Cadence - When do you Lug?
#76
Quoted: 1814 Post(s)
Liked 923 Times
Long climbs are much easier if you vary your climbing style. Spinning at 70 rpm with a low gear and standing with a 60 rpm. I usually go up a gear or two just before standing. The actual speed doesn't change but the cadence does. A lower cadence while sitting can really stress your knees and over time can cause injury. Depending on weight get as low a gear as nesssesary to keep moving without dropping below 65-70 and one that allows you to recover. Walking should never be an option. I carry a lot of weight and find a granny 24 and a 32t freewheel sufficient. Unloaded, obviously that will be unnecessarily low. The old adage of having but not needing is better than needing but not having is very fitting for cycling up steep, long hills.
The OP is talking about doing long climbs at about his FTP, so his climbing style would theoretically not vary from seeing-red-and-about-to puke.
#77
just another gosling
Quoted: 3885 Post(s)
Liked 1,938 Times
I don't have a climber (and probably sprinter) build. I am about 6' and usually over 200 lbs. I have big thighs, 23.5" circumference. In '75 while training for a cross country ride with my older brother, I noticed on a good climb (12 miles, 2200 feet climb) the first day I used a low gear and was way behind my brother, couple days later on same climb I used a higher gear and dropped him. Of course this is relative to how he was doing both days. I notice that if I have lower gears I'll use them, but I don't think it makes me climb faster, as I'll be roughly at the same cadence, I guess, as some say, my engine mimics a diesel, constant cadence no mater what I throw at it, so for speed I might as well use the higher gears as I have the strength to push them. Note you can get the same power out with high force * low cadence or low force * high cadence.
To each his own.
To each his own.
If one wants to play this game, the object of the game is to learn how to go as fast as possible over whatever distance is being ridden, not necessarily to always do that of course, but it's good to know the technique. Both strategy and tactics are in use. OTOH, you get pretty much get all this from riding with a group which is faster than you are. After a dozen rides, you start to figure it out. The other riders provide the metric.
I weigh 145 and have itty-bitty thighs, only 21", the size of Arnold's arms. You do the math.
Results matter
Results matter
#78
Quoted: 3241 Post(s)
Liked 2,512 Times
Quickly read through the thread. I gather that the I gathered this information:
OP is doing the Six Gap Century
OP bought a new bike because he didn't think the old one would cut it.
OP is questioning whether he has enough gearing or not.
OP also has a thread on hydration going so he is thinking about it hard.
Let's put up the elevation profile so we can see what he is talking about.
https://www.6gap.com/images/route-in..._elevation.png
#79
Liked 2,512 Times
Looking at the ride profile, not a lot of recovery between the punches/climbs. OP could be on the mat quickly with the ref counting down to 1 if he is not careful. I am 5'8" around 200lbs, fast twitcher, not a climber, heavy sweater and a cramper. If it is some type of endurance event, the cramps will be there. I do one major climbing event per year because it is there. Here is the profile. I will write up some thoughts.
https://ridewithgps.com/routes/29030456
#80
Bikes: 2020 Trek Emonda SL6, 90's Vintage EL-OS Steel Bianchi with 2014 Campy Chorus Upgrade
Quoted: 452 Post(s)
Liked 162 Times
The hydration thing is different than you might think. I am not worried about hydration at Six Gap (not that it doesn't have to be done, but I am expecting reasonable temps at the end of Sept). But I am going to ride a local century as a training thing shortly, where (despite a relatively early start) 90+ temps are likely. And I have concerns about my ability to absorb (as oppose to just drink) water at an adequate rate, since I sweat 5 pounds of water per hour. That would be here https://www.bikeforums.net/road-cycl...echniques.html
And I have decided that 34/32 will be good enough for me.
dave
#81
Liked 2,512 Times
Here is the advice I can give you. With that route's profile, if/when the cramps come, you are done for the day. You will be sitting on the side of the road waiting on the SAG wagon. Whatever gearing you think you need, have 2 more in reserve. Stuff can happen ride day. Maybe it is hot. Maybe you don't get enough sleep. Who knows. I don't care if you just got a new bike. There is no reason to even have the 50T on that ride. You will be on the 34 most of the time. Leave the chain on one of the small gears and coast down the descents. Freespin some at a high rpm/no load some on the descents to clear out the legs. That ride that I put up, I have a crankset that I use only on that ride. I used to do it on a 52/40/30 and a 28 or 30 biggest sprocket in the back. About 3 years ago, I made up a triple with a 50/36/28. Best thing I ever did. That crankset and a matching chain goes on the week of the ride and then goes back on the shelf the next week. Scour Ebay and other sites to find a used crank, RD, cassette, whatever you need to get enough gearing just for that ride. Even that might not work. Take a camera in case you have to walk. When you are walking people will ask you if need help. Tell them you are taking pictures and enjoying the scenery. That's what I had to do.
#82
Liked 2,512 Times
I didn't see your response until I finished mine. I didn't say a new bike was a bad thing. I ride a different bike every year on the ride I posted. What you will find on your ride is you will end up using only about 5 gears. About the bottom 3 and one on the top if you decide to pedal down the descents. The rest of the time will be spent shifting between those. Those transitions from down to up look really quick. Make sure you get onto you climbing gear before the up starts. Good luck.
I'm also on a marathon training team that starts in June for the fall marathon in Richmond Va. We train through the summer. I would link the nutrition/hydration clinic info, but it is only for registered people on the team. If you are looking for electrolyte replenishment on the cheap, the Wendy's sea salt packets included all of the potassium, magnesium, etc. that you need. Grab some of those and take them with your water.
#83
You need a metric other than speed. PM is the best, HRM works once you learn what it does. Both is even better. Without a metric, it's hard to tell exactly what you're doing. OTOH if you use a device for long enough, you don't need it as much because you get the feel of what works.
From your build, we are much different, so I feel different guidance applies.
#84
Quoted: 1975 Post(s)
Liked 232 Times
You said it yourself, your speed was only relative to your brother. He could have not been recovered as well the second time you climbed it. Power would tell you how you did relative to yourself. The second day you both could have been slower overall but you could have been less slow. speed/time up a climb that is repeated is a good proxy for power if you are consistent with timing and start/endlines
#85
Liked 1,938 Times
Huh, I am confused. First you say "You need a metric other than speed." But isn't speed the ultimate goal into getting up a hill faster? All PM and HRM do is guide you. Then you say "the object of the game is to learn how to go as fast as possible" but isn't that speed, which you say you need metric other that it? You also say "The other riders provide the metric" and that was in my original post, though admittedly only one other rider, but the same one each time, not a group.
Build matters in that the bigger rider will usually be faster on the flat - but not always. Fit and flexibility makes a big difference. Taller riders have an advantage on 700c wheels due to the limits of frame design. Climbing, it's about watts/kg. BMI 24 or less, mostly climb OK. Watts can be trained. Weight can be lost. Method is the same however, discussed previously.
Power and HR show you where your limits are and therefore where various proportions of those limits are. Those things determine how fast you get up the hill. You can't go faster than you can go, or perhaps one should say, faster than it's prudent to go. VAM is a nice metric. That and average speed are useful things to look at when the ride is over, see how you did. The fastest way to get around a course solo is to watch cadence and effort. I say that one titrates the pain.
Results matter
Results matter
#86
1) he didn't make any excuses, like he wasn't recovered
2) IT WAS 1975, power meters (or any bike computer) wasn't available!
This whole thread has been on cadence while climbing. I make a statement not all people are the same, and give an example of a different experience than most were saying and have people doubt me, try to give examples/reasons how I could be wrong. Sheez! I haven't said do it this way its the only way, I've just said my experience, and have said everybody is different, as does LeMond. Note again this was just one example, and this was from 1975. Don't you think I have had even more experience since? I lived since in Tucson with Mount Lemmon climb (31 miles, 6,430 feet) and Albuquerque with many good climbs in the area including Sandia Crest climb (20 miles, 4,200) and Santa Fe Ski Area (16 miles, 3,300 feet). And I have results to back up what I mentioned, 3rd in Sandia Climb TT, and 2nd in Santa Fe climb TT, so I am just not blowing smoke.
#87
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
In principle I will be taking on some long and steep climbs in a couple of months. And the question of gearing is still on my mind.
In my case it seems to me that, assuming that I am putting out power somewhere in the range of my ftp, that a cadence down in the 70 to 75 range is where things start to become inefficient. I think that I could pedal at 80 rpm or 95 rpm (at around my ftp) without making a huge change in physiological effort. But somewhere in the 70 to 75 rpm range and (at the same power output) I will find that the time that I can spend at roughly ftp is going to go down. And things go downhill (as in harder to maintain) pretty quickly in a very small rpm range. E.G., there seems to be a huge difference between 67 and 72 rpm.
What have others found about this in their riding. I am just curious. A new RD (or not) for my bike is driving this question.
Thanks.
dave
ps. It is a difficult experiment to run in my case because I just don't have any climbs that are long enough to test this (everything around here is up and down constantly, so constant power/rpm is not something that I can achieve on our roads).
dave
Thanks.
dave
dave
Ummm ... I just go up the hill slow enough so that I can breathe easily and fast enough that I don't tip over.
If I'm in danger of tipping over, I walk.
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
#88
In Real Life
Bikes: Lots
Liked 596 Times
Since I am the OP I would add/alter the above. There were a bunch of reasons for buying a new bike, starting with the fact that I only owned a single bike and the simple act of trying to move the nose of my saddle 1/16" left me without a bike for 5 days. See https://www.bikeforums.net/bicycle-m...st-seized.html .
dave
dave
Electrolytes.
Rowan
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
#89
Quoted: 6945 Post(s)
Liked 10,945 Times
Ashton Lambie won the Dirty Kanza 100 this year with a 56-tooth chainring. 'Course, he's a world-class track racer.
#90
In Real Life
Bikes: Lots
Liked 596 Times
More like sliding down. Once the hill gets up to about 25%, I don't want roadie shoes!
Rowan
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Likes For Machka:
#92
If you have a trainer or rollers with resistance and a power meter you might try S
At 5'11" and 150 lbs I may look like a climber, but looks can be deceiving. Losing 10-15 lbs since last year makes climbing easier, but that hasn't translated to faster.
I don't work very hard at improving my climbing, though. We don't have any long enough grades, so all we can do is repeats.
I've tried tricking myself in to thinking some settings on the indoor trainer mimic climbing, but... nah. It doesn't. Only climbing is like climbing.
#93
Quoted: 4559 Post(s)
Liked 2,802 Times
Over the past couple of weeks I've switched from mostly spinning at my usual cadence (90) on the trainer to bigger gears, more resistance and slower cadence. It'll take awhile to see results, and I'm just getting over a respiratory virus, but on the last couple of 50+ mile rides it seems to be helping. I figure I can spin outdoors to conserve energy, so it'd be better to change up my trainer routine.
#94
Liked 1,938 Times
Results matter
Results matter
#95
Liked 1,938 Times
Yes. Electrolytes move the water out of the stomach much faster. I take 1 Endurolyte/hour, but some take up to 6. Now Hammer makes an extra-strength version for those folks. I take just enough so I'm always a little thirsty.
Results matter
Results matter
#96
I do out-of-envelope stuff on my rollers. I mean, why not? So if I want big gear work, I like a 50-55 cadence in zone 3. Actually my rollers don't have that much resistance, so I have to spin maybe 70 to get Z3. Have to go outdoors for slower. Idea is no upper body movement, prying on the bars, etc. I try to do it all with my legs. Supposed to be a leg exercise. 10 minute intervals, 5' easy between. Three usually. Yeah it hurts.
tahoe_girl
Training & Nutrition
15
06-08-14 06:10 PM
hhnngg1
Road Cycling
90
01-24-11 07:43 PM
