1972 Bianchi build
Bikes: Novara Verita, Trek 4500 MTB, 72 Bianchi Rekord, 1987? Ciocc, 2010 Merckx LXM
1972 Bianchi build
Found this on FB Marketplace locally. After some research, I believe this is a 1972 Bianchi Rekord, although it may be a Corsa.
Disassembled and cleaned. Frame is being blasted and powder coated. Components appear to be a mix of original Campagnolo and "added later". These pics are from the FB ad. I'll post as work progresses.
Bikes: '68 Raleigh Suberbe, '92 (German) Centurion Equipe, '85 Schwinn Peloton, 1983ish Zunow Road Racer project, '69 Squanch Super Tourer, 1980 Bianchi Super Corsa, '82 Austro-Daimler Vent Noir, '89 Miyata 914 project, 1982ish Bianchi Rallye
Quoted: 294 Post(s)
Liked 9 Times
Love it. Why are you stripping paint? It looks to be in good condition.
How will you protect the chrome on fork crown from blasting?
(Asking because I have a frame needing powdercoat but has chrome areas I want to save.)
Stripping because it appeared to be over-sprayed with a "close to original" color. I cleaned up the fork by hand with a chemical paint stripper. There is no chrome on the frame. Powder Coating guy did tell me he can mask to protect chrome as needed.
Quoted: 3813 Post(s)
Liked 3,345 Times
from what may be seen in photos some of the remaining original bits include:
headset
3TTT Tourist stem and bar
wheels
Sheffield pedals
Campag Valentino gear ensemble
Universal brake levers
frame tubing is high tensile
if model Rekord original chainset was NERVAR Sport cottered
headset
wheels
Sheffield pedals
Thanks! The rear derailleur is a Shimano Crane. Not original to the build, I think. Seat may be original, although there is no marking on it. Seat Post is Campagnolo, and I believe original to the build.
Liked 3,345 Times
thank you for this additional information
pillar definitely not original
original pillar plain steel
forum has had a number of threads on the Rekord model of the early 1970's; you could browse them to see original kitting
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,927 Times
Do you have any pics of the dropouts? This is a bit older than I am familiar with but I doubt the CampI seatpin is OEM. From wjhat I can see I do kind of agree with the HiTen frame quality. I don't understand your desire to remove tyhe paint because it isn't original, for the quality level of bike we are talking about looks good. Unless you intend to keep this forever you'll never recoup the cost of powder coating.
BTW this does fit you yes? Have to ridden it 100+ miles? What if you put lots of money into this making it better and you don't like the fit or ride?
Sugar "Kane" Kowalczyk
Liked 3,345 Times
thank you for the new photos
frame ends -
dropouts are Agrati Nr. 000.8002
fork ends are Agrati Nr. 000.8010
IIRC the Rekord model of this time came with the Agrati stamped dropouts which have an integral gear hanger
of course the 1972 date puts it at the height of the boom and substituions of often required to keep production wheels turning...
original brake calipers for the Rekord model were Universal Extra model 51
if saddle original it will likely be marked on the underside with something such as "S. Marco, Made In Italy"
cycle's Sheffield pedals look to be the Corsa Nr. 655 model. toe clips appear to be AFA brand from France.
frame ends -
Forum Moderator
Quoted: 3091 Post(s)
Liked 6,601 Times
I'd have it powder coated in Celeste. It is Bianchi's traditional color and "could" make the bike more desirable if/when you sell it.
Liked 3,345 Times
here is an image of the NERVAR Sport cottered chainset on a REKORD model cycle of 1971. note also the Sheffield Corsa Nr. 655 pedals, Campag Valentino front mech, NISI wheel rims, frame pump and Campag cable guide combination pump holder.
the Campag combination cable guide and pump holder on your bicycle is part number 630 and is shown here in the catalogue of 1960 -
Bianchi Goddess
Liked 2,927 Times
frame ends -
frame ends -
Bianchi Goddess
Liked 2,927 Times
Pics of dropouts attached. Good points on the level of spending on this bike. Frame is my size. Blasting and coating is $100. Bike was next to nothing. Literally. The wild card for spending will be the wheels. Not sure the rims are usable. I need to decide if I am widening the frame to accommodate a more modern rear hub, then using 700c wheels that I have laying around. Could buy rims and spokes and use the existing hubs and freewheel. I have a set of correct Universal brakes in a parts bin. I think a pair of new lever hoods is $27. I may splurge and get repro decals for $50. Next on the bench is an 80s Ciocc, also in my size, that may ride better than this Bianchi. We'll see.
Liked 3,345 Times
thank you for finding and posting this image
must be that me poor memory misserved me once again
either that or they came through both ways...
note that pedals on cycle in image have been changed
the Sheffield model 655 is rather narrow between its inner an outer spurs so that many riders find they cannot get their shoe in
have nicknamed it "the ballerina pedal"
note that your frame is constructed with a true three-piece head while the cycle in this image is built with a bulge-formed head
a three-piece head is stronger/preferable and costs slightly more
Picture is a bit more saturated than it should be, but frame is back from Powder Coating
