Ultegra Di2 Rear Derailer - today I learned...
Old 06-23-19, 10:14 PM
ronin4740
Bikes: Giant TCR, Pure City Original Fixie, Fuji Roubaix, Raleigh M800
Quoted: 37 Post(s)
Liked 21 Times in 14 Posts
Today I learned that an Ultegra RD-6870-SS Short Cage Derailleur is firmware locked to not allow the configuration of an 11-32 cassette in the eTube software... So even though you can replace the jockey wheel cage with the GS version with a few turns of the wrench you can't program the darned thing correctly...
Grr...
Oh well, was a fun exercise in calculating chain length, swapping parts (the stupid screw that keeps the cage from rotating back too far would NOT budge on the new inner GS cage part - I had to dremel a slot in it to get enough torque on it to move it) and ultimately cursing the Gods in the heavens...!
Guess I'll just go order a RD-8050-GS and call it a day.
ronin4740 is offline
Old 06-23-19, 10:18 PM
Cyclist0108
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times in 1,164 Posts
I never told my Di2 derailleurs about my 11-36 cassette or my 46/30T crank. Yet it works fine.
That B-screw needs (needed) a JIS #2 screwdriver, or go buy a new bolt with an allen key head for $0.89 at the hardware store.
Cyclist0108 is offline
Old 06-23-19, 10:24 PM
colnago62
Quoted: 741 Post(s)
Liked 412 Times in 230 Posts
I use a 32 on my 9000 without a problem. If you plan on using the 32 in semi full sync mode, you have to use the custom to set up the cassette, or not. I could never tell th difference.
colnago62 is offline
Old 06-23-19, 10:30 PM
ronin4740
Quoted: 37 Post(s)
Okay. If you guys think it's okay to leave it setup this way with a 52/36 front chain ring set I guess I just won't worry about it then... Was a little worried as on the way up the cassette the sync mode doesn't shift to the little chain ring until the up shift to the 32T rear gear... and I can't seem to program it to shift down one cassette gear sooner for some reason... Looks like I ought to pick up a few JIS screw drivers as well. The hex bolt is a good idea as well.
Old 06-23-19, 11:37 PM
Cyclist0108
Occam's Rotor
Mine is programmed to mimic how non-electronic shifting works, so the gearing doesn't matter.
However, I have to ask why you would modify the rear derailleur, rather than simply get a smaller set of chain-rings.
Old 06-23-19, 11:44 PM
ronin4740
Quoted: 37 Post(s)
The cost of the 11-32 cassette and the gs cage parts was less than the cost of a smaller ultegra chainring set.
Also now I have a spare 11-28 cassette if I decide to buy a tacx smart trainer for off season...
Old 06-24-19, 08:34 AM
jadocs
jadocs's Avatar
Quoted: 942 Post(s)
Liked 527 Times in 349 Posts
That's fine if you do not use synchro shift. If someone uses synchro shift the rings and cassette matter because it uses the ratios to calculate where you need to be optimally.
jadocs is offline
Old 06-24-19, 08:58 AM
colnago62
Quoted: 741 Post(s)
There is a custom mode where you can manually set the parameters for where the derailleurs shift. It is a pita figuring out the gearing, but once you do, just save it and you are good.
Old 06-24-19, 09:06 AM
jadocs
jadocs's Avatar
Quoted: 942 Post(s)
That's correct, so far setting the correct (default) ratios has been working great for me.
jadocs is offline
Old 06-24-19, 09:26 AM
TimothyH
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times in 469 Posts
What exactly is locked out? Is 11-32 not an option in E-Tube when it detects a 6870 short cage? Sincerely asking. Not trying to challenge.
The RX805 clutch derailleurs will cause the two smallest sprockets to be locked out when the front is in the small ring. You will not be able to use your small front ring with the 11 or 13 tooth sprockets in the rear. It just won't shift into those combinations.
The RX805 also eliminated manual mode. It is semi-sync or sync only. The workaround is to set the front to shift zero times when the rear is shifted - effectively the same as manual mode.
I don't know if the 8050 behaves the same as the RX805 but keep it in mind as you do the setup.
-Tim-
TimothyH is offline
Old 06-24-19, 01:08 PM
ronin4740
Quoted: 37 Post(s)
11-32 isn't an option when etube sees a short cage derailleur. 11-28 is the largest selection.
I'd also like it to shift down to the little chain ring from the big chain ring when going from the third largest to second largest cassette gear but I can't seem to configure it to do this.
More fiddling, video watching and maybe a shimano support call are in my future.
Old 06-24-19, 02:58 PM
cthenn
Bikes: 2023 Canyon Aeoroad CF SL, 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, Some BikesDirect MTB I never ride.
Quoted: 647 Post(s)
Liked 136 Times in 89 Posts
This is making my eyes water a little bit, but are you saying you can override the setting where the synchro is forced to shift? My synchro shift going to a lower gear is not where I'd like it to be, but I can't seem to program the gear combo where the synchro shift happens. IE-I have a 50/34 and a 12x28 on the back, the synchro shift going down gear is the next shift after 50-25(second cog), whereas I want it to synchro shift at 50-23(3rd cog). I like the upshift end just fine, so I don't want to alter that to "fix" the other side of the synchro shift.
Long story short, is there a way to override etube settings to set the synchro wherever I want? And if so, does that affect actual shifting performance?
cthenn is offline
Old 06-24-19, 04:44 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4733 Post(s)
Liked 1,532 Times in 1,003 Posts
hmm.. is it worth waiting for Di3?
Sy Reene is offline
Old 06-24-19, 11:44 PM
Badger6
Obsessed with Eddington
Badger6's Avatar
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times in 368 Posts
Originally Posted by cthenn
...is there a way to override etube settings to set the synchro wherever I want? And if so, does that affect actual shifting performance?
Yes, and I think so.
You can set the cog where the front chain ring shift is triggered in S1 mode, for both up and down...and how many cogs it moves in relationship to the front chain ring shift. Google the procedure, it's explained for every permutation of the eTube software. I'll let an experienced mechanic answer with the science, but it strikes me that shifting the front works better at certain points on the cog as opposed to others, and experimentation, in my experience, is useless on a stand, you need to be on the pedals (at least I did).
For a video explaining the programming using the desktop software:
Badger6 is offline
Likes For Badger6:
Old 06-25-19, 12:01 AM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 18883 Post(s)
Liked 10,646 Times in 6,054 Posts
I've been thinking about going back to this.
Seattle Forrest is offline
Old 06-25-19, 03:16 PM
cthenn
Quoted: 647 Post(s)
For a video explaining the programming using the desktop software: https://www.youtube.com/watch?v=OSubp_ktTps
LOL, duh, didn't even think to Google/YT this...I just got caught up reading and posted my question. Thanks, I'll check this out!
cthenn is offline
Likes For cthenn:
Old 06-25-19, 04:00 PM
ronin4740
Quoted: 37 Post(s)
The video is great but he never shows moving the top down in blue on the left side. That's what I haven't been able to figure out how to do. In my configuration I'd want that blue highlight to be on 2.17 instead of 2.00 to avoid the top jockey wheel from getting pulled in really close to the big gear in the rear cassette while the bike syncro shifts...
Maybe I'll ask the bike shop when I pick it up today.
Old 06-25-19, 04:10 PM
Badger6
Badger6's Avatar
Quoted: 532 Post(s)
Hmmm. I adjusted mine using the iOS app, and I was able to move each box. If I recall, however, at certain times some of them are locked from moving, I just don't recall the instances that did that in the app. What I do know is that I was able to fully adjust everything. Ask your shop, the Shimano software/apps are not always as intuitive as you'd think.
Badger6 is offline
Old 06-25-19, 04:14 PM
ronin4740
Quoted: 37 Post(s)
Ya... I'm going to wish I'd brought the USB adapter with me. The shop may have one though. I can at least show him what I'm talking about in the Android app.
Guess I could download the iOS app to my iPad as well.
Seattle Forrest
0
09-20-17 09:04 PM
Ozan Guner
Road Cycling
3
05-19-15 02:34 AM
merlinextraligh
Tandem Cycling
4
05-01-15 11:54 PM
jvj
Road Cycling
6
02-15-14 07:08 AM
totalnewbie
Road Cycling
11
12-14-13 06:29 PM
