Dynamo light newbie
Dynamo light newbie
I was excited to buy a bike that came with a dynamo front light along with a tail-light. Finally, no more forgetting to bring or charge lights/batteries. No need to put on/take off lights. Unfortunately the front light is about as bright as a scented candle. The tail-light is great though. The Performance Bike mechanic did mention that the light was more for being seen rather to see. His response when I expressed concern a front basket would block the light. Well, he wasn't wrong.
Is 30 lux particularly low light? From what I've read, setup of the hub is a big factor in ensuring the light is providing its max capacity? Or is 30 lux's capacity is to be seen rather than to illuminate the road?
If I want a brighter light, do I only need to replace the light bulb(s)? Or replace the light itself? Replace the entire dynamo system?
HEADLIGHT
Axa Blueline 30 lux, Steady Auto
TAILLIGHT
Axa Blueline led, Steady
Breezer Bikes | 2017 Liberty 1R+ ST | Bike Archives
For context, my USB light is 550 lumens and as a primary light, it's just about right for me. If I were to buy another USB light, I wouldn't go any lower.
HEADLIGHT
TAILLIGHT
Senior member
Quoted: 943 Post(s)
Liked 658 Times
Yeah 30 Lux is Just enough to make you visible not to light your way. 75 and up is what you need. The dyno hub won’t have a problem powering a brighter light.
Passista
Quoted: 866 Post(s)
Liked 721 Times
I don't know about lumens, but the B&M Lumotec Cyo Premium at 80 lux is a very good light.You can really see the road with it. As stated above, that hub won't have any problems powering it.
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
30 Lux is a measure of maximum brightness at a point, not over an area. Lumens measure total light emitted as perceived by humans, regardless of the distribution or concentration of the light. Neither measure gives a complete characterization.
Your generator produces 3 watts at maximum speed. From 3W a good LED lamp can emit ~300 lumens, max. That's like a decent flashlight; more than a "be seen" light but not a lot more.
Human perception of light is very non-linear. You'll have to have 600 lumens to barely notice the increase which can make a very good bike light if distributed well, and even more is better. So, you are still constrained by the power supply. Consider adding a good battery powered main light and think of the dynamo light you have as "be seen/get home."
Thanks to everyone for your informative posts. As someone who is on their first dynamo light--my base information was nil.
So it looks like the good news is that I can buy/install a brighter light. The bad news being that brighter may not be as bright as I wish.
Cygolite 550 is going for about $30 on Amazon...sigh, guess I'm sticking with detachable lights for awhile yet.
Quoted: 2604 Post(s)
Liked 1,933 Times
You can simply replace the light, and get up to 100 lux.
You'll want to be aware that a lumen is not equal to a lux. The Busch und Muller lights put more light on the road than battery powered lights with lumen ratings about three times higher than the BuM lux ratings.
This is probably irrelevant, since OP has already made up his mind: my experience was that 40 lux (one of the original Cyo lights) was adequate for suburban and urban streets, and for anything less than downhill speeds on rural, unlighted roads. The Cyo II is awesome, period.
https://www.amazon.com/Müller-Lumotec-Premium-bicycle-headlight/dp/B00G49RGJE/ref=asc_df_B00G49RGJE/?tag=bingshoppinga-20&linkCode=df0&hvadid={creative}&hvpos={adposition}&hvnetw=o&hvrand={random}&hvpone=&hvptwo=&hvqmt= e&hvdev=c&hvdvcmdl={devicemodel}&hvlocint=&hvlocphy=&hvtargid=pla-4584345018253018&psc=1
