Stuck bar stem help
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 460 Times
Stuck bar stem help
Picked up a 1986 Miyata 912 that was in like new shape but I can't seem to get the bar stem loose.
I've sprayed though the bottom with PB Blaster and let it sit but it doesn't want to budge. Any recommendations?
Insane Bicycle Mechanic
Quoted: 806 Post(s)
Liked 709 Times
Pictures would help.
Did you loosen the center bolt and tap it downward to loosen the wedge? Also, after 30 years it's likely that there is some corrosion between the stem and the fork's steerer. Flipping the bike upside down, filling the inside of the steerer with PB Blaster, and letting it sit a couple days is what I would do.
Jeff Wills
Jeff Wills
Quoted: 677 Post(s)
Liked 460 Times
Quoted: 1438 Post(s)
Liked 1,092 Times
If corrosion has caused the wedge to stick it will likely take a LOT more that a tap to dislodge it, although it would be prudent to try that first. In either case after a PB Blaster (or better, Kano Kroil) treatment I would suggest removing the wheel and supporting the fork crown with something like a piece of 2x4 securely clamped on its edge to a solid object, with the fork ends off of the floor to avoid damaging them. This will also cause the force not to be dissipated in the tire or flexing of the fork blades. Then, back the stem bolt out a turn or so and hit it HARD with something heavy like a hand sledge to break the wedge loose. You need to generate enough peak force to break the wedge loose, repeated tapping may not reach sufficient levels of force.
Take the handlebars, front brake caliper and, front wheel off. Hang the bike from the ceiling over a plastic drip pan. Start basting the head tube with diesel fuel. Wait a day or two. Then, it's Hammer Time!
Quoted: 677 Post(s)
Liked 460 Times
How far do I have to loosen the center bolt before I whack it?
Quoted: 1062 Post(s)
Liked 665 Times
I'd say only about a quarter inch. If you can get the wedge to budge by even a fraction of a mm, you've won the battle. You want the bolt to still be threaded into the wedge. You should be able to drive the bolt head all the way back into the stem.
Now, once you've gotten that far, the stem might slide out easily, or it might still be stubborn if there's a lot of corrosion in there, but at least that's another battle.
Quoted: 677 Post(s)
Liked 460 Times
Thanks guys. I let it soak for 2 days with PB Blaster .Straddled the crown of the fork with a 2X6 and 1 whack with a 4 lb. hammer loosened it right up. Thanks again
Likes For robertj298:
Quoted: 806 Post(s)
Liked 709 Times
Like I learned years ago as a skinny lad: if at first you don't succeed, Get A Bigger Hammer.
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
