Feathering?
Feathering?
Just found out about this, i was gunna put it in the braking technique thread but i think it deserves its own thread.
if you dont know, featherting is wen you slam your brakes on front and back for a short period of time wait a second or two, and repeat. I have v-brakes. does this work well? mainly im concerned about dh sections, like very steep down hill. can you stop quickly from fast speeds?
Wood Licker
Bikes: Trek Fuel EX 8 27.5 +, 2002 Transition Dirtbag, Kona Roast 2002
Quoted: 23 Post(s)
Its like manual ABS. Works really well. But then again I don't slam my brakes ever. I modulate them sometimes alternating front and back. Slamming brakes is a sure fire way to get injured on technical stuff.
Stopping quickly...ehhhh yes sort of. Depends on the situation. But to be honest trying to BRAKE on actual dh sections will usually mean a wipe out. Leave the braking for before and after. If you are really sketched or in the midst of wiping out drop or side slide the bike. Its gonna hurt, but not as much as if you touch the front brake and endo landing on your head.
Gravity Is Yer Friend
Location: "Over the Hill" and going down fast in the 805.
Bikes: Scott Gambler, Scott Ransom, Kona Bear, Bianchi 928 Carbon/Chorus, C'Dale Rize4
Actually feathering is as you descibed with an exception, you do not slam on the brakes. Just as the name implies, feather it. If you slam on the brakes be sure I am there to get pics
As for how fast you can stop, that will depend on a few things. How fast are you going? What are the conditions/terrain? Type of tires? What brakes? And a few others but you get the idea.
no skills...
Exactly, I always feather my front and back breaks to avoid locking up. As long as you keep you weight back and dock push the front brake to hard you can usually brake alot faster using a combo of both brakes. Even downhill, just remember to keep your weight back if you pull that front brake, and dont pull it to hard... my 2 cents
Wood Licker
Quoted: 23 Post(s)
On near vertical things never brake. Period. No matter what...or at least have a camera near by.
Wood Licker
Quoted: 23 Post(s)
Feathering...hmmm no I prefer modulating both equally. At times (very rarely) I shift back and forth...but usually just all, nothing or modulating the front.,
