Brompton cables
Brompton cables
Old 01-19-24, 10:19 AM
hhk25
Bikes: 2017 Marinoni Tourismo Extreme, 1984 Trek 520, 1987 Niskhiki International, 2013 Brompton M6R, 2016 Brompton P6R
Quoted: 147 Post(s)
Liked 28 Times in 21 Posts
Brompton cables
IIRC, the shift cables are Sturmey Archer with the 3mm ends. Do both shifters use the same cable? Anyone know a source for the cables only in the US?
Alternatively, has anyone modified the shifter to accept more common cables?
hhk25 is offline
Old 01-19-24, 11:34 PM
Duragrouch
Quoted: 968 Post(s)
Liked 521 Times in 416 Posts
Hmm... I'll be interested to see responses. I don't have a Brompton, nor a Sturmey Archer anywhere around, so I'm curious about the cable sheath/housing diameter, and cable type. For modern derailleur systems, shifters should use cable housing with longitudinal steel wire under the plastic (this was pioneered with the rise of Index Shifting, as previous helical core housing had sufficient stretch/compression in bends to affect shifting). Helical coil housing is now relegated to brake cables. However, a S/A 3-speed IGH may not require as precision a cable, don't know. Pics from Sheldon Brown:
Duragrouch is offline
Old 01-20-24, 02:07 PM
Bleu
Bleu's Avatar
Quoted: 39 Post(s)
Liked 26 Times in 17 Posts
My Brompton's shift cable housing reads Jagwire LEX. Probably get this at most bike shops.
Bleu is offline
