The longest, hardest climbs are in North Georgia
Old 08-04-19, 08:27 PM
Spoonrobot
Spoonrobot's Avatar
Quoted: 1217 Post(s)
Liked 187 Times in 118 Posts
Removed
Spoonrobot is offline
Old 08-04-19, 09:53 PM
TimothyH
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times in 469 Posts
North Georgia is pretty rugged.
The comment section of bikepacking.com's write up of the Trans North Georgia route is full of people surprised at the elevation here. Stuff like, "Holy moly, that's steeper than the Colorado Trail...and it's in Georgia." and similar.
https://bikepacking.com/routes/trans...-georgia-tnga/
-Tim-
TimothyH is offline
Old 08-04-19, 10:03 PM
HTupolev
Quoted: 1979 Post(s)
Liked 1,298 Times in 630 Posts
That does look tough. The only gravel climb over here that I've done which has a similar amount of altitude is NF-18 (Segelson Road), which takes you from the valley floor to this:
It's steadier than your climb, though. Lower back pain is a real threat on Segelson... if you get into too steady a climbing form and forget to loosen up on the shallower spots, you can end up starting to hurt in steeper spots where you can't get out of the saddle as easily, heheh.
We've got some decently scary 1000-2000 foot hills, though. The ride I did yesterday covered only 28 miles, but it included three ~mile-long stretches that each averaged 12-13%:
Even though we all brought sub-1:1 gears, we were grinding horribly on the steep spots.
We hadn't ridden the final climb before, and there are lots of roads around it to check out... maybe that'll be the focus of another ride. It heads up one of Mount Pilchuck's southern buttresses. The views from that road didn't photograph as well as I'd hoped, but they were fantastic.
HTupolev is offline
Old 08-04-19, 10:10 PM
CliffordK
CliffordK's Avatar
Quoted: 18378 Post(s)
Liked 4,512 Times in 3,354 Posts
That is quite the climb for gravel. Not real steep overall, but a few mighty steep sections.
I tend to look for paved road for climbs like that!!
We've got a few 10 to 20 or more mile long climbs around here, but mostly paved. I can think of a few gravel logging roads that I've mostly driven on, and there'd probably be more if one looked.
CliffordK is online now
Old 08-04-19, 10:47 PM
softreset
Quoted: 129 Post(s)
Liked 54 Times in 25 Posts
There's one about 20-minutes from where I work that's real popular with the locals.
Mix Canyon
Vacaville ? The Diabolical Duo ? Mix Canyon & Gates Canyon (Super Steep) Hill Climbing
It's not all gravel but some of the gravel sections (not captured in those photos at the link above) are real brutal. A co-worker, 2-3 years ago chose it as his hill for one of his many Everest'ing challenges.
I've done the climb once, last fall and I did a lot of hike-a-bike. But my perceived fitness absolutely did not align with required fitness.
softreset is offline
Old 08-04-19, 11:14 PM
terrymorse
climber has-been
terrymorse's Avatar
Quoted: 3432 Post(s)
Liked 3,567 Times in 1,793 Posts
White Mountain, California
The climb from Big Pine (3988’) to White Mountain Peak (14,252’) might be the most vertical in the US.
I did it on a hard tail in 2004, but didn’t quite make the summit (didn’t bring enough food). It was a slog.
https://www.tourofcalifornia.org/201...-peak.html?m=1
terrymorse is offline
Likes For terrymorse:
Old 08-05-19, 06:01 AM
shelbyfv
Expired Member
shelbyfv's Avatar
Quoted: 3674 Post(s)
Liked 5,437 Times in 2,763 Posts
I'll bet that would flatten out quickly if you heard some banjo music!
shelbyfv is online now
Old 08-05-19, 06:54 AM
Koyote
Quoted: 6971 Post(s)
Liked 10,968 Times in 4,692 Posts
Make the grade higher and add some virtually unrideable mudbogs to your climb and it might be as tough as this one: https://ridewithgps.com/routes/29626799
And then there's this one, which is next-level: https://ridewithgps.com/routes/30234764 I knew I was in for a long day when I saw all the people on MTBs.
Koyote is offline
Old 08-05-19, 07:17 AM
dgodave
Behold my avatar:
dgodave's Avatar
Bikes: 2019 Gorilla Monsoon, 2013 Surly Krampus, Brompton folder
Quoted: 6941 Post(s)
Liked 444 Times in 289 Posts
Wow! I never knew this existed. Maybe someday on my way to SF. It does look like a grind tho.
dgodave is offline
Old 08-05-19, 07:23 AM
TimothyH
- Soli Deo Gloria -
We are the ones making the music.
-Tim-
TimothyH is offline
Old 08-05-19, 08:50 AM
shelbyfv
Expired Member
shelbyfv's Avatar
OK, each to his own, but I'm gonna wear my "I'm not Ned" safety vest if I ride down there.
Old 08-05-19, 09:09 AM
Shimagnolo
Shimagnolo's Avatar
Quoted: 3376 Post(s)
Liked 5,518 Times in 2,860 Posts
I don't normally go looking for gravel roads.
But here is one I tried once just because it is the steepest road within easy riding distance.
Narrow as hell, and loaded with ruts from snow/rain drainage.
Lickskillet Road, near Boulder.
It runs between Lefthand Cyn, and the town of Gold Hill, and is one mile long.
Note the gradient chart at the bottom of the image:
Shimagnolo is offline
Old 08-05-19, 09:12 AM
Shimagnolo
Shimagnolo's Avatar
Originally Posted by Spoonrobot
Anyway, my thread prompt was I saw a couple riders I follow on Strava (Erik Newsholme & Brian Toone) did Pikes Peak but I've given to understand that's been paved.
For cyclists, the paving of Pikes Peak is a mixed blessing;
When it was gravel, cyclists were prohibited.
Since it has been paved, cyclists are allowed.
Old 08-05-19, 09:15 AM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times in 422 Posts
Is that a FS 29r triple with 2.25 inch meats on California gravel? Oh My! Is that even allowed in the gravel section?
trailangel is offline
Old 08-05-19, 09:30 AM
terrymorse
climber has-been
terrymorse's Avatar
It is definitely a grind, more so because there is no water on the route. We hid some water near the Schulman Grove visitor's center the day before.
The worst part was the pounding on the body during the descent on washboard surfaces. That beat me up pretty badly, a hardtail was probably not the best choice.
It took days to recover from the beating. Here are my notes:
Ride day: 82.7 miles, 12,480 feet, 9 hours 21 minutes; bonked (dummy), sore ankles/wrists/back
Next day: drive home, sore & tired
Next day: rest day, still sore and tired
Next day: 43.9 miles, 3540 feet, 3 hours 10 minutes; recovery ride, left hip still sore
Here's the route on ridewithgps
EDIT: Photos of White Mountain — some taken during the ride.
Ride, Rest, Repeat. ROUVY: terrymorse
Old 08-05-19, 10:42 AM
Koyote
I'll take a few longer climbs over several shorter rollers like that. Here's a new event this year that I'm waffling on, steep gravel rollers are so much more mentally taxing than just pointing the bike straight up for an hour+.
Agreed. I lived and raced in CO, and did some of the big climbing events, like the Mt Evans Hillclimb. Riding uphill for 28 miles is a slog, but do-able with persistence. Out here in PA, though, we have shorter but steeper climbs. Yesterday I was on a paved road that maxed out at 25% grade; the climb wasn't too long, but that is steep.
Koyote is offline
Old 08-05-19, 10:49 AM
ksryder
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times in 329 Posts
I was on one of these climbs a few years ago at night when my dynamo stopped working.
That was the night the lights went out in Georgia.
ksryder is offline
Likes For ksryder:
Old 08-05-19, 12:48 PM
terrymorse
climber has-been
terrymorse's Avatar
That's awesome. What are the altitude effects like doing it as one ride?
Well, I definitely noticed a drop in my power output above about 12,000 feet. I slept at altitude for a few days beforehand, which I think helped overall.
How you feel at altitude and how you're performing may not match up. When I rode up Mt. Evans on a road bike, I felt really strong towards the summit. Later, I checked my stats. My climbing rate wasn't anything to write home about, the road grade just wasn't very steep.
Old 08-05-19, 12:52 PM
dgodave
Behold my avatar:
dgodave's Avatar
Awesome. Thanks!
(So.... I'm not ready to agree that the longest hardest climbs are in Georgia.)
dgodave is offline
Old 08-05-19, 02:33 PM
bonsai171
Quoted: 750 Post(s)
Liked 90 Times in 70 Posts
But I'm curious what y'all have in your areas.
Down here we got the Cohutta, the best climbs of which are just south of the Tennessee border. Did this yesterday, it's a monster. Entirely gravel with varying surface, short sections of smooth dirt, a ton of embedded rock, loose crusher run, lots of washboard and dozens of punchy 9-11% sections - that are also loose and chunky. It ate up a ton of riders, I passed several that were riding strong until mile 7-8 and then ended up walking after a seriously steep loose section. Guy ahead of me stopped, sat on the ground and when I asked if he was ok he said "I just can't climb anymore right now" with a thousand yard stare into the trees. The future as a chunky gravel road stretching up into the sky you climb but it never ends.
Anyway, my thread prompt was I saw a couple riders I follow on Strava (Erik Newsholme & Brian Toone) did Pikes Peak but I've given to understand that's been paved. So I was genuinely curious who has access to the longest unpaved climb. I suspect it's out in Colorado or Washington somewhere. Or even *gasp* California. Even if it is longer I bet it's not as hard as our stuff, Georgia gravel is the best. Unless I move somewhere else then that gravel'll be the best
Maybe a little OT, but please share some details on that bike. Suspension with drop bars? What frame is it? There are definitely some tough climbs in the Cohuttas. Did the potato patch climb last November. IIRC it was 1,500 ft climbing, with 12-15% grades. Took about an hour to climb, half hour to descend in rainy weather :-D
Dave
bonsai171 is offline
Old 08-05-19, 03:17 PM
HTupolev
Fun orthogonal fact: the bicycle in my photos above is a Stumpjumper.
HTupolev is offline
Old 08-05-19, 03:38 PM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 18883 Post(s)
Liked 10,646 Times in 6,054 Posts
I bet it's in one of the three states you mentioned. A lot of our state is Wilderness which means no roads, no bikes. So we might not have it.
The hardest gravel ride I did had 10 miles of chipseal at the beginning, probably disqualifies it. Involves 4,200' of vert, and drop dead gorgeous scenery.
Maybe the most impressive 100 % gravel ride I've done is Slate Peak, from Dead Horse Point. That was also about 4,200' of vert, over 10 miles, with sunshine at the bottom and icy trees at the top. This is the highest road in Washington. A thru-hiker who had just spent the spring, summer, and early fall walking from Mexico to Canada was seriously impressed that a person would want to ride a bike up that mountain.
https://connect.garmin.com/modern/activity/2023537925
The road goes right through a meadow.
I'd been wanting to do this ride for years, but the yellow trees are what I came for. It was the bike equivalent of a larch march.
Seattle Forrest is offline
Old 08-05-19, 09:44 PM
TimothyH
- Soli Deo Gloria -
How about Mt. Kilimanjaro?
TimothyH is offline
Old 08-06-19, 03:05 PM
Hmmm
Hmmm's Avatar
Bikes: TCX & CAAD3 SAECO
Quoted: 147 Post(s)
Liked 118 Times in 66 Posts
Surrounding area of Paris is pretty flat. Single track and fire roads are smooth and soft. It's a dream. Coming from Salt Lake City, Utah, where it's either straight up or flat into the desert. Paris is a gravel cycling dream for me. I'm back in SLC for the summer and can't wait to get back to ride in Paris.
Hmmm is offline
Old 08-06-19, 03:41 PM
Seattle Forrest
Is that this climb? If it is man that looks like a real butt kicker
It is … but in the interest of truthfulness and completeness, the first 10 miles or so of that segment are paved. It doesn't turn to dirt until the point where the Methow and Lost Rivers merge. The paved section is mild rollers, almost all of the climbing is on "gravel" (hard packed dirt mostly).
But that segment is the "correct" route for a ride like that, it starts and ends at the Mazama Store where you can get some great pastries and coffee.
Seattle Forrest
20
10-13-18 02:17 PM
VRC
Classic & Vintage
49
09-24-17 08:32 AM
Barrettscv
11
03-08-17 02:57 PM
Planemaker
Fifty Plus (50+)
2
09-14-15 06:06 AM
DirtRoadRunner
5
03-20-15 01:03 PM
