post(s)
Liked 3,084 Times
You can look into a rivnut. That’s how the bosses are secured on my aluminum TT bike.
Edit - rather than bosses, I should say it provides a threaded insert for the bottle cage bolt to secure directly into.
https://en.wikipedia.org/wiki/Rivet_nut
Quoted: 1301 Post(s)
Liked 1,903 Times
The clown-eye or diamond boss looks like it didn't have any brass under it. You could try cleaning the parts with a Dremmel tool and epoxying the part back in, but even with 2800 psi epoxy it would be weak. If you have a new clown-eye you could use a riv-nut, or even drill the old boss out of the clown-eye and then riv-nut it in. Some epoxy or JB weld under the eye and then touch it up with some enamel paint. All are work arounds, and not as good a re-brazing. But should hold under normal conditions. HTH, MH
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3869 Post(s)
Liked 6,461 Times
Using a rivnut would ruin some aesthetic. Does the bike warrant aesthetic?
Is it the top or bottom fitting? If bottom, a simple fix, like jb-weld, will probably last longer there.
As non-fixie said, prepare the surfaces meticulously for the epoxy. Use tape on the paint. Follow the jb-weld instructions. Just buy the regular stuff. No need to go overboard.
Bikes: Indeed!
Quoted: 1506 Post(s)
Liked 3,463 Times
It looks like it was held on for all these years by nothing more than the paint. The JB Weld will be much stronger.
Brent
Brent
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
I'd use JB Weld and make sure I squished a little down into the tube to sort of "wrap" the binding stuff over the edge of the hole in the tube, like they do in "plaster and lath" walls. Oil the threads on the screw so it does not get stuck.
Likes For thumpism:
Liked 2,827 Times
Rethinking- Rivnut and a reuse or new diamond "stiffener"
Bringhneli, nova, ceeway, possible sources. JB weld and Rivnut it together in one swoop.
I wonder if there is any braze holding the stiffener to the threaded insert.
Bikes: 1973 Colnago Super, Litespeed Classic , Automoto , Pinarello Gavia TSX,Eddy Merckx Corsa Extra,Eddy Merckx EMX-5 , 1982 Moser SL, Concorde TSX, Vitus 979 KAS. Diamant SLX,60's Meteor
Quoted: 235 Post(s)
Liked 947 Times
clean it til you get bare metal, JB Weld and your done.
Likes For Manny66:
Likes For Hudson308:
Bikes: Cervelo S5, Cannondale AL1 Lefty MTB, Trek X01, Trek Farley 7,1951 Raleigh Sport, 57&60 Raleigh Tourist, 70 Raleigh Super Course, 80's Soma Prestiege,72 Raleigh Grand Sports, 85 Club Fuji, 76 Raleigh Competition, 85 Panasonic,70's Peugot u08. & more
Quoted: 39 Post(s)
Liked 25 Times
Clean it and use JB. As stated before if it does not hold you are no worse off than now. Jb is tough stuff!
Quoted: 1079 Post(s)
Liked 1,019 Times
Clean meticulous and install a river nut then grind down the backside of the diamond and drill it out the center so it can slip over the rivnut. Little light epoxy to hold it in place. It'll be purely decorative at that point. Paint the edges to keep it clean.
Quoted: 2362 Post(s)
Liked 1,746 Times
If it's one of two sets of bosses, you could at least use this set just for a pump, and use the other for a water bottle. I would be.... cautious about the weight of a full water bottle attached to this boss JB Welded to the tube.
Schwinn MTB?
Schwinn MTB?
Thanks for all the suggestions everyone. It was the bottom boss so I tried JB Weld. It’s been curing since yesterday so I’ll have a look today. Hopefully all good. I’ll update once I check it out
Likes For krems81:
