What's the most reliable hardware choices?
Brakes - mechanical disk brakes?
Drivetrain - single speed belt drive?
Tires - tubes with liners?
Conversion kit?
Solar panel?
Bags - Revelate?
Conversion kit?
Solar panel?
Bags - Revelate?
Pennylane Splitter
Bikes: Yes
Quoted: 1807 Post(s)
Liked 1,448 Times
Folks go on tours with everything from Walmart bicycles to custom-made steel framed wonderbikes. As long as the 'hardware' is maintained and used within its design constraints, it'll work fine.
Likes For skidder:
Quoted: 3462 Post(s)
Liked 1,468 Times
Defining reliable, for what purpose?, for what location?, for a user that has how much mechanical knowledge?, for what length of time?, for what road or trail surface?
How you define or measure reliable for a three day bikepacking trip is very different from what is reliable for a loaded touring trip where you are over 100 km from any form of retail establishment and several hundred km from a bike shop or hardware store.
Likes For Tourist in MSN:
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 324 Times
Easy choices. Back wheel has Rohloff14 with TRP Spyre cable disc brake.
Front wheel hub is a SA XL-FDD dyno DRUM brake. Always works in any weather with ZERO adjustment, for 30,000 miles. A strong fork is needed.
For 35/ 38 mm tires, Velocity Dyad rims. Except with a Rohloff, use 2.3/ 2.0 spokes with locking brass nipples.
Sweptback bars for ultimate comfort.
Any IGH will have near zero chance of spoke breakage. NOT so with lopsided dR wheels.
Bare Alu parts are a big fail IMO. Easily scratched and prone to sticking to steel tubes.
Likes For GamblerGORD53:
Quoted: 2236 Post(s)
Liked 1,314 Times
Reliable can also be determined either by the frequency of failure or problems once failures occur.
Perhaps a Rohloff IGH may fail less often but if it does, you will have a long wait until it gets serviced and returned. No local shop will do that for you.
A derailer may fail more often (I've never had one fail on tour but everyone's example will only be antedotal) but it can repaired or replaced at most local bike shops.
Same logic applies to belt drive. Walk into a shop and see how many replacement parts they have in stock.
Revelate is a popular brand because they are light bags and were a good choice for racing bikepackers. They got a lot of good press off of that. Popularity does not equal reliable. Probably, from a practical perspective, Ortlieb seems to be a reliable bag of choice for bike tourists.
Brakes. Mechanical is probably easier to service in the field but hydraulic stop with better modulation. Reliable in different ways.
Tires. The most reliable would be solid rubber but the ride would suck. The spectrum between puncture resistance and speed goes on from there. Tubeless vs tubed depends on conditions I think. Ultimately if a tubeless tire cannot be repaired you throw a tube in it so... I run tubes with Stans fluid in them as a compromise. Some will or won't agree.
Everyone will have their own opinions for this question. There is no right or wrong, just perspectives. Look to the reasoning rather than the choice.
Likes For Happy Feet:
Liked 1,314 Times
Sometimes, if one reads internet sources, it seems they have a habit of copying and pasting material from other internet sources. Basically, people writing about subjects they don't know.
Some concepts are touted as the next big thing in cycling but that doesn't always translate into adoption on a wide scale. Touring is one of those genres that is slow to adopt so things like belt drives, tubeless, hydraulic etc... while having some place in modern cycling, may take longer to popularize, if at all.
If something is proven to work it will probably work again. Trying something new has the potential risk of ruining a tour, not just an afternoon ride.
aka Timi
aka Timi
If reliable is seen as bombproof, easy to repair, and spare parts available in most parts of the world, I think it would be a pretty old school:
26” steel mountainbike, no suspension
V-brakes
Shimano components
7 or 8 speed triple drive
Platform pedals
Here’s mine, an old Miyata On Off Roadrunner, fully loaded for the pic, though I usually tour much lighter on a Bianchi Volpe
V-brakes
Shimano components
Platform pedals
Likes For imi:
Liked 1,468 Times
If so, what is your budget?
Does it have to be small to carry into buildings like a folding bike or will it be stored outside?
I have a igh belt drive with tubeless tires, mechanical disk brakes, and drop bars. I was wondering what the tourists thought.
aka Timi
Of course there are many exceptions but I would say that steel is preferred somewhat over aluminium, and not many on full carbon bikes, mtb's with suspension or single-speed. High spoke count and high quality wheels are important. After that... well we're all over the place (pardon the pun)
Liked 1,314 Times
For commuting you have the option of refining equipment choices to what is available in your area. In that case, if you have a source for IGH belt drive etc... then they would be as reliable as anything else. If you break a chain, mechanical brake or derailer commuting you still have to fix them as well. The difference touring is you are away from your home base so you have to make due with what you can find on the road. There you have to play the law of averages or have a preplanned backup available.
Your bike sounds fine. I have commuted on all sorts of bikes.
Quoted: 226 Post(s)
Liked 45 Times
Many people have separate bicycles for touring vs commuting.
The commuting bicycle gets ridden daily, therefore, reliability issues have already revealed themselves and have been corrected.
Commuting bicycles are more reliable.
People drag out their touring bicycles once or twice a year and mechanical issues might not have shown themselves....yet.
The best assurance of reliability is to ride your touring bike everyday and make it your commuter bike.
Probably the same reason they fly B-52's and fighter jets often. (reliability vs availability = I'm getting into an area I don't know what I'm talking about)
Likes For boomhauer:
Liked 1,468 Times
For commuting, I would favor tubes over tubeless. I have never used tubeless so I might not be a good info source, but it is my understanding that sealant addition is required on a regular interval. I average one flat a year and I would rather deal with one flat than messing with sealant addition.
Nothing really wrong with mechanical disc or drop bars. But look at your disc brakes on occasion to see if the pads need replacement before you damage a rotor.
What about it? Are you looking to buy or do you have one? Not sure what you are asking here.
Bikeable
Quoted: 173 Post(s)
Liked 104 Times
I agree with what Happy Feet wrote. There is (unfortunately) this buzz that hydraulic brakes are unreliable? There is this double standard. Hydraulic brakes used in cars date back about a hundred years, yet (some) cyclists think the technology is too
'new and unproven for their bike?
do the hydraulic lines in your car run outside the body exposed?
do you load your car atop tractors, underneath buses, shoved in rail freight cars unnerneath sacks of spuds?
if a line gets snagged in the middle of nowheres, do you have the tools and supplies to repair it?
your mechanical brakes should work just as well for touring, and be easily repairable in the field.
if not, odds are you can pick up a cheap chinese caliper thingie at a village market in laos for $5.
Inspect and maintain what you have. If you find something keeps breaking, requires constant adjustment or just plain bothers you, then go to the local bike shop, discuss your issue intelligently, identify your budget and determine if worth investing the time/budget to "upgrade".
You get three options in most situations, but really can only have two.
1. Low-maintenance/longevity,
2. Cheap, and
3. Lightweight.
Choose wisely for your situation.
2. Cheap, and
3. Lightweight.
